Results 1 to 9 of 9
Thread: Fork help
    Mar 2013
    Fork help
    I have a kona tanuki and it has a 130mm fork will it make a big difference if I put a 120mm fork??
    Am asking this because I do alot of uphiling
    Sent from my Nokia Lumia 925 using Tapatalk
    120 shouldn't change the ride immensely. Really if your changing it for the advantage on the climbing I'm not sure it will make a huge difference.
    Mar 2013
    But there is also the factor of that there's less options with the 130mm forks
    Fat-tired Roadie
    Nov 2007
    10 mm per se isn't very important, IMO.
    Is your fork actually doing something to mess with your ability to climb?
    Mar 2013
    Not really just want something lighter
    Fat-tired Roadie
    Nov 2007
    What fork is it?
    Mar 2013
    I currently have a rockshox tora solo air
    Fat-tired Roadie
    Nov 2007
    You can probably only lose about 1.5 lb. That's got to be less than 1% of the weight you're hauling up a hill.
    I've been eating less, and have lost about 15 lb from my body lately. (And my abs are looking a lot better again too. )
    If you must do it, the lightest forks going are probably the fanciest RS in that travel, and the fanciest White Brothers and DT forks around the right travel. If you like your bike's current handling, spacing down a 140mm fork might be preferable to going to 120.
    Mar 2013
    Yea am at 198 want to keep going
  1. Lauf Trail Racer Fork. The lightest 29er suspension fork ever?
    By Shalom in forum Shocks and Suspension
    Last Post: 06-11-2015, 05:45 AM
  2. Replies: 5
    Last Post: 02-18-2014, 07:12 AM
  3. Replies: 3
    Last Post: 02-17-2014, 05:34 PM
  4. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  5. Replies: 5
    Last Post: 09-12-2011, 04:13 PM
