Thread: flat vs riser
    Feb 2006
    flat vs riser
    I use a 640 flat bar with bar ends on my 26er (100mm 5 degree rise stem) since it gives me a comfortable position and make climbing easier. Though I have difficulty to control it on some more difficult technical territories. What would be a good compromise? Thanks.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    A wider bar will retain climbing as you like it and offer better precision and control in technical sections.
    Flat vs. riser is only a question of where the grips end up. You can rise or lower stuff by changing the bar or adjusting stem position.
    Reputation: Mr Pig's Avatar
    Your stem is very long. I personally hate long stems, they make the front of the bike feel like it's wandering about. Try a stem half that length and see how that feels. You might be surprised by how much it changes the handling of the bike.
    Reputation: velo99's Avatar
    Apr 2014
    There has to be a balance between height & comfort. Fit is important as bar height. If your hands go numb after 20 minutes what good does it do to plan a 12 mile ride? Your weight should be balanced not riding on your hands. Taller stem or riser ars take care of that problem. Lighten the front end can be a matter of adjusted technique.
    The bike doesn't make you go fast.
    You make the bike go fast.
  1. Flat or Riser Bar?
    By bikerbert in forum 29er Bikes
    Last Post: 04-21-2014, 11:17 PM
  2. Riser bar vs. riser stem and flat bar
    By xycarp in forum General Discussion
    Last Post: 06-12-2013, 07:35 AM
  3. Flat bar vs riser bar
    By dudesok in forum General Discussion
    Last Post: 11-20-2012, 10:14 AM
  4. Who's gone from flat bar to riser and why
    By pamt in forum General Discussion
    Last Post: 03-02-2012, 06:21 AM
  5. Flat bar or riser?
    By bridger in forum 29er Bikes
    Last Post: 01-07-2011, 08:49 AM
