Thread: Flat tire help
    Flat tire help
    Was about to head out for ride and noticed my front tire was very low on pressure…maybe 10psi, figured I had a slow leak.
    Took the tube out and fill it with air…like 25psi, but I don’t see/hear any signs of a leak! 12 hours later and the tube is
    Still inflated at 25psi. I’m confused now….do I have a leak or not???
    addicted
    Reputation: willrace4food's Avatar
    Jan 2009
    probably not, tubes lose air over time. best to check the pressure before every ride.
    Aug 2010
    Sometimes the valve leaks and then when you disturb them to air it up, they reseal. Or someone was messing with your bike, like my kids do sometimes. They like to let the air out of my shock and then I think it has a leak.
    Reputation: mtbnozpikr's Avatar
    As previously stated, tubes lose air very slowly (depending on thickness or walls, material, and valve). Tubeless tires can lose pressure even faster. There may or may not be a hole and just because you can't hear or see any leak doesn't mean it's not there as some are extremely small and almost impossible to spot. If it's working for you I'd run it but next time you're tube is out, I would inflate it and then put it under water and watch for air. I've had punctures so small I have needed to squeeze to create more pressure to find them.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  1. Rode on a flat tire....sidewall OK or replace tire?
    By Stonebreaker in forum Wheels and Tires
    Last Post: 06-25-2010, 08:53 AM
  2. Flat tire
    By joco23 in forum Beginner's Corner
    Last Post: 08-08-2009, 04:58 AM
  3. Flat Tire
    By stargazer858 in forum Beginner's Corner
    Last Post: 05-28-2007, 09:26 PM
  4. Flat tire already???
    By HikerXJ in forum Beginner's Corner
    Last Post: 06-12-2006, 05:50 PM
  5. flat tire
    By cghornets20 in forum Downhill - Freeride
    Last Post: 05-23-2005, 03:38 PM
