    Fixed the derailleur last night on my old bike
    Was talking to friend of mine to get him to biking with me, I recently bought a Specialized stumpjumper, and I have a 18-year old hybrid sitting at home.
    Got him to try out the hybrid but no good with the front and back derailleurs. The front was rubbing against the chain, the rear the cable was loose and the hanger was off quite a bit. Not knowing what to adjust, thought we'd start with one of the adjustment screws and 3 hours later, got the bike fixed up.
    We kept adjusting the screws both ways, not sure if there's a rule of thumb as far as which sprocket should be on before adjusting? This way my first attempt to fix any bikes, I wouldn't try it to my Stumpjumper but for the old bike, there's nothing to loose!
    Would appreciate any tips on adjusting the derailleurs.
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    Do a google search
    "derailleur adjustment" gives you several options, including videos. That should be everything you need.
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Make sure your derailleur hanger isn't bent before you start too.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    The screws set limits of travel for the derailleurs. You want to adjust them so that the chain can't travel too much and get jammed into the spokes or frame or fall off the cranks. The shifting from gear to gear is adjusted with the barrel adjusters or by changing the cable position in the pinch bolt. Basic procedure is to set the limits, without cable tension when possible, and then set shift indexing. Here's a comprehensive look at the procedure:
    Park Tool Co. ParkTool Blog Rear Derailler Adjustments (derailleur)
  1. broken now fixed
    By Cantil3v3r in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2011, 08:15 AM
  2. fixed/fixed 135mm hubs other than Phil Wood??
    By girona in forum Singlespeed
    Last Post: 08-05-2009, 03:02 PM
  3. Replies: 4
    Last Post: 12-03-2008, 05:11 PM
  4. Replies: 1
    Last Post: 05-29-2008, 12:21 AM
  5. Intense M1 derailleur fixed
    By BalleRacing in forum Downhill - Freeride
    Last Post: 10-18-2005, 10:25 AM
