Results 1 to 30 of 30
    Reputation: desert guy's Avatar
    May 2012
    First Time Out Riding Clipless
    Wasn't as bad as I thought, I just built it up to be more. I only went down twice, both times at slow speeds. I did find myself riding smarter, picking my lines better, because I know that I can't bail as quickly like when I was on flats. I felt like I was able to pedal with more power and efficiency.
    One thing I did notice, my legs were on fire like no other time. I guess when I was on flats, I would adjust my feet to be more comfortable. Now, they are planted in the same spot, using the same muscles all of the time. This is the only thing I can think of, because it was noticeable.
    All in all, I like the clipless pedals.
    “You see us? We’re the people kicking your a*s. Fear us, because we will kill you, motherfu*ker,”*
    -Chris Kyle
    Jun 2013
    What kind of pedals? Maybe you need more float?
    I used to ride on Shimano SPD's, I liked them; till
    my shoes wore out.
    EVERYTHING COUNTS - IN NYC TRAFFIC - YouTube
    Jun 2013
    Do you happen to have any experience riding road bikes with clipless? I am just trying to get a comparison for my own transition to clipless on my 29er.
    May 2012
    Re: First Time Out Riding Clipless
    Quote Originally Posted by 1nterceptor View Post
    my shoes wore out.
    They are Shimano XT PD-M785 Trail SPD Pedals.
    -Chris Kyle
    May 2012
    Quote Originally Posted by Entouragegeek78 View Post
    No experience at all.
    -Chris Kyle
    Hi There!
    Reputation: TheGweed's Avatar
    Quote Originally Posted by desert guy View Post
    How did you decide where to put the cleats on your shoes? You may not have them in the right spot.
    NTFTC
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    You may want to consider the SM 56 (I think that's the part number) multi release cleats. I use them. They release in five different directions. Great for panic situations. Release when you need it, stay on when don't.
    May 2012
    Quote Originally Posted by Mr5150 View Post
    That's what I'm using for that reason. Thanks.
    -Chris Kyle
    The best thing I did was get those, I was falling over often, the multi release resolved that quickly!
    Jan 2013
    ...I only went down twice, both times at slow speeds...
    One thing I did notice, my legs were on fire like no other time. I guess when I was on flats, I would adjust my feet to be more comfortable. Now, they are planted in the same spot, using the same muscles all of the time. ...
    i am new to the sport, since early this year.
    i bought a pair of crank brother mallet 1s from theclymb .com and went at it.
    i was practicing on the street - clipping in and out - and felt pretty good.
    i hit a trail behind the house and it got scary real quick! lol.
    i went down two times and was laughing both times.
    i had a nice fall at a local lake and was not laughing
    my last fall was at a stop light after a fairly long ride. i came to a complete stop and went down... i had forgotten i was clipped in!!!
    overal, i am happy as it places my feet in the same position every time.
    and because the mallets, i have mallet 3s now, have a platform... i unclip out before if i get nervous
    joel
    May 2012
    Quote Originally Posted by JAvendan View Post
    Lol. This is so easy to do.
    -Chris Kyle
    I started out with Time clipless and getting out of the pedal took a very deliberate motion. I fell several times but after a few months I had enough. I switched to shimano with the multi-cleat and it holds just enough but releases when I need it. You can also adjust the tension on the pedal to release the cleat easier.
    May 2012
    Quote Originally Posted by shellshocked View Post
    This is my setup.
    -Chris Kyle
    Sep 2012
    I just put these on my shoes but haven't been on the trail with them. I have ridden 5 times with the 51's (single release) with no issues but I also haven't been on anything too technical. I put the multi direction release cleats on to see how they work because I have a feeling I will benefit from them when I get back on more technical stuff. Still unsure though, even on the tightest setting on my pedals the 56's seemed too easy to get out of (just riding around the street). Anyone else have experience with both? If I have been fine with the single release cleats should I just keep running with those?
    (sorry to hijack)
    Reputation: StuntmanMike's Avatar
    I've done this too! The guy I was riding with got a real good laugh out of it.
    All in all I love my SPD's though. I can't imagine riding flats. I tried it once and it just feel strange. My feet were all over the place.
    And I won't ever ride on the road w/out them! I run the same pedals on my MTB as I do my road bike....Shimano M520's... Work great and were like 25 bucks on sale.
    '15 Charge Cooker Maxi 2
    '13 Salsa Horsethief 2
    '12 Trek 6000
    '11 Ridley X-Ride
    '11 Santa Cruz Driver 8
    May 2012
    Quote Originally Posted by StuntmanMike View Post
    Same here, my feet were all over the place with flats. It was a problem, especially on steeper climbs.
    -Chris Kyle
    Jan 2013
    yeah... that fall hurt the most because i was at an intersection and i am sure the guy in the car had a great laugh - lol.
    i like how the clips keep me in the same position every time. i do not have to think about foot placement.
    joel
    Happy Trails
    Reputation: Scott In MD's Avatar
    Maybe this is helpful:
    If you are starting out on clipless, loosen the clip tension. On Shimano pedals, use a 2.5mm Allen wrench to loosen the clip tension as loose as it will go (counterclockwise to the stop), then tighten maybe three clicks tighter (clockwise). There are two adjustment points per pedal, on each flat (four total per bike). It is important to set all four equally. Loosening the tension should make for a fairly easy release. Like ski bindings, more proficient riders will use correspondingly higher clip tension.
    Another newb tip is to start with only one clipless pedal and one cage pedal ... Sort of like a training wheel.
    You should soon be able to clip out effortlessly. The benefit of clipless in efficiency and comfort is huge. I'd give up full suspension and maybe disc brakes ... Maybe... Before I gave up clipless pedals.
    Cleat location is personal, but for me a reasonable point to start on cleat location is all the way back, then forward just barely off the stop, and then rotated >> toes out a little (ie cleat pointed in a little). A pro tip is to set your bike up on a trainer (or use a spin bike), then loosen the cleats so that they will move with some friction, then spin with slightly loose cleats until they find a "home" position. A good bike fitter will set up your cleats as well, and you can mark the location by outlining with a sharpie pen.
    Pedals and cleats are individual preference, so YMMV.
    likes bicycles
    Reputation: vitale232's Avatar
    When I was learning clipless pedals, I went into my grass and practiced track stands. Since I was not very good at them, I would have to put my foot down often.
    Practicing in a situation where have to take your foot off in "panic" will help you get over the low speed falls more quickly. And since you're working on track stands in the yard, tumbling over shouldn't hurt.
    Best case scenario, you learn to track stand and to take your foot off quickly. Worst case scenario, you are really good at track standing and hang out in the yard in one position for hours. Other worst case scenario, you get really good at taking your foot out quickly.
    Either way, worked for me. I fell maybe twice on the trail while first starting clipless, and I've become a good track stander. But now I ride flats again.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    May 2012
    Quote Originally Posted by thegweed View Post
    This could be a reason. I put the cleats where I thought I wanted the pedal. They feel fine when I'm riding.
    -Chris Kyle
    Nov 2012
    I love my HT flats. With good shoes I have 3/4 motion and complete freedom of feet. I use these on an AM bike. I am about to purchase/build an XC and will use clipless.
    I dropped the clipless on my AM after wiping at speed and stripping one of the screws on the cleat. The cleat spun as a result and I was stuck to my rig. I tumbled down hill at speed attached... Lucky I wasn't hurt worse... three weeks.
    May 2012
    Quote Originally Posted by Scott In MD View Post
    Good info. I'm going to try that method to try to get my cleats right. Thanks.
    -Chris Kyle
    Reputation: J.B. Weld's Avatar
    The problem with this is that if you leave the cleats loose enough to float around they will move when you unclip.
    I agree that for most shoes cleat position is best all the way back, sometimes more (I've used a file). The angle you position the cleat somewhat depends on how you walk, if you walk pigeon toed for example then you should position your cleats that way.
    May 2012
    Quote Originally Posted by J.B. Weld View Post
    Mine are almost all the way back.
    -Chris Kyle
    Happy Trails
    That's what the sharpie is for. Loosen cleats to friction-tight, clip in, spin; find home position on your cleat, remove feet from shoes while clipped in, trace (or locate visually) the outline of the cleat on the bottom of shoe as best you can while shoe is clipped to pedal, unclip; adjust, tighten cleat screws.
    But I agree; this could be a helpful trick to set up your cleats, but might not work for everyone. Cleat will likely move when you unclip. And tracing is probably the wrong word. "Locating" maybe a better word. Works for me. YMMV.
    Vincit qui patitur
    Reputation: owtdorz's Avatar
    I just started road riding and have been clipless on my MTB since I started riding a year ago.
    I ride clipless on both the Road and MTB and do not notice any difference. I ride with Speedplay Zero and Frogs.
    The only thing riding road I never worry about having to bail like MTB.
    Vincit qui patitur
    2014 KONA Process 153
    2016 KONA Operator
    2017 Salsa Powderkeg
    2018 Santa Cruz Tallboy 29 C R
    Jun 2013
    Everyone does that a couple times when they are new to clipless. Actually, I did that last week with a rental bike with toe clips & straps. I guess my usual release move didn't work.
    As you get used to clipless, you'll always release when you want, and almost never not-release when you don't want.
    May 2012
    Quote Originally Posted by Racnad View Post
    This is good to hear, cuz there are several sections of the trail where I was really scared, mostly the sections where I could go over the side if I wasn't able to catch myself. I actually stopped in those sections to get a good look, and I never did that on flats.
    -Chris Kyle
    Jun 2013
    I just started riding a road bike this year, after about 20 years riding a mountain bike with SPDs. The first thing I did with the road bike (inherited from my dad) was put a set of SPDs on it. I feel that once you are used to clipless, you really don't like pedaling any other way. If you are used to clipless on a road bike, it will feel natural on your 29er, and you probably won't have problems not releasing when you want, provided you have the same system on both bikes. I would recommend the "multi-release" models for mtb while they're probably not needed on a road bike.
    Level 5 Rider!
    Reputation: Desidus's Avatar
    Jun 2013
    I don't have clipless and am a total noob, but your legs are probably burning because you are using muscles you haven't normally utilized much. I ran before I started biking and my legs are burning right now because of muscle groups being used in ways that they hadn't until now. Same thing with clipless, you are now pulling up to power the bike, not just pushing down drawing on a new muscle group. May burn now but will lead to large advantages when your muscles adapt to it.
  1. Tried Clipless for the first time
    By JM27 in forum Arizona
    Last Post: 01-24-2013, 08:06 AM
  2. its time.. clipless pedals??
    By fondoo in forum General Discussion
    Last Post: 12-07-2012, 08:57 PM
  3. First time going clipless
    By bapski in forum Beginner's Corner
    Last Post: 11-05-2012, 07:58 PM
  4. Replies: 56
    Last Post: 09-27-2012, 05:20 AM
  5. First time clipless - how do I choose a shoe?
    By one incredible donkey in forum Apparel and Protection
    Last Post: 12-31-2010, 03:14 PM
