Results 1 to 20 of 20
    Oct 2013
    First MTB Ride (questions inside)
    So I went on my first ride today in San Marcos, TX on Pergatory Creek - Prospect Park.
    For starters I went on the beginners trail...but then kept going, got lost, and ended up going 4 miles on an intermediate trail. It was extremely difficult but really fun. I got completely stopped a couple of times due to e smashing my pedals on rocks; hopefully it wont effect the frame of the bike :/.
    But anyways. Attached are some pictures. One of them is of my fork. I was curious if it going down as much as it did in the pictures during my ride is bad or if it's fine? (The oil ring from the fork/shock?
    Also, my friend brought his buddies 100$ Walmart bike...which actually survived.
    First MTB Ride (questions inside)-img_1939.jpgFirst MTB Ride (questions inside)-img_1942.jpgFirst MTB Ride (questions inside)-img_1946.jpgFirst MTB Ride (questions inside)-img_1947.jpgFirst MTB Ride (questions inside)-img_1948.jpg
    Reputation: hey_poolboy's Avatar
    Congrats on your first ride! Nice bike. Looks like a Seeker...? If that's an air sprung fork I would be inclined to reduce your pressure a bit. You aren't using your available travel.
    You should take a few minutes and set your sag on your fork. It would require a shock (suspension) pump or a trip to an LBS that would help you out. Sag is not necessarily the end all be all, but it's a good place to start. See here for a basic how-to.
    Reputation: StuntmanMike's Avatar
    Congrats on the first ride, and welcome to the sport! Sweet looking bike.
    And like poolboy said, looks like you aren't using all of your fork travel.
    '15 Charge Cooker Maxi 2
    '13 Salsa Horsethief 2
    '12 Trek 6000
    '11 Ridley X-Ride
    '11 Santa Cruz Driver 8
    Oct 2013
    Quote Originally Posted by hey_poolboy View Post
    Yea I thought I had my sag set (it's an Airborne Guardian). I had it set to about 25mm when I got on and off.
    With what I have set now, will it hurt my bike or am I just not utilizing all of my shock which would make it ride more comfortable? Also should I turn the Preload to - (negative) or + (positive)?
    Thanks for the help
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Using all available fork travel will undoubtedly make your bike more comfy and plush. Play with the setting some to get what is to your liking. My preference is slightly more to the + air side(60%+/40%-).
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Oct 2013
    Quote Originally Posted by Zachariah View Post
    Thank you.
    I know there is Preload which in the top nob, but there is a nob on the bottom of the fork. I guess I'll have to play with the Preload more and maybe later adjust the bottom one
    Hoping to get back out tomorrow again if I'm not too sore
    If you have a preload knob I would imagine you have a spring fork. You could decrease the preload a bit to help. It would be a good idea to see if rockshox has a spring / weight list. You may be better served by a lighter spring.
    Either way, it's not going to hurt your bike. It will only affect your ride.
    Sent from my DROID RAZR using Tapatalk
    Oct 2013
    I appreciate your helpful response. I was kind of figuring the spring size might be too "large" for me. I guess we can see how it goes tomorrow when I fiddle with the settings. I know for the first little bit I had preload set all the way to Negative (-) and I turned it to Positive with 3 full turns. I honestly didnt notice very much difference; maybe because it's new and not broken in or that I am just knew to the whole MTB scene and cant tell small adjustments.
    Won't hurt a thing.
    Turn preload to negative to soften it up; positive for a firmer ride.
    Mess around with different settings and do some testing on the trail so you can get a feel what the adjustments do.
    Hi There!
    Reputation: TheGweed's Avatar
    If'n you ever get the chance you might want to route that front brake line inside the fork. Glad you got out there today.
    NTFTC
    Oct 2013
    Quote Originally Posted by thegweed View Post
    So it wont get caught on trees and shrubbery?
    Reputation: lotusdriver's Avatar
    Sep 2013
    Those trails look awesome, and it sounds like you had a great ride on your first time out.
    My last bike had spring forks and as I only weigh 72kg they hardly moved. After I changed the springs for softer ones they worked a lot better, so I suggest you might want to look into doing that.
    But the forks are working fairly well as they are, it is just that you could get them to work better.
    Oct 2013
    Quote Originally Posted by lotusdriver View Post
    Yea that part of the trail was the easy part -.-
    The Intermediate areas (almost all of what we did) was borerline expert. Fully of jaggy rocks I thought would destroy my tires; but they survived. Really enjoyed myself and I'm happy I had gloves and padded liners under my shorts or I'd be super sore.
    Hi There!
    Quote Originally Posted by Gedemer View Post
    Yessir, and besides it looks by your last picture the line routing is at the back of the top of the fork and then down to the caliper. I can't tell exactly from the picture. If the brake is working then don't worry about that for now, just keep riding. Good luck.
    NTFTC
    Oct 2013
    ^ Alright, yea I'll reroute/zip tie it. I know what you mean.
    Also;
    Is there a way to tighten the brakes? My front brake is nice, but the right (back brake) side is a tad bit too easy to press and engages only when pressed very hard. Thank you.
    Disc brakes need to be bedded in , What that means is that you need to get them hot. Get up to 10 so mph engage the brakes firmly ,do that a few times .Some of the more expensive brakes have adjustments,what does your bike have?
    Fat-tired Roadie
    Nov 2007
    What brake do you have? My instinct is that it needs to be bled...
    Oct 2013
    Brake Levers Tektro Auriga Comp
    Brakes Tektro Auriga Comp Hydraulic Disc
    Rotors Tektro 160mm Rotor
    Airborne Bicycles. Guardian 2.0
    Fat-tired Roadie
    Nov 2007
    I don't have direct experience. But my understanding is that Tektro's hydros aren't really "there." (Probably if they were, they'd sell 'em as TRP.) Talk to your mechanic and do your homework, of course, but you may be looking at swapping on some BB7s or name-brand hydraulics.
    Nov 2012
    keep at it. Once you get bit, there is nothing like trail riding, always a lot of fun...
    If you can find a good shop - go there, show them you'll support them when you can for purchases, and get them to look at your bike and address this issues you're concerned with. I am blessed with a local shop with people who ride and enjoy it, and love working on bikes - eve those not bought there.
    Having friends to ride with who have better skills is also a good way to get better.
    And third, don't be afraid to spend money to improve your ride if it fits you and you're expecting to keep it. (Maybe those brakes....)
  1. derailleur setup, common issues? (beginner questions inside)
    By briswo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-19-2012, 05:59 PM
  2. Chile boys can ride! See inside
    By Jaybo in forum Downhill - Freeride
    Last Post: 02-23-2012, 02:33 PM
  3. First ride on the EMD today, review inside...
    By madsedan in forum Niner Bikes
    Last Post: 12-13-2011, 06:46 PM
  4. Replies: 2
    Last Post: 04-27-2011, 11:14 PM
  5. Waldo Canyon night ride 3/16 (video inside)
    By hitechredneck in forum Colorado - Front Range
    Last Post: 03-18-2011, 08:30 AM
