Results 1 to 33 of 33
    Sep 2013
    New question here. first bike recommendations/suggestions?
    I'm selling my car and replacing it with a bike. If I can get $6500 for he car, my bike budget will be $1500. I'll be using the bike mainly to get to and from appointments; grocery shopping; and just getting around. Would a hybrid be best for me? fwiw, I just measured my in-seam, and it's around 33 inches. I'm 5' 7" and weigh roughly 175 pounds. Keep in mind that I haven't ridden a bike in at least 25 years. With my expected budget, along with my background, which bikes should I look at?
    Thank you.
    Reputation: lotusdriver's Avatar
    Sep 2013
    Are you wanting to ride the bike off road at all? Maybe going out on some local trails at the weekend. Or is it going to be purely for town/road use?
    Sep 2013
    not likely; recently had total hip replacement, so balance/stability is my main concern.
    Sep 2013
    Then you are probably on the right track with a hybrid or city bike.
    They have road biased tyres but still a wide range of gears, and the riding position is more relaxed/comfortable.
    Sep 2013
    Thanks, lotusdriver
    Sep 2013
    Transport - Trek Bicycle
    a bike like this?
    Sep 2013
    Not unless you want to carry a load of stuff with you, maybe if you are a window cleaner!
    Have a look at the Trek 7.4 FX for the kind of bike you are looking for.
    Is this your year round primary transportation? A fat bike like you see in the Cargo Bike section should be an option.
    Cargo Bikes
    Sep 2013
    Yes, this will be my year-round, do-everything bike. I'll check out the cargo bikes. Thanks!
    Sep 2013
    Well, l guess if you want to carry that much stuff with you.
    I have never seen a "cargo bike" here in the UK, at least not out on the road. So am not familiar with that branch of cycling.
    Maybe it is a good idea over in the USA where the weather is better.
    Clueless genius
    Really, any touring bike would be a good fit for what it sounds like you want to do. Plenty of places to mount fenders, racks, panniers, bags, etc. More upright geometry for long distance comfort, sometimes flat bars and sometimes drop bars. Even a steel cyclocross bike (Provided it has rack and fender mounts) would be a good option!
    1994 Cannondale M400 2017 Felt Surplus 30
    1997 Marin Point Reyes 2013 Pivot Mach 5.7
    Sep 2013
    How about these three?
    520
    7.4 FX
    CrossRip
    Are you going to by using this for grocery shopping during the winter?
    If you think you may ride in snowy conditions, then a fat bike with wider tires could be a fun option.
    Sep 2013
    yes, I will most likely be riding in the winter, eb1888...have any 'fat tire' bikes in mind?
    Thank you.
    Quote Originally Posted by NHBiker2013 View Post
    Thank you.
    If you can start a thread in this section or read some others I think you will get some good recommendations.
    Fat Bikes
    And of course test riding for fit is free and a good info source.
    Sep 2013
    Thanks...sorry about that.
    Re: first bike recommendations/suggestions?
    Where do you live and what weather do experience? I would never get a fat bike as my only bike.
    Also, there is no need to spend $1500. For a daily use bike, a $300 used beater bike is the perfect bike, I'd put a bike rack in the back.. You can lock it up without it being targeted by thieves, its more secure. Different larger tires for winter maybe.
    A bike might not play friendly with your hip, you might try and incline bike, spending less now will give you more options later.
    Check the commuter subforum on here. Those riders are very experienced and you'll find better guidance there IMHO.
    Sep 2013
    I live in NH, where the winters are long, cold, and snowy.
    I plan on around $700 or $800.
    Off I go to the commuter sub-forum. Thanks!
    Sep 2013
    I just ordered a Schwinn Protocol 1.0 Men's Dual-Suspension Mountain Bike (26-Inch Wheels, Red)
    Sports
    I'd cancel that order. That would be my last pick bike for commuting.
    This costco bike gives better value imho, but there are often better deals.
    Northrock XC6 bike 3x8, 18" and 19.5" $379 at costco
    Sep 2013
    The Shwinn Protocol 1.0 is one of those very cheap full suspension bikes, selling at about 300 in the UK.
    It will work, but will be very heavy and clunky. The suspension will move but it won't be much help and the cable front disc brake will be marginal at best. The gears will work but you will always be adjusting them, and various parts on the bike will soon go rusty as the chrome plating peels off.
    On flat roads it will probably roll well, as these heavy bikes often do. It will be useable but it won't do you any favours.
    At the very least call the bike shop and pay the extra for the Protocol 2.0.
    At least that one has a SRAM drivetrain.
    Although it is still made from steel, so will probably weigh as much as a small car.
    Sep 2013
    order canceled, new order placed at Bob'sbicycles.com for a 2013 Flightline
    Sep 2013
    That looks a lot better!
    I think you will be much happier with that one, than the Schwinn.
    Sep 2013
    thank you. It'll be my first bike of any kind in 25 years.
    Fat-tired Roadie
    Nov 2007
    I skimmed the thread last night and glanced in the commuting forum this morning.
    While it wouldn't have been my choice, I think a hardtail MTB is a much better place to start than either a FS or a hybrid. They're basically the Dutch bikes of our country.
    For commuting, I found I wanted a lot of accessories. I had a powerful headlight and multi-LED blinker, and my commuters have had a rack and fenders. I have the Kryptonite NY U-lock, which is probably good enough for most places outside Manhattan.
    What to wear can be tricky. I used to commute a little over two miles. It was long enough that a jacket that didn't breathe well could be a real bummer and my shoes would get sprayed with water and I'd get rained on on wet days, but short enough that I didn't really want to pull on the spandex and change at my destination, which can be awkward. For me, the key was a wind resistant hoodie on most days and a really expensive cycling specific rain jacket when it actually rained. On rainy days, I also wore some gore-tex pants I'd chewed up snowboarding and some gore-tex running shoes. This meant I'd get to school wearing clothing I could wear all day, except the jacket and pants on days I wore those. Once I had an office, I left a sweater there for those days.
    For longer commutes, wearing more cycling clothes and changing at the office can be the way to go.
    For commuting, I think clipless pedals are overrated. I like 'em on bikes I ride as a sport, but toe clips work with whatever shoe I happen to be wearing. That's one less thing to store, and one step less messing around.
    For short commutes, I like a messenger bag. Around a half hour or if there's a major climb, I prefer a pannier.
    Those douchey little cycling caps are great for bad weather and helmet hair reduction. I have a couple.
    Leave nothing removable without a tool on your bike when you walk away from it.
    Don't be afraid to take the lane. If there's not enough space for a car to pass you comfortably on the left, you're less likely to get clipped, IMO, when you're riding in the passenger-side wheel track. Don't ride in the gutter. That's for garbage, and usually doesn't have enough space to either side. Signal your turns, and place yourself for left turns (or not to turn right when a lane gets tacked on) as you would in a car.
    What else... slick tires are nice but unnecessary when the roads are dry or only have water on them. Knobbies are enough for snow but not black ice. I haven't tried studded tires.
    Sometimes, the ride to work can be the nicest part of the day. Usually my days go at least a little better than that. Be safe and have fun. You'll figure out what stuff you do and don't care about.
    Sep 2013
    Thanks, Andrw.
    Sep 2013
    Well, I went test-riding today. I tested a Trek 7.1; another Trek whose name I cant recall, and a 3-wheeler from another company. I fell testing the 7.1; I couldn't even balance long enough to get on the second Trek; and I almost tipped the 3-wheeler...not a good outing; however, it told me what I needed to know (I need to re-learn how to ride a bike after 25 years' driving.) the price will be very reasonable (under $500); so, unless something happens, it looks like I'll end up buying the 7.1.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I had a FX 7.3 that I used for commuting for a year. I picked it up used with a computer on it for $250 ish. I put a carbon seatpost, carbon handlebars, Selle Italia Carbonio saddle and a better stem on the bike to absorb road vibration, more comfort and dropped a couple pounds off the bike.
    It was fast, comfortable, and the flatbar made it great for around town.
    Sep 2013
    Thanks for sharing this, Moe. I think I'll end up with the 7.1.
    Sep 2013
    canceled the order & went to my LBS instead
    Fat-tired Roadie
    Nov 2007
    Surly is doing some non-suspension mountain bikes right now. If any of your local shops carry those, check them out.
    Kona also has some pavement-going MTBs they market for commuting, and that people like. I'd look at those too.
    I actually prefer road bikes for the job myself, but it sounds like you'd benefit from something more stable, at least for a while.
    Sep 2013
    yes
    Thank you.
    Save up to 60% off new Fat Bikes and Mountain Bikes - MTB - Motobecane 2014 Fantom FB4 Elite
    Easy, fun and good also in snow.
  1. Replies: 9
    Last Post: 05-30-2013, 11:52 AM
  2. Need suggestions / recommendations for restoring saddle fade
    By sminniear in forum General Discussion
    Last Post: 10-26-2012, 10:59 AM
  3. Bike recommendations?
    By PDXDrew in forum 29er Bikes
    Last Post: 07-06-2011, 09:27 AM
  4. bike recommendations
    By jnmayes in forum Beginner's Corner
    Last Post: 01-23-2011, 07:22 PM
  5. Bike Recommendations?
    By JustStarting in forum Clydesdales/Tall Riders
    Last Post: 01-06-2011, 11:25 AM
