Results 1 to 3 of 3
    Jun 2013
    Idea! find the degree of rise on my stem
    I used an angle finder on my stem to find the degree of rise. The numbers are pointed at 20, 70 & 110. If this works, which number is the correct rise? (long vertical arm of angle finder is parallel to steerer tube... short arm of angle finder is parallel to “nose” of stem). I'm sure you experienced bikers can tell the degree of rise on my stem by just looking at the pics. Thank you
    Attached Thumbnails Attached Thumbnails find the degree of rise on my stem-img_0396-forums-minus-name.jpg
    find the degree of rise on my stem-img_0412-angle-finder-steel-stem-20-70-110-fav-forums.jpg
    Reputation: MSU Alum's Avatar
    It's from horizontal. i.e., 20 degrees.
    Jun 2013
    tyvm MSU Alum
  1. stem rise vs. handlebar rise?
    By allrachet in forum 29er Components
    Last Post: 01-11-2013, 07:09 AM
  2. Can't find 36/45 degree/ 44mm OD integrated headset?
    By dooku in forum General Discussion
    Last Post: 01-09-2013, 09:38 AM
  3. looking for a -25 degree stem
    By pernfilman in forum Weight Weenies
    Last Post: 06-17-2012, 06:56 AM
  4. Best 70mm stem options with at least +/-5 degree rise?
    By chumbox in forum General Discussion
    Last Post: 09-23-2011, 06:57 AM
  5. Replies: 16
    Last Post: 03-10-2011, 06:43 PM
