Results 1 to 8 of 8
    Nov 2013
    A few questions from a newbie
    When I was setting the sag on my forks I let a bit of air out and a greasy green type oil came out is this normal ?
    Dam I now can't remember the others questions now but will add them when I remember
    Nov 2013
    I noticed it when my bike wheel was free wheeling then rear cassette seems to move side to side as if something is bent but my brothers bike does it as well ? Thanks in advance just intrigued really
    Dec 2010
    Both of things you mentioned are normal and are not signs of a serious issue. Keep riding
    Nov 2013
    Thanks It's a brand new bike is it still normal ? Haven't actually had a proper ride yet was ill all weekend and haven't got any got lights yet so desperate to get out soon see how she performs
    Dec 2010
    Yep, completely normal better get some lights and get out and ride!
    Jan 2013
    Quote Originally Posted by lankyspark21 View Post
    That's nothing to worry about, especially for a new bike. Just get better and ride it. I am sure that everything will be ok.
    Nov 2013
    Had my first little ride today luckily was working at home which gave me half hour to get out and ride it, with new skills learnt from the cornering videos I was able to hit the turns so much faster stopped trying to ride it like a motorbike and lean into the corners now looking forward to doing some proper trials at the weekend!!!!
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    The air piston is covered by a layer of very thick oil which helps keep the o-ring(s) inside the air spring lubed up so they don't leak. A very small amount of oil often comes out when you unscrew the shock hose, as was said this is normal. If you want to reduce the amount of oil always make sure that the valve you're inflating is facing upward. So if you're inflating an air valve that is pointing toward the ground, it's best to turn the fork over when removing the hose. Also important is to make sure that if you do have a valve pointing toward the ground (many Lefty forks, Rockshox negative air chambers, and so on) to make sure that you prevent that oil mist from getting on your disc rotor or caliper. Hold a clean rag around the air hose when you unscrew it and wipe everything clean before you put the valve cap back on.
  1. Newbie questions.
    By Fuzzwardo in forum Fat bikes
    Last Post: 10-17-2013, 07:32 PM
  2. newbie with serious questions lol!!!
    By paras99 in forum General Discussion
    Last Post: 04-24-2013, 08:28 AM
  3. newbie questions
    By Javier in forum Wheels and Tires
    Last Post: 10-09-2011, 08:32 PM
  4. 1x9 newbie questions
    By Tubbsy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2011, 08:39 AM
  5. Fat Newbie questions!
    By boomhauer in forum Fat bikes
    Last Post: 08-06-2011, 12:39 PM
