Results 1 to 16 of 16
    Dec 2013
    Duda sobre la potencia y el manillar
    Hola amigos, he buscado una respuesta a mi pregunta pero no la he hallado, es la siguiente: compre una bicicleta hardtail, pero la potencia no abraza completamente el tubo de la horquilla como se aprecia en la foto, la pregunta es ¿Hay algún riesgo al circular así?
    Agradezco sus respuestas de antemano
    Attached Thumbnails Attached Thumbnails Duda sobre la potencia y el manillar-image.jpg
    Reputation: Kiwiplague's Avatar
    If you are asking "is my steerer tube too short?" then I'd say, yes, it does appear to be a bit shorter than it should be. The fact that the upper bolt of the stem is above the top of the steerer is way less than ideal. At the bare minimum you should get a stem with a lower stack height. Only other option is to get a new fork with the correct length steerer tube.
    I don't crash, I just have slightly uncontrolled dismounts!
    Reputation: Gasp4Air's Avatar
    True. The top edge of the stem should only be 2-3 mm above the top of the fork steerer tube.
    Use it, use it, use it while you still have it.
    Reputation: Thorin_2's Avatar
    Jan 2009
    Si, hay much riesgo en mi opinion, especialmente si lo vas a usar "off road".
    ****** to the dirt
    Quote Originally Posted by Poncharelax View Post
    google translate Hello friends, I have sought an answer to my question but I have found, is: will you buy a hardtail bike, but the power does not fully embrace the fork tube as shown in the picture, the question is are there any risks when driving it?
    I appreciate your answers in advance
    Yes there is a risk in riding the bike with the steer tube that far down. If there are a few ring shims under the riser take them out. If not you are going to need a new fork.
    google translate
    Sí, hay un riesgo en la bicicleta con el tubo de dirección que muy abajo. Si hay algunas cuñas de anillo bajo el elevador se los saca. No te vamos a necesitar un nuevo tenedor.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Riesgo hay y mucho si la usas en la tierra, tienes anillos debajo de la potencia? remuevelos de lo contrario tendras que reemplazar la horquilla o buscar una potencia menos ancha si es que existe.
    Dec 2013
    Quote Originally Posted by deke505 View Post
    google translate
    He sacado algunos anillos, esta es su nueva posición, creo que sigue siendo corta. Gracias por sus respuestas.
    Jan 2009
    Para mi esta much mejor ahi. Quizá no para hacer "downhill" ni nada por el estilo pero si para uso general (en mi opinion).
    Esta mejor pero todavia esta corta, cambia la horquilla.
    Sent from my HTC PH39100 using Tapatalk
    Dec 2013
    Quote Originally Posted by DiRt DeViL View Post
    Sólo la uso para transportarme en asfalto y rara vez en terraceria, la horquilla absorbe las imperfecciones del pavimento, algunas bajadas y ligeros golpes. Tengo una Giant Anthem para la fiesta en la montaña. Gracias a todos por sus respuestas.
    ****** to the dirt
    Todavía puede ser peligroso. Si coges un bache o un agujero en la carretera o la suciedad de las barras de control todavía pueden desprenderse.
    Quote Originally Posted by Kiwiplague View Post
    "usted debe conseguir un tallo con una altura inferior pila"
    This.
    Googlated...
    Usted es madre parece alto. Usted no debería tener problemas para encontrar uno que no requiere tanto del tubo de dirección a qué aferrarse. Tome el suyo apagado y medir la cantidad de tubo de dirección sobresale por encima de los auriculares, y luego comprar un tallo cerca o más corta que la longitud.
    Lo siento si alguien ya dijo esto - yo no traduzco los demás mensajes para leerlos.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    "Usted es madre parece alto" translated back into English on the Google says "Your mother seems high".
    I don't know how 'stem' turned into 'madre', no offense Ponch.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Reputation: Betarad's Avatar
    Quote Originally Posted by slapheadmofo View Post
    Perhaps Google is assuming that she actually assembled the bike for him.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    I am picturing this thread in my head and all that comes to mind is the Jimmy Kimel Live interview with Will Farrel, about the movie, Casa de mi Padre.
    Cheers!
    Quote Originally Posted by abelfonseca View Post
    i am picturing this thread in my head and all that comes to mind is the jimmy kimel live interview with will farrel, about the movie, casa de mi padre.
    Cheers!
    lol
  1. New 29er FRENCH frame - SOBRE !
    By GoldenG in forum 29er Bikes
    Last Post: 04-18-2012, 01:56 AM
  2. Duda con tubeless Kit
    By Leomtb in forum Mexico
    Last Post: 04-13-2012, 12:25 PM
  3. Sobre DAD 29"
    By Jingleman in forum 29er Bikes
    Last Post: 08-15-2011, 04:12 AM
  4. una duda
    By el_novato in forum Mexico
    Last Post: 04-17-2011, 10:13 PM
  5. My Enduro Hardtail........Sobre OFF
    By steph89 in forum All Mountain
    Last Post: 03-28-2011, 12:35 PM
