Results 1 to 36 of 36
    Oct 2013
    Drivetrain Recommendations
    So today I picked up an '05 Giant Rincon for $80. However, I discovered that the PO swapped wheels at some point, leaving me with a 7sp freewheel setup on a bike meant for an 8sp freehub/cassette. I stopped by my LBS, who set me up with a brand new wheel they pulled off another customer's bike. Unfortunately, no such luck with a cassette or crankset (which has a really worn, small chainring).
    I've been poking around and found a Shimano HG51 (11-30) cassette and FC-M361 Acera (42/32/22) crankset. These match the OE gear spreads, which is actually a requirement for the crankset thanks to a front derailleur mounted directly to the BB. But otherwise, I know nothing about what I should be looking for.
    Budget is kind of an issue. I want decent parts, but at the end of the day, it's still a cheap bike. I don't need to spend more than the bike's value rebuilding the drivetrain. It's going to be used as a commuter bike I can take out and pound the dirt with.
    Thoughts?
    PS: Which tool do I need to install the new cassette?
    The parts that will make whatever you pick up shift like a high quality expensive setup is the housing/cable. A Jagwire lined housing and stainless slick coated cable run as one piece(drill out the midpoint stops) will make you very happy. Use a little silicone lube.
    REI has a Novara/Jagwire set for $19. Superglue the cable before you cut off the end and thread it through the housing. And put a drop on the cut end first too. They also sell the housing in bulk. You need a couple more feet because the kit is sized for a broken up run. Make a big loop at the rear derailleur to avoid drag.
    Oct 2013
    Interesting, and thanks for the input. I do have a shift cable kit on my to-do list, as the current housings are thrashed.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I imagine eb1888 has his own reasons for running full length housing, and I will say he is an excellent poster here.
    Personally, I would only run full length cable housing if I lived in an area where contamination (water, mud) was a factor. Fortunately, I don't. The less housing, the less compression of housing that takes place. As long as you are not sloppy with cutting the housing, use good quality ferrules (I prefer nice aluminum ferrules), and route the housing sensibly, interrupted housing performs better IME. If you live in, and ride in wet, muddy conditions, in that case, full length housing would be worth considering.
    Still don't know that I would drill out the cable stops. That would stop me in my tracks if looking at a used bike. If you're going to bury it when you're done with it, knock yourself out. JMHO.
    You don't need to drill anything to run full length - just zip tie the housing in place.
    FWIW, I don't think lined housing is worth bother with. It's more of a PIA to install, seemed to get gummed up more quickly, and I never noticed much of a performance difference, even with some pretty expensive kits. YMMV. And at $19, at least it's not a brutal rip-off, like the pricing on some of the lined cable kits.
    OP - any reason you're not choosing to just replace the worn front ring instead of the entire crankset?
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Oct 2013
    Unfortunately, the individual rings are nonreplaceable. Have to do the whole thing=/
    I really wish I had spotted this stuff before picking up the bike, but live and learn.
    Gotcha.
    Don't forget to budget for a new chain too.
    One thing that might take the sting out of opening up your wallet is to just chalk it up to the fact that rings, cogs and chains are wear parts - like tires, they need regular replacement, and that regularly recurring cost is just part of the game.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Oct 2013
    Yeah, that's how I'm trying to look at it. My wife, however, is not so understanding, lol. Considering it needs two new tires, cassette, crankset, and shift cables, plus I need to tune the shifters/brakes and grease the bearings... I'm not thrilled with the quality of the shifters either, but they're functional so they're going to have to stay until later on.
    Any thoughts on the individual pieces? Should I be looking at SRAM stuff instead? My choices were based on Amazon reviews, but no practical experience.
    Definitely full length housing is necessary for muddy, wet and heavy dusty conditions. But the reason to run jag lined housing full is to remove three or more ferules from the cable run. Aluminum ferule ends cut as they wear slotting to become drag clamps on the cable and you get much sooner to the slowed down shift that you can't quite adjust out.
    Cheaper shifters and derailleurs don't seem to have quite as much spring pressure as the upper range stuff. When you put the Jag full length on and you get a butter shift that uses that lesser spring rate. You can't get that with the better sets.
    One of those things you do once and don't consider going back.
    $19 bucks is pretty cheap to spend to try something that could make a major improvement in your riding experience.
    But you do have to properly cut the end off the cable. You need it to be rounded smooth to maintain the quality of the liner in the housing.
    Use a sharp dedicated quality cable cutter, like a Pedro's.
    Coat the cut location before the cut with superglue like Q-Bond. Coat the end after the cut.
    Sand the end round and recoat.
    Spritz some silicone lube into the housing.
    Carefully thread the cable through a ferule and the housing out through the end ferule.
    Big loop of housing at the derailleur end . Cut the cable for final length after superglue again.
    There you go.
    Oct 2013
    By "loop," do you mean a full circle? Or just a large half-circle?
    I like turtles
    Reputation: TiGeo's Avatar
    To me, to change crank (the BB is probably hosed too) and the other parts, you may approaching the cost of a new entry-level bike (still will probably be cheaper to fix what you have). Cassette, chain, crank, etc. is going to set you back at least $150..and that is online prices where you will have to do your own install. See what the shop that did the wheel can do for you on this stuff..sometimes they have stuff laying around the shop they want to get rid of or even used parts that will still work just fine.
    I wouldn't get too hung up on the full length housing tangent...just replace what you have if it needs it.
    To answer your question, to install your cassette, you need a cassette tool which is a splined tool that fits into the lock ring - probably runs $10.
    Seriously..from what you are describing, go to the shop and have them evaluate what you need and see what they can do for you..if they can get you fixed up for $200 including labor you have done well.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Quote Originally Posted by eb1888 View Post
    I'm glad it works well for you, but I've be hitting the riding for almost 25 years through all seasons in New England, and it's not even in the ballpark of being a necessity.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Oct 2013
    Quote Originally Posted by TiGeo View Post
    The parts I originally mentioned, including the chain and a cassette tool (still not sure if it's the right one - there's a few different types), come in at under $80. While I'd love to have $150 to spend on that kind of stuff, I don't see the point in putting that much into a low-end bike that doesn't really need it right now.
    The shop I originally went to is primarily a used parts shop, and they have no 8sp cassettes. They were willing to sell me a good crankset and install it for free, until we figured out that the FD is non-adjustable and wouldn't accommodate the crankset they had on hand. They'd happily order me new parts if I asked, but I'd still have to pay overhead, and I have no problem investing in a couple shop tools (crank puller, cassette tool) that I can keep on hand vs paying a shop to do everything for me, and then having to go through the same thing when I wear out the new drivetrain.
    Fat-tired Roadie
    Nov 2007
    All front derailleurs are adjustable. It's a fairly fine-tolerance action, so they have to be. What are you trying to do that's throwing the chainrings far enough out that you can't still install a different crankset? I'd expect that any other MTB triple for an English bottom bracket would be able to drop right in. Can you post a pic? I'm also surprised that an Acera crankset doesn't have replaceable rings. Mine did...
    Check out parktool.com for well-illustrated instructions when you start replacing things.
    I like turtles
    ^^^What he is saying is that his FD is a BB mount - like a chain guide. He has to mount it to the BB and the crank has to be spaced so that it will work with his FD. Sure..its adjustable...but not from the standpoint of mounting.
    I am a bit confused OP; in your first post you are talking about swapping rear wheels to get a 8-speed compatible freehub. Then you are talking about a chain in your last post. Can you please clearly list out what all you have so far. As to the cassette tool, a Shimano tool is the one you need:
    Park Tool FR-5C Lockring Remover | Park Tool | Brand | www.PricePoint.com
    Replacing parts on lower end bikes can be v. challenging as many of the drivetrain parts are throw-away (crank doesn't have removable rings, etc.) and hard to find aftermarket. Often, finding used parts will be the way to go or going the upgrade route where in this case you would also replaced the BB-mounted FD for a seat-tube mounted unit but then you start down the road of replacing/spending more than you want.
    To be honest, the cost of the tools in your case will better spent IMHO having someone who knows how this all works to do it because the likelihood is that you will never replace these parts again on this bike and rather will probably get something newer if that time comes again. The newer bike will likely not have the same type of crank/BB (square taper) and these tools won't do you any good.
    I like turtles
    Here is a new crank that will likely work:
    Shimano Alivio FC-M410 Compact Crank Set > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    BB:
    Shimano UN53 Square Taper BB > Components > Drivetrain > Bottom Brackets | Jenson USA Online Bike Shop
    Front derailleur:
    Shimano Deore M590 Oe Front Derailleur > Components > Drivetrain > Front Derailleurs | Jenson USA Online Bike Shop
    Cassette:
    Shimano HG70-I 8 Speed Cassette > Components > Drivetrain > Cassettes | Jenson USA Online Bike Shop
    Chain:
    KMC X8.93 Chain > Components > Drivetrain > Chains | Jenson USA Online Bike Shop
    Toss in another $20 for cables/housing and you are at around $100 + your time and a few tools. Tools would need to be a BB tool, cassette tool, chain tool, and cable/housing cutters.
    Obviously, you really have to know exactly what you need to order stuff online as there are many sizes etc. for the BB and the front derailleur clamp (and whether it is top/bottom pull)...this isn't a rookie job but can be done with some patience.
    Oct 2013
    Wow, that's a dirt cheap FD...and a Deore to boot. For $10, I may just pick that up. I'll go measure the tube in a bit.
    TiGeo, so far this is what I have:
    Original Shimano 3x8 shifters
    Non-original wheel w/7sp freewheel setup
    Brand new takeoff wheel/freehub from the LBS (no cassete)
    Here's what needs to be replaced:
    Crankset (OE is a TruVativ w/non-replaceable chain rings)
    8sp Cassette (don't have one for the new wheel yet)
    Chain
    Shift cables/housings
    Optional replacements:
    BB - not sure about this; there's no play in the current unit
    FD - not required, but would give me more adjustability for the future
    I'm a tinkerer by nature and I have a tendency to hoard tools, but I'll probably hold off on buying any tools aside from a cable cutter and cassette tool until I talk to the LBS about installation.
    I like turtles
    Great decision!
    'Tis but a scratch
    I've read this whole thread and I am confused. I don't see that you are actually having a functional problem. It seems that you discovered it was changed from 3x8 to 3x7. Yes, that is a step in the wrong direction, but if it works, why not just ride it. The fact you got a free wheel seems to be leading you down a path to spend $100-$150 in parts and tools to make that free item work. Is it actually having a problem?
    Oct 2013
    1) It's a crappy wheel
    2) The hub bearings have some play, and probably need to be cleaned and greased
    3) The 7sp freewheel doesn't match the 8sp shifter
    4) The teeth on it are kind of beat up
    5) I already got the new wheel for $40. Couldn't turn that down.
    I could relube the hub, snug it up, limit the RD to the 7 speeds available, and throw on a chain, but I'd still be stuck with a burned out small front chainring that's going to quickly wear a new chain. It would also bug the crap out of me. If it was in really good shape and the crankset was ok, I'd probably run with it. But they're not. Oh well.
    Fat-tired Roadie
    Nov 2007
    Chances are the new crank won't match the existing bottom bracket.
    That's a cheap part, so it's more that it's one more expense to pile on. If you can find a complete crankset, bottom bracket included, it's a non-issue.
    You could hold off on the new crank for a while. Not having a granny ring off-road will be annoying, but you don't need gear ratios that low on the street. Does the chain actually skip when you're in the granny ring?
    Sent from my Nexus 7 using Tapatalk 4
    OP: I see your $80 bike quickly turning into a $300 bike with what you've already bought and what you'll need. Can you find a bike that's better equipped for less than $400 that is complete and working?
    EB1888: What is the purpose of putting superglue into brake housings? I use Jagwire on all my builds and I've never done the process that you describe and have never had any of the issues like shift bind. I also use M739 or M900 shifters. The ferrules that come Jagwire are just fine too. $12 on eBay for Jag cable sets unboxed.
    'Tis but a scratch
    Quote Originally Posted by Starfury View Post
    Now I get it. It does sound like you are in for a full drive train then (cassette, chain, crankset, FD and BB and the cables. It looks like TiGeo has you hooked up.
    I'll also repeat the notion that a set of Jagwire cables/housings is a good investment but you don't NEED to run continuous housings and drill out the cable stops.
    zygote2k: I think the notion of super glue is to go on the cable where you cut it so it won't fray and then get jammed up when threading through the housing. However, usually a brand new cable doesn't have this problem if its threaded first and then cut. I still suspect the glue idea is helpful for that "after threading cut" though.
    Oct 2013
    Quote Originally Posted by AndrwSwitch View Post
    Honestly, I haven't even ridden the bike enough to tell. But the small chain ring is very obviously worn more than the larger two. That said, I do use that low gear ratio on the street. There's quite a few stop signs/lights in between here and school. I also frequently ride with my daughter to her school, and she can't go all that fast on her 16" (wheel) bike.
    zygote2k, I don't see this quite reaching $300, but I have considered your point. Problem is, this is a very street bike-oriented area, with very few mountain bike options aside from what gets dumped from college kids after they graduate. And even if I did find something, I kind of have to assume that anything I pick up in that price range is still going to need some work, and I definitely can't afford anything past that. As is, I'm trying to sneak some of this stuff by the wife. Even looking at a brand new bike from bikesdirect that would need no work, I'd end up with something less-equipped than what I'm looking at putting together with the Giant, and it'd be really hard to sneak a brand new bike under the radar
    Fat-tired Roadie
    Nov 2007
    Re: Drivetrain Recommendations
    Put the brakes on parts you might need until you've actually ridden the bike!
    People get into upgrading their bikes as a hobby. Which is fine, and they can have useful knowledge. But they have a different perspective than you in terms of what constitutes value, and a lot of people get really precious about detail stuff that doesn't really effect function.
    Since the bike is in pieces, start by getting it rolling. It sounds like you're pretty committed to using the new wheel you already bought. So buy an 8-speed cassette and chain and install those. Then re-evaluate. Bear in mind that if the bike could go, stop and shift when you test-rode it (could it? Did you?) it shouldn't need anything else to go, stop and shift now.
    Once you can ride the bike again, look at things effecting reliability in the short term. You don't actually know the granny ring is worn out. You just find it visually unappealing. Maybe you're right, but we haven't reached that bridge yet.
    Fat-tired Roadie
    Nov 2007
    Oh yeah - and post some pictures!
    Oct 2013
    Well, the LBS condemned the crankset, and I can see why upon inspection. Plus, the guy I got it from had the FD locked at the small chainring, so it was getting more wear than any other gear.
    I did test-ride it, but I was focusing more on making sure the shifters worked, none of the bearings had excess play, and there were no cracks in the frame. The brakes need to be adjusted to work properly, but that's no big deal. I'll try to take a couple pics and maybe see if I can put some real torque on on that small chainring this week. In the meantime I can at least get the cassette, chain, shifter cables, and maybe that FD ordered.
    What's the difference between the Z72 chain I've bought previously and that X8.93 chain?
    You know, where you're mostly riding just on the road, unless you've got some really steep hills around, you could always try just forgetting about using the small ring altogether and ride the other two, particularly if you go to a 32 or possibly even a 34 tooth large cog in the rear. Should be fine for what you want to do with it - gets you up and running, doesn't cost a nickel and buys you some time to squirrel a little dough away for future upgrades (or a different bike).
    Oh yeah, and be careful about stomping on that little ring - a bunch of tourque and a chain that slips = a nasty mark on your kneecap that looks like the back of your stem and a lot of cursing.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by zygote2k View Post
    Putting superglue on the ends of the cables keeps them from fraying when inserted into housing or from fraying when you cut the cables. If you thread the cable through the housing before you cut it to length the soldered end will keep things in place just fine. It's only if you have to thread a cable without the soldered end on it that you might want to consider glue.
    OP, I'd keep track of your expenses. You can nearly buy a new bike for the cost of all these fixes.
    Oct 2013
    Adjusted the brakes and shifters today and went for a short ride. Chain does not slip on the small chainring, although I did notice that the outer chainring is a little bent. Didn't seem to affect shifting, but we'll see after I replace the chain and swap the 8sp setup on the bike.
    I did figure out that I really can ride without the first chainring on the street. It's geared really low. My older Trek 820 is geared completely different, with wider spacing between gears and a higher overall gearing, but the Giant is just annoyingly slow on the small chainring, and at max gearing (3rd/7th) it leaves me wishing I had another gear to switch to.
    I did verify that I have a 34.9mm seat tube, which is compatible with that Deore M590 shifter. Considering that, and the rather low gearing of the bike, I think the plan now is:
    Swap the new wheel on the back with a new 8sp cassette and chain, replace the shift cables/housings, buy the FD (because it's $10) and save up a bit for a new crankset/BB.
    Fat-tired Roadie
    Nov 2007
    You're going to get a much higher gear with the cassette. It's a ratio thing. So going from a 13 or 14 tooth smallest cog to an 11 is a big deal.
    Sounds like a good deal if lined and with stainless coated cables.
    In the REI kit you get a shifter connector blob at each end road or mt. Put the super glue on the area near the end you have to cut off to be able to thread the cable through the housing. Then put a drop on the cleanly cut end and round it carefully by rubbibg it on some fine sandpaper and re glue.
    Why?
    The lining in the housing is part of what you are paying for. You want the full performance for the longest time. A sharp cable end can damage it. The effort to avoid that is minimal. Add a little silicone lubricant and feed the cable slowly through. Use enough housing to have big non binding loops at each end. Tighten the cable at the derailleur. Reglue and make the final cut and add a drop of glue to the end. Check that your derailleur hanger isn't bent OR twisted. Ride and shift. You will never choose a different setup.
    Is it necessary? No. Will you notice the higher level of performance even from lower level components? Yes.
    Minimal effort and cost--significant performance improvement you will feel every ride. Works for me.
    Picture Unrelated
    Jun 2005
    New cables rarely benefit from lubrication due to the lining of the housings. Lube attracts and holds dirt and dust which will cause the cables to behave poorly more quickly. If you insist on a lubricant on your cables a very light oil is ok or Shimano Special Grease SP41 are your best bets. Of course SP41 costs a fortune but it works like nothing else.
    Reputation: J.B. Weld's Avatar
    [QUOTE=zebrahum;10883935Shimano Special Grease SP41 are your best bets. Of course SP41 costs a fortune but it works like nothing else.[/QUOTE]
    But the tiniest of dabs will do, one of those micro-tubs could last decades.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by J.B. Weld View Post
    I know, but it's hard to recommend a $30+ tube of grease to anyone.
    I like it.
    Make sure you get the correct FD for your bike - there are variations in where they articulate from and which direction the cable is supposed to be pulling from - ie top-swing/bottom-swing and top-pull/bottom pull. Some derailleurs can swap between top and bottom pull set-ups, but 'swing' isn't configurable at all AFAIK.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  1. Drivetrain Q's. X-Post from Drivetrain
    By Harold in forum Commuting
    Last Post: 08-29-2013, 01:58 PM
  2. SRAM Grip Shifters on Shimano Drivetrain & SRAM Drivetrain....
    By Dragon Of The East in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-24-2012, 07:47 PM
  3. Another drivetrain question- drivetrain noise
    By Streetdoctor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2012, 01:50 PM
  4. Recommendations on a drivetrain for a dirt jumper ?
    By Soccersmitty55 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2011, 02:13 AM
  5. Drivetrain issues - please help - x post from Drivetrain
    By yohyat in forum Downhill - Freeride
    Last Post: 01-03-2011, 08:30 AM
