    Dec 2012
    Does stanchion size affect head angle when all else is equal?
    On the geometry spec-sheet Yeti lists different head angles for the 32 and 34 stanchion forks at the same length. Specifically they state that a 32 stanchion 150mm travel fork results in a 67 degree head angle while a 34 stanchion 150mm travel fork results in a 66.7 degree angle...
    What gives?...
    29er
    a to c is different
    Sep 2012
    Quote Originally Posted by Dan GSR View Post
    a to c is different
    Right! ...because different forks use different crowns, which affects the axle to crown distance.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by shibiwan View Post
    Which means 34 has an A-C that is about 5mm longer.
    ninjo, the difference is not directly because of the larger diameter stanchions but other design differences.
    mtbtires.com
