Results 1 to 2 of 2
    Does being 'light weight' means I can't do well in time trial?
    Well this is not exactly about MTB.
    I realise that I couldn't time trial very well on the flat but I can climb relatively well compared to people of my field.
    My estimated FTP is 200w, 56kg. That makes around 3.57w/kg. The FTP is just an estimation, not exact value. But it shouldn't be too far off.
    I believe a 200w FTP is relatively low but if being able to time trial on the flat rely more of FTP than W/kg, does that mean that it would be much harder to power on the flat compared to the bigger guys of the same W/kg as me?
    Thanks in advance
    Fat-tired Roadie
    Nov 2007
    LOL. Try the XC racing and training forum for this sort of thing if you must post it on a MTB site.
    That said, your answer is mostly right there in that jumble of numbers you posted. If a big dude has the same watts per kilo as you, multiply that stat by his weight and you'll see why it's going to be hard for you to compete in a flat TT.
    Bear in mind that at high speeds, the opposing force is mostly air resistance. Your larger opponents push more air than you, but it doesn't go up linearly, so probably not much more air. At low speeds on a climb, the opposing force is gravity and the problem becomes W/kg. Since road races are still relatively fast on a climb, air drag still plays a role. Which is part of why predicting race outcomes from people's power numbers doesn't really work.
    If you're racing off-road, it's never very fast or very flat. So no excuses.
  1. Yankee Springs TIme Trial
    By pattongb in forum XC Racing and Training
    Last Post: 04-11-2012, 07:31 PM
  2. Need help interpreting my time trial results
    By ak57 in forum XC Racing and Training
    Last Post: 12-15-2011, 05:22 PM
  3. Virginia Key MTB Time Trial!! Oct 9th!
    By Thameth in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 09-29-2011, 10:35 PM
  4. PMP Super-D(ish) time trial course
    By Blatant in forum Arizona
    Last Post: 08-03-2011, 10:29 PM
  5. Time Crunched Cyclist 8min Time Trial--which HR should I use?
    By Okie Dokie in forum XC Racing and Training
    Last Post: 03-29-2011, 10:10 AM
