Results 1 to 3 of 3
    Jun 2014
    Do Suntour Coil Forks Squeak?
    I have a very intermittent, high pitched squeak or squeal coming from the front of my bike somewhere. I hear it most often on the trail, but hear it on occasion on the road. It's so intermittent that it is hard to pinpoint, but does seem to happen on things that make the fork displace. On the road it is less frequent and the fork is locked out.
    Am I right in blaming the fork? Pretty certain it isnt wheel related as it isn't regular. It doesn't seem to be coming from crank or bottom bracket either.
    Just kind of curious.
    Thanks in advance.
    Also check if the rotor is a little bent and is hitting the pads.
    When you hear on trail lightly apply the brake to see any effect.
    Bounce on the front to see anything more from the fork.
    I wouldn't expect a finely engineered product with military grade tolerances between the stanchions and the plastic bushings would allow a tiny particle of dusk to intrude. Possibly wiping the stanchions and lubing with silicone spray lube would help flush the areas clean.
    Jun 2014
    I really don't think it's brake, it's too intermittent.
    I'm thinking either fork or headset, possibly front hub? I really think its the fork though, it is most prevalent during high frequency low amplitude rocky type stuff.
  1. Suntour Raidon Air vs RS XC 32 Coil
    By jpricewood in forum Shocks and Suspension
    Last Post: 07-02-2013, 12:44 PM
  2. CCDB Coil Squeak
    By Doba in forum Shocks and Suspension
    Last Post: 05-17-2013, 01:22 PM
  3. SR Suntour Forks
    By Kona0197 in forum General Discussion
    Last Post: 03-19-2012, 04:30 PM
  4. Curnutt coil shock rebound "squeak"?
    By creyc in forum Foes
    Last Post: 02-05-2012, 11:06 AM
  5. Suntour XCM, how to change to softer coil?
    By Urbansniper in forum Shocks and Suspension
    Last Post: 01-12-2012, 07:25 PM
