Results 1 to 10 of 10
    Do I Need a Shock Pump?
    I recently bought a 2008 Specialized Rockhopper, front suspension only. Do I need a shock pump? I'm not exactly sure what they're used for. Thanks!
    Shock pumps are for shocks that use air pressure as the spring. The base rockhopper uses the Dark 3 fork, which has a coil spring. No shock pump is needed.
    The Rockhopper comp which has a Tora 302, uses a coil spring and air, so you will need a shock pump.
    The Rockhopper pro has the Recon Race fork which I think also uses a coil spring and air.
    I rode my RockShox Duke XC for 6 years before it ever saw a shock pump. If you get periodic tune-ups from your LBS, don't sweat it. Save your money for something more worthwhile. Shocks are mostly just bling anyway, although they will reduce arm and shoulder fatigue on REALLY long rides. If you race, you might shave a few seconds as well. Otherwise, they're just a tried and true way to part you from your money.
    Reputation: ussprinceton2004's Avatar
    no need for a shock pump, unless you decide to replace your fork to one that needs it
    Wouldn't a normal floor pump work as long as it could reach the maximum pressure?
    I have a Tora 318 SL air.
    Dirt Deviant
    Reputation: savagemann's Avatar
    Quote Originally Posted by tduro
    Have you ever ridden a bike with good shocks?
    I've hit stuff on my bike that would most likely have snapped the frame or fork of a bike that was rigid.
    To the OP...........What fork is on your bike, and which model RH did you get?
    If it is indeed an air fork you should get a shock pump.
    Look, whatever happens, don't fight the mountain.
    Reputation: Langdog's Avatar
    Yes, a floor pump will work
    ...BUT...
    shock pumps are designed to output high pressure in low volume increments. These smaller increments allow more precise and accurate control of the pressure you're using in the fork and fine-tuning the ride quality/spring rate is more repeatable when using a shock pump. If price is a concern when purchasing the pump, look here:http://www.pricepoint.com/detail/162...Shock-Pump.htm
    This is a nice product that I personally own that works well for both air-sprung forks and rear shocks. Before I purchased the shock pump, I went to an auto parts store and bought a schraeder valve extender and threaded it onto the air valve and used a floor pump. It worked fine, but is not the correct method.
    "What Would Doug Do?"
    bi-winning
    Reputation: rkj__'s Avatar
    I don't agree with your post. :-)
    Dirt Deviant
    Quote Originally Posted by Langdog
    Funny, thats what I did to get my RS SID pumped up before I had a shock pump. Bought a 4 pack of the chrome valve extenders for $2.....= )
    Quote Originally Posted by savagemann
    I guess great minds think alike...but I do have a shock pump now.
