Results 1 to 11 of 11
    Reputation: beecrazy's Avatar
    New question here. Do I Need A New Fork? noob
    Hello All
    Just starting MTBing this year- havn't really rode for 20 or so years! Any who, I just picked up a 2000 GT Rebound early this summer, it has a Rock Shox Judy XC on it.
    When I use the front brake (linear pull) the front shock shudders.
    There is no feel of play in the stanchions, I took the fork apart partially and the bushings look good and feel good- put in new 5 weight oil.
    I cleaned up the wheel where the brake pads ride ( not sure if I did it correctly) thinking it is more of brake issue causing the fork to vibrate/shudder front to back.
    Any input would be appretiated
    Don
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Seems like you're in the right area. Did you try to scuff the pads also?
    There....Are... Four...Lights!
    Good call! I havn't touched the pads. I did scotch brite the wheel, and that changes it but didn't eliminate it.
    I will have to hit the wheel one more time and scuff the pads to see if that helps!
    Don
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    did you check that the headset is not loose
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: fireball_jones's Avatar
    I would guess it's the headset or the wheel is bent or you have loose spokes before thinking it's the fork.
    The head set does not have any play that I can feel, I could always tighten it up a hair, it was a little loose when I purchased the bike... how much preload should there be?? Is there a torque spec on the headset (it is thread less)?
    The wheel is true, and the spokes do not feel loose. Unless they are all a hair loose? I haven't put a dial indicator on the wheel but I would guess less than .020".
    How true is considered true?
    I am mechanically inclined- so working on it isn't a problem, just new to the bike thing- when I was a kid I was the neighborhood bike mechanic
    Thank you guys for all your input- I will play with it and let you know
    Don
    i also unicycle
    headset or slightly loose hub were my two choices if the work itself isn't flexing.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    Update
    Just finished tinkering with the bike- it is much better but I can't fully tell until I ride it in the sun light!
    I tighened the headset ( for the third time since the beginning of the summer); I tighened the spokes and trued the wheel ( probably has less than .005" lateral runout); I scuffed the brake pads on some 80 grit and scuffed the wheel with a scotch brite pad.
    I think the headset was the biggest thing- even though I felt no lash, the leverage couldn't be duplicated by hand. I may take the headset apart and regrease the bearings and readjust.
    When I first purchased the bike the front wheel wasn't tightened all the way- good call on checking that too!
    Thank you to all those who gave advice
    I will try it tomorrow (weather permitting) to see how she does!!!
    Don
    Huckin' trails
    Reputation: David C's Avatar
    Check if the v-brake posts are not too loose on the fork's v-brake studs... I did ride my RS Dart 2 with v-brakes and was kinda hard on them and the v-brake themselves start having play, but the studs are ok... They should have a little play anyway, but if you brake suddenly and heard a "clank", then it might be the brake arms that are getting loose... Just have to change them.
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Update
    Udate
    Whoops- musta hit wrong button
    The shudder is probably half or so gone
    I took the headset apart last night and cleaned and greased the bearings and adjust the headset.
    There must be just a little play that I can't feel in the fork bushings/ something going on with the wheel brake pad surface causing the shudder. At least it does it at higher speeds instead of all the time.
    I will continue messing with it and keep all updated.
    Thanks again for all the input
    Don
  1. New Fork, Noob needs help
    By pattongb in forum Shocks and Suspension
    Last Post: 08-13-2011, 08:08 AM
  2. Noob Fork Help
    By 08HardRock in forum Shocks and Suspension
    Last Post: 08-08-2008, 05:59 PM
  3. How to buy a fork? Noob.
    By spidron in forum Shocks and Suspension
    Last Post: 10-28-2006, 06:13 AM
  4. help a fork noob out
    By mondaycurse in forum Shocks and Suspension
    Last Post: 02-26-2006, 10:02 AM
  5. Noob ? about my fork...
    By LukeTX04 in forum Shocks and Suspension
    Last Post: 12-28-2005, 10:54 AM
