Results 1 to 5 of 5
    Nov 2013
    Do not answer. I asked this question twice
    Disregard. do not answer. I asked this question twice.
    Reputation: J.B. Weld's Avatar
    [QUOTE=alaskadude;10844811
    THIS FROM SURLY:
    Since Surly frames are faced prior to painting, it is possible to shave the paint off the head tube and BB shell ends with a carpet knife blade. This usually results in an acceptable result, saving you money, but we still recommend having it done the proper way to ensure longest life from your components.[/QUOTE]
    This statement seems reasonable to me. Personally I'd do it as long as I had handy access to a tool but I wouldn't worry about it if it didn't get done either.
    Fat-tired Roadie
    Nov 2007
    I think it's more important for the head tube. Given what they say, I think removing the paint would be enough for me. If you have easy access to the right tools, facing off the paint is likely to be easier.
    Dec 2010
    I've built up a few Surly frames, and I'd suggest doing it. At the least use a razor blade and some fine grit sandpaper on a wooden block to get it down to the metal again. If you have the ability to do it or have it done, do it before building your frame up. It's much easier to bring a frame to the shop, and a lot less work if you haven't already built it up.
    I personally would let the shop hit it, if you've got a decent one nearby. I do almost everything on my bikes at home, but facing is one of the few things I leave to the guys with the right tools. I just consider it part of the deal with a new frame.
  1. Tool to face Surly fork brake bracket
    By dvzzz in forum Tooltime
    Last Post: 12-03-2013, 09:36 AM
  2. How do you remove this Race Face BB30 bottom bracket adaptor?
    By spunkmtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2013, 03:04 PM
  3. Substitute Bottom Bracket for Race Face Evolve
    By jscot111 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2012, 01:35 PM
  4. Replies: 10
    Last Post: 01-27-2012, 10:47 AM
  5. Race Face X-type bottom bracket replacement
    By adrianfleming in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2011, 03:45 AM
