Results 1 to 7 of 7
Thread: Disk off center
    Reputation: henmar77's Avatar
    Jun 2012
    Disk off center
    I was installing new pads on the new wheels I have mavic crossed. I have deore zr brakes. I noticed that the disc is not center in the opening. It doesn't hit but I'm assuming this is going to cause lopsided brake wear. How do fix this, does it need to be shimmed?
    Sent from my PC36100 using Tapatalk 2
    GT FORCE 1.0
    Suck it!
    What day are we riding?
    Reputation: Rockin's Avatar
    Did the wheel get seated all the way in the dropouts? Pics might help the explanation.
    Jun 2012
    Well when it was fully seated that's when the disc wasn't centered. I offset it slightly without the wheel being cocked to much that it wasn't pointing straight and that fixed it. So what does that mean? Something else is wrong?
    GT FORCE 1.0
    Suck it!
    I have noticed the disc position between brake pads can vary with how much I turned (or not) the QR nut.
    Sent from my MB865 using Tapatalk 2
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '99 Spec' FSR Comp
    '9x Spec' Hardrock Cromo rigid
    B A N N E D
    Quote Originally Posted by henmar77 View Post
    You should have the axle fully seated in the drop out.
    Some hubs are slightly different with their specs, one brand of hub might give you rub and another brand won't.
    I'd say your brake calipers need realigning.
    ****** to the dirt
    Quote Originally Posted by zephxiii View Post
    Does it very when the axle is completely seated or when you have offset it?
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    There's play in the mounting holes on the caliper. Loosen the caliper only enough so you can move it side to side, apply the brake, and then tighten (while holding the brake on). If your pistons are both working and not sticking this should center the caliper on the rotor.
