Results 1 to 27 of 27
    Aug 2013
    Bonking ... not feelin' well Disc Breaks Squeeking
    My disc brakes have started making a strange squeaking noises when I brake, at first it was only the rear, 10 mins later both!
    I have been doing some harsh breaking today but my brakes are only a couple of months old...
    my breaks are avid elixir 5 hydraulic.
    After a quick search I came across someone advising it could be brake callipers mis-aligned, but didn't explain any further.
    Anyone have any ideas? Thanks in advance
    Sep 2012
    Squealing is common, especially if you did not bed your brakes in properly and I also see you have Avids which are known to squeal regardless. Try a product called Squeal Out, it is a compound that you put on and re-bed your brakes with. Worked for me!
    Jan 2009
    brake, not break!
    Aug 2013
    Thanks for that...
    SLX are the cost effective choice. Here's a front for $60.
    BlueSkyCycling.com - Shimano SLX M666 Disc Brake w/ Adapter
    Aug 2013
    Thanks but not looking to replace my brakes after only 2 months old, just looking to fix the problem.
    Jan 2009
    there are several reasons for disc brake squeal/squeak/warble/etc. I could list them all, but there are dozens of threads and websites dedicated to this question that you can find on your own. a few minutes of reading will probably answer your question. I probably sound like a jerk, but your question and been asked, discussed, and thoroughly answered dozens of times. i have some suggestions, but I would be wasting my time typing something that has already been discussed ad nauseam. please take the time to do a little research.
    start in the "brake time" forum. here's a good thread to start- The Juicy brake turkey warble/vibration MEGA THREAD
    Fat-tired Roadie
    Nov 2007
    Did they get wet? Are they still performing well?
    Aug 2013
    Nope they didn't get wet, and yes they are performing fine. The noise sounds as though the discs are wobbly or uneven but they are also fine
    Reputation: Shakester's Avatar
    Jun 2012
    Does the brake make a humming squeaky sound? Did you lube your bike up lately or touch the rotors with your bare hand? There are so many reasons why a bike's brake will squeak, but getting lube or any kind of oil, even from your fingers, on the rotors is pretty common and that will contaminate your pads. You can replace your pads, but before you do that, give your rotors a thorough cleaning with IPA.
    Aug 2013
    Yes I lubed the chain and few other parts. Probably touched the disc as well. I'll give them a clean later with alcohol wipes, can I clean the pads with anything or will they have to be replaced now?
    Thanks for the relies
    Jan 2009
    Quote Originally Posted by Shakester View Post
    I prefer Dogfish Head 120 minute, but Sierra Nevada works well too.
    Jun 2012
    Quote Originally Posted by SCO7TY View Post
    I usually like to just replace them. I keep a few extra sets around, but I've heard of people using super fine sandpaper to clean the pads.
    Aug 2013
    Thanks a lot, probably just buy some new but for now I'll give the rotors a good clean
    May 2013
    Quote Originally Posted by mack_turtle View Post
    Yeah, I thought that was a rather unique use for an India Pale Ale. They don't sell Dogfish Head where I live, though. . .sucks!
    Don't listen to me. I'm too new to have an opinion yet.
    Reputation: MSU Alum's Avatar
    Rubbing alcohol on a wash cloth "flossed" between the pads will get a lot of brake dust and contaminates off. That, and making sure they are properly aligned should help.
    Here's "Wolverine" explaining how it's done on Youtube. Adjusting Disc Brake Calipers - YouTube
    Fat-tired Roadie
    Nov 2007
    Re: Disc Breaks Squeeking
    Disc brakes sometimes make noise. So do Vs and cantilevers. I wouldn't spend money or much time on it.
    Quote Originally Posted by eb1888 View Post
    For Avids that is most likely the fix.
    What type of bike? Search the Specialized forum, you'll find tons of threads about the Avids and noisy brakes, most of the time the fix is another brand.
    OG Ripley v2
    Carver 420 TI
    Jun 2012
    If a good cleaning and it still squeaks, maybe swapping out the pads ($15 a set) and see if it that helps. Possibly switch from the metallic to an organic.
    Jan 2011
    try checking the alignment. I had a similar problem with shimano hydraulic disk brakes. Finally, it turned out brake pads were not aligned properly. turn the tyre and observe if the pads are touching rotor.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    I love my disc breaks. I turn up the volume on my disc player and take a nice loud break from the ol routine.
    Oct 2013
    Heat the pads after cleaning on a frying pan(yes fry the pads)
    . It'll burn up the oil that may have stuck to your pads... it works
    Jan 2011
    fixing the alignment issue of the brake pads solved the squealing issue for me.
    Aug 2013
    Not had chance to have a look yet, will most likely give a few of these suggestions a go tomorrow
    Sep 2012
    Try the squeal out I mentioned in my post above.. My Maguras were gobbling like turkeys after a month on my most recent bike so I ordered some and followed the directions. For almost a year now my brakes have hardly made a peep. Avids may be notorious for the gobble but its worth a shot. A tiny bit goes a long way so order the smallest size.
    Squeal Out
    I have avids and mine made a horrible noise after doing some work on the bike. Cleaning the discs with alcohol and aligning the calipers got rid of the noise. If you don't already know how to align them, the method I used is to loosen the mounting bolts to the caliper, then tighten the mounting bolts while holding the brake lever.
    Jan 2009
    time for a brake break. I think I might to a break dance to brake the broke brake and break up the brokeness of your brake break.
    most people never face the tabs and post mounts on their frame/fork. even with the convex/concave washers used to mount most brakes, it's hard to get them really straight. getting your tabs/posts faced will help a lot with getting the pistons to hit the rotor squarely. look into getting your tabs and posts faced. if it's a relatively new bike, the shop where you bought it should take care of this for you, as they should have done it before the bike was even put on the sales floor.
    also, pistons often stick inside the caliper, causing a lot of noise and lousy braking. look into cleaning and lubing your pistons.
    finally, if you have Avid brakes you are not the first to discover that the SUCK. get some Shimanos. if the bike is still so new, see if the bike shop will get you some sort of credit for an upgrade.
  1. squeeking noise from pivot on 2011 superlight
    By ernie00 in forum Santa Cruz
    Last Post: 06-13-2012, 10:27 PM
  2. Washed my bike. Now disc breaks are squealing
    By Gregdpw in forum Brake Time
    Last Post: 04-19-2012, 09:04 AM
  3. Squeeking Brakes...???
    By bowler1 in forum Brake Time
    Last Post: 01-18-2012, 05:16 PM
  4. New to hydro disc breaks?
    By wesleyjoejimbob in forum General Discussion
    Last Post: 12-16-2011, 05:56 PM
  5. What Happens When a Zip Tie Breaks?
    By FNFAL in forum Passion
    Last Post: 08-18-2011, 08:15 AM
