Page 1 of 2 12 LastLast
Results 1 to 100 of 142
    Disc Brake Problems
    Hi all,
    Well I am officially fed up with my new Trek's brakes. Please see the message I sent the Trek's customer service via online submission. I'm beginning to think that my brake pads were never really the problem, just that the type of disc brakes I have (promax) suck. I am open to any suggestion to getting this taken care of. AND PLEASE, SPARE ME THE WHOLE YOU GET WHAT YOU PAID FOR. That is complete BS in regards my particular case. A bike from Trek should be able to lock up (brakes). I only weigh 165 for crying out loud. Thank you all in advance for your suggestions.
    Hello Trek,
    I bought my Trek 3900 Disc 2010 about one month ago from ******* Bike Shop in ********, CA. Ever since then, I have had problems with my disc brakes. The stopping power on the front & back of the bike is unacceptable considering it is coming from Trek. The first time I took the bike out, the brakes would not lock up. I figured that this was simply the brake pads needing to be bedded. However, after a number of other rides, they did not improve. I was told that I had gotten lube/oil on the brake pads and that I would need new ones. Therefore, I cleaned the rotors and cleaned the calipers. That only helped the back brakes a little bit. At least now they would lock up. However, the front brakes were a different story. I then purchased a set of brake pads for my front disc brakes at the cost of $17.99, because ******** Bike Shop recommended I do so. I installed those on the front disc brakes, but it did not fix the problem. The staff at ******** checked that the brakes were adjusted correctly and even rode the bike and tested the front brakes. They were shocked at the poor stopping power of the front brakes (and even the back brakes to a smaller extent). I spoke with the Manager, *****, and he told me that the problem is to be expected from a "under $600.00 bike. However, when I asked him to get one of the specialized bikes that was around the same price as my Trek, the brakes on the Specialized worked AMAZING. I did not appreciate how the manager, *****, made me feel that it was because I purchased a low-end bike. He said he would start the warranty claim process with Trek. In conclusion, I am very disappointed with my purchase. I have spent $20.00 buying one set of disc brake pads (which I likely never really needed). I have also spent much time driving back & forth from my home to the bike shop trying to get the issue resolved. I have not been able to enjoy my bike riding experience. I feel as if the bike shop was not honest in telling me that the real reason the brakes were not functioning correctly was due to the poor quality of the brake components. They have admitted that the current brakes on the bike do not provide adequate stopping power and I wonder why I was not warned before I purchased the bike. I bought a Trek bike from an authorized dealer for a reason: To buy a good quality bike. I would appreciate if Trek would help me become happy with my purchase because I am starting to regret it. My phone number is *****************************
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    so your justification of power is the ability to 'lock up' you wheel? did you go over a cliff because your braking p0wer was not good enough?
    you are asking for suggestions? im not sure what this whole rant is about...
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Quote Originally Posted by DriveByBikeShooting
    What are you asking, driveby?
    Yes, I want my brand new disc brakes to lock up the wheel with me on it just like a specialized bike around the same price would.
    Yes, I am asking for a suggestion as to how to get brakes that work properly!!!
    just wondering if the shop had another 3900 that you or they can try to see if it does the same thing as your bike. maybe it was just the brakes on your bike that were defective.
    2000 something DB Sorrento
    2010 Motobecane 29Pro SL
    Quote Originally Posted by bRyAZSig228
    funny you mention that. i went to another bike shop that had some of the exact bikes in. those brakes sucked to. Actually, the manager of that shop said that he was irritated at Trek for providing such shitty brakes.
    Feb 2010
    Must be a bad batch, my TREK 8500 brakes are biting real good.
    newless cluebie
    It could be expectations.
    You mentioned you hit the brakes on a Specialized in the same shop and was able to brake just fine? You didn't mention if those were also Promax mechanical discs. You very well could've grabbed a Specialized Rockhopper Comp Disc with the Avid BB5 mechanical discs. That's a very important distinction. Avid mechanical disc brakes are considered some of the best on the market... whereas Promax, not so much.
    Yes, you get what you pay for. Promax mechanical disc brakes are just about the chintziest, cheapest mechanical disc brakes you can buy. To be honest, linear pull v-brakes at that pricepoint are going to be a better buy. Promax does make decent hydraulic disc brakes though.
    How to adjust for best bite for what you have? I'm guessing those Promax calipers only have one moving piston. I'd adjust the caliper position on your fork so that the pad that doesn't move is as close to the disc as possible without rubbing. Also, you may want to check your brake levers to see if they're adjustable from a ramped-pull (old style) to linear-pull (new style). The difference is the amount of cable that moves when you pull on the lever. The Promax discs may require one over the other to operate correctly, and depending on the levers, yours may be set incorrectly.
    Shooter: Your 8500 is also a $2000+ MSRP bike, with hydraulic discs.
    EDIT: I took a look at ProMax's site; if you have the DSK-720 model mech disc calipers, you don't have to adjust the whole caliper, you can adjust the inboard brake pad using a knob.
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Pro max disk brakes are the absolutly worst disks on the market! Stopping power is marginal at best! May actually be unsafe in certan circumstances. I'd bite the bullet and get a set of BB7s and you should have some good stoppers! Sorry about your Wally world brakes!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    Quote Originally Posted by shooter26
    The brakes on your 8500 are totally different then those on the 3 series. They are even different then the BB5's I have on my 6000.
    Quote Originally Posted by ae111black
    LOL!!! And to think...I was buying at a LBS to avoid the Wally world, Target, Costco, cheap components. Complete and utter BS!
    I actually going to push until the brakes work the way they were advertised to work. when I bought the bike, I told the salesman EXACTLY what I wanted to do with it. He talked up and down about how good the 3900 disc brakes would be over V-brakes and how they would be more reliable. How am I, a beginner, supposed to walk into a bike shop knowing that he is telling me a load of BS? Its also complete BS that store manager said he would get the warranty involved and that he HOPED that Trek would send better brakes and not the same ones. He even admitted that if they sent the same ones, I would likely have the same problem! Well, I talked to the manager, wrote Trek, and contacted American Express. You guys should see the riding I do....nothing extreme....just light-medium trail riding. Dude! The way this thing stops...I wouldn't feel comfortable riding it through the streets of San Diego. Garbage truck....ohhhh **** I can't stop! WHAM!!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Throw a set of BB7"s on it and be done with it .
    MTB skillz = NADA
    Reputation: GrayBeard Pirate's Avatar
    Dec 2009
    Quote Originally Posted by oceanfirehawk
    You bought a bike looking for brakes better than V-brakes, but didn't spend a bunch of money for top of the line stuff. I imagine you got what you asked for, but you are just not happy with it. I would just buy some higher quality brakes and be done with it if I were you.
    Put it this way, I just bought a new bike and it came with Tektro Hydro brakes. I do not expect them to work like Elixirs. I expect them to act like low level Hydro brakes, and when I am ready to upgrade to something better...I will.
    Since I don't like writing, I don't have a blog to pimp. This space for rent.
    To me it sounds like your complaint is with the sales rep at the bike store so not sure why this would be Treks fault. I'm also not sure why you want to be able to lock up the brakes. I have close to a thousand miles on my bike and never locked them up once. Do the brakes you have now stop quickly without locking up? Keep in mind cars went to ABS so the tires don't lock up. You keep control and less stopping distance.
    I agree with others though. I would take it up with the bike store or buy some BB7's and just install them.
    Umm did you not take the bike for a test ride and feel that the brakes were crap? Sounds to me like you have steak tastes on a hot dog budget. What did you want the sales guy to tell you when you are testing a 600 dollar bike. Ofcourse he'll tell you the brakes are good. They are good for a cheap bike. To me it's buyer beware. You bought a bike either without testing the brakes or not knowing any better. Sounds to me like you made a mistake.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    ............................................______ __
    ..............?.....__............................ .............:`.........../
    ............./__.(....."~-,_..............................,:`........../
    .........../(_...."~,_........"~,_....................,:`..... ..._/
    ..........{.._$;_......"=,_......."-,_.......,.-~-,},.~";/....}
    ...........((.....*~_......."=-._......";,,./`..../"............../
    ...,,,___.\`~,......"~.,....................`..... }............../
    ............(....`=-,,.......`........................(......;_,,-"
    .............\`~.*-,.....................................|,./.....\,__
    ,,_..........}.>-._\...................................|........... ...`=~-,
    .....`=~-,_\_......`\,.................................\
    ................................`:,,.............. .............`\..............__
    ........................................_\........ ..._,-%.......`\
    ...................................,<`.._|_,-&``................`
    Honestly... ahh I give up
    Professional Speed Bump
    Reputation: captainjoon's Avatar
    This is the LBS's responsibility as well as the manufacturer's. All brakes, even V-brakes should be able to lock up and skid the tires or endo at full grip. If the brakes don't lock up, that's a bad design or faulty brakes.
    If a customer comes back and says that the brakes aren't working properly, the LBS can't say "Oh, that's because they're cheap brakes..."
    WTF.
    If the bike was purchased recently, the LBS should do their best to help the customer with a solution...whether it's trying to resolve the issue with the manufacturer or offering a trade in for the brakeset or even offering an exchange for the bike if it's still in the condition that was delivered in.
    newless cluebie
    I did offer some suggestions on making it stop better. Ignoring it and concentrating on whining won't do you much good.
    Quote Originally Posted by timberstone
    Ok. First off, I am coming from a business standpoint. Second, no the brakes do not stop quickly without locking up. I have had a number of techs and the manager at the store ride the bike and they have all agreed that the brakes are adjusted correctly but the brakes have crappy stopping power. My issue with Trek is that they are putting a disc brake system on the 3900 that isnt even good enough to ride down a street with traffic.
    I am not going to purchase bb7s at my expense guys. The brakes should work. I guess I am viewing the issue from the standpoint of good, ethical business. I think some of the guys here are maybe Bike Shop employees or owners.
    Quote Originally Posted by superflychief
    You are making a lot of assumptions here superfly.
    First off: I did test the bike. The brakes were the same way they are now but the salesman told me that it would take a couple rides to break in the brakes...and THEN they would stop excellent.
    You obviously have zero business sense. Take that coming from a business school grad with years of experience in the hospitality industry.
    Quote Originally Posted by captainjoon
    WTF.
    EXACTLY!!! WTF!!!!!!!!!!!!!!!!!!!!!!!!!!
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I worked on a bike last summer having Promax brakes. Those brakes were so terrible, I almost couldn't bring myself to put them back on the bike. They don't really stop you. They just sorta slow you down, sort of. I came awfully close to buying the kid whose bike I was rebuilding a set of BB5s from my own pocket. Yes, those Promax brakes were really that bad.
    OP, can you afford to spend maybe $70? If so, then go on eBay and grab a set of Avid BB5s. Here's a link to a pair:
    http://cgi.ebay.com/New-2010-Avid-BB...ht_5259wt_1050
    You might be able to get a set cheaper, especially if you watch for a used set. People often sell off their old BB5s when upgrading.
    Don't even waste your time on those Promax brakes. Just toss 'em.
    I Have Cookies
    Dec 2008
    The fact that you bought the absolute bottom of the barrel bike @ a LBS is your own fault.... some research should have been done on your part on the spec's of the bike you got.... just because it was purchased @ an LBS doesn't mean the parts on it would not be sub-par. the reason Trek put those on that price point bike is that their are CHEAP! bottom line!!! It would be like ford selling a mustang with the brakes of an escort on them, SURE they will stop the car but they were alot "cheaper to spec out" on the car. Same goes for Trek. That's Why IMHO avoid the really lower end bikes spec ed out with what looks like "higher end" components! The manufacturer has to skimp somewhere to give the bike that price. Better to do it right the first time, Saves money in the long run!! As for getting them to work correctly....HUH Good luck! Sure fire way to PISS OFF the guy's @ your LBS!!!
    +1 on My and AZMountans advice.... Bite the bullet and get the bb7's yourself. LESSON LEARNED!
    ____
    Kimo
    Reputation: traffic002's Avatar
    Dec 2008
    Seems like if the LBS knew the brakes performed poorly new but would improve with usage and they have verified the brakes are still performing poorly, then a good LBS would sell you a set of BB5s at cost or significant discount and install them for you.
    I have BB5s on my 29-er and they work quite well; especially for its price.
    Just get out and ride!
    Enthusiast
    I'm not so sure that I agree. How many times on these forums do we refer posters to an LBS specifically because we want them to buy a bike that is up to par? If a bike shop sells sub-par material, or provides no guidance to help purchasers avoid sub-par models, then where's the advantage of a bike shop over the discount store?
    Sadly, as the dropping dollar makes imported bike parts ever more expensive, I'm seeing increasingly low end and disappointing parts on bike-shop bikes. Companies like Trek are probably between a rock and a hard place. They are under pressure to hit price-points that are increasingly difficult to hit with good parts.
    Dec 2008
    FWIW, on a $600 bike, I DO expect the brakes to be powerful enough for all but long downhill riding.
    ha ha ha what the hell does business sense have to do with anything? It doesn't take a couple of rides to bed in new brakes. I can get a set up to 100% stopping power in a few minutes. If they aren't grabbing hard after a couple of min. then they are junk. Would you buy a car off the showroom floor that didn't stop well and the sales guy said, oh it will stop better after a few hundred km's. Just keep it under 50. ha ha ha Don't be angry with me that you bought a cheap bike.
    Reputation: Noobi-Wan Kenobi's Avatar
    Maybe you should have tested several bikes before you bought this one. And, by comparison, if this one's brakes were not good enough for you............then you should have addressed the problem with the LBS or just bought something else. Making sure everything feels right is the reason we should try to test ride before we buy.
    Originally Posted by Vtolds/Dremer03---- "assume any bikes left unlocked and unattended are free to take"
    Quote Originally Posted by traffic002
    I would love if they did that for me. However, last night they did not offer that as an option. They pretty much said thats the way the brakes are and we will try to file with trek's warranty.
    Dec 2008
    To keep you riding without feeling like you'll slam into a tree because you couldn't slow down, I'd ask if they would do that for you. Or at least for the front brakes. Heck, see what stuff they've got lying around to piece together a set of brakes that actually work.
    This would be the reason I go to an LBS rather than buying online. Basically if you're not satisfied, then they should work with you to help you get there and enjoy riding. If you enjoy riding, you'll wear stuff out then you'll come back for service and parts. That's how the game works.
    I Have Cookies
    Dec 2008
    Quote Originally Posted by JonathanGennick
    "then where's the advantage of a bike shop over the discount store"
    The bike is assembled safely and professionally by a bike mechanic. Things torqued properly, Threads greased, Put together properly.
    "I'm seeing increasingly low end and disappointing parts on bike-shop bikes."
    You would be surprised if you walk into most LBS's and look @ some of the lower end Comfort bikes or even the Kid's bikes. Their not much different than what you would find @ Dept Store's higher end, component wise.
    The bike company's have been doing this for years. It's nothing new. The lower end stuff you get what you pay for. they have to cut cost's somewhere.
    ____
    Kimo
    Ok....I think you're correct in being unhappy with the brakes, but it also seems that your expectations are a bit out of line. You should not expect, factually speaking, your brakes to lock up (at least not on an entry level disc brake). Brakes, from the manufacturing standpoint, are intended to bring you safely to a stop. They do that, don't they? Just not as quickly or abruptly as you thought they should? If you expect a bottom-end ride using mostly bottom-end components to perform the same as higher-quality and higher-performing products in the marketplace, then you're just wrong. You'll have to spend a little more cash to get some of those benefits. Yes, good brakes are very nice to use and we've all grown accustomed to much better braking than what bike riders have ever known before....but you're buying bottom-end stuff here.
    That said, you should have some recourse via Trek or the bike shop to simply return the bike and then go buy another. Or, like several people said above, just pick up another brake or set of brakes. Personally, the rear brake isn't as important, so I'd just get a BB7 front brake either used for cheap, or look online and you can find them from $35 to $45. Another option might be to try some compressionless housing for your front brake...cheap and quick fix that might really improve it a lot.
    You might get lucky and get Trek to give you some better brakes, but most likely your best option will be to return the bike and buy another. The shop isn't responsible for this....it's Trek's issue for spec'ing a cruddy brake. If you misunderstood, as a newbie, or if the shop misinformed you, then they should be willing to help you as best they can provided you haven't pissed them off by now, but don't expect anything for free.
    I don't think you're viewing this from a business standpoint.....sounds more like an angry consumer standpoint to me. Return it or buy a front brake of decent quality, dude. Or hell, v-brakes are still great except in wet weather.....exchange it for the v-brake model and get a small refund in price. Your choice but damn, chill out a little.
    Quote Originally Posted by Noobi-Wan Kenobi
    Dude! The salesman lied! LOL
    AZ
    AZ is offline
    I am calling bullshiite , this is the same bike that you sprayed lubricant on the brakes , you stated as such in a thread that you started . I suggest that you owe everyone here an appology as well as a retraction of ALL of your bogus claims .
    Quoted
    "I made a real newb mistake. My disc brakes were not stopping and then I realized I had been shooting lube into the disc brakes and all over other brake components. How do I dry the lube up so I can stop!"
    Jenson has BB7's on for $45 bucks, I don't know what Promax go for....
    Ask the LBS how much they would charge to upgrade to BB7s....
    Labour should be free, promax gotta cost oh say $30 bucks each....
    So maybe pay $60 bucks for the upgrade and get the hell out of jail?????
    Where you sit now you are going to have to negoitcate.
    AZ
    AZ is offline
    FWIW , there are only four Trek dealers within a 25 mile radius of Temecula , I wont find it very hard to find the one you are trying to defraud .
    Ouch....dude, if you lubed your brakes accidentally, then what you need to do is buy new pads and scrub the rotor and caliper clean. Get some Ajax powder and a stiff brush and make a paste...scrub the rotors twice on both sides and let them dry. Clean the caliper with solvent as best you can, then bed in the new pads.
    I know it's possible that Promax put out a faulty brake, but in my experience every one of the low end brakes (no matter what design they are) have filled their intended purpose. If they put a faulty one out there, then there will be a recall. They've all brought the bike to a stop...some are just better than others. If it was just that you mistakenly got oil on them, make it right and ride happy.
    Whoa. If you got oil on em...then it's no responsibility of your LBS or manufacturer.
    between the amount of times the OP said BS and LBS i cant understand whats going on....
    newless cluebie
    Quote Originally Posted by AZ.MTNS
    Quoted
    Nice, I did remember reading that thread but I didn't realize it was the same poster.
    BUSTED.
    Bite the bullet buddy, you screwed your own brakes up.. don't be blaming Trek or your LBS. That's like buying a car, crashing it while drunk, and blaming your dealer+manufacturer for it.
    can't you just try to exchange it with the specialized you tried since the sales guy told you the brakes will be fine after a few rides and the bike is fairly new? how old is the bike btw? I say partly it's the lbs fault here, cuz they should have known that the bike has a shitty brakes. trek put those brakes on that bike for a reason and that is because it's an entry level bike and if you want a better braking power go with their better bikes.
    I Have Cookies
    Dec 2008
    Quote Originally Posted by Crankenator
    Dude!! WTF!! OP-GET A LIFE!
    ____
    Kimo
    AZ
    AZ is offline
    Dude , read the thread " Big newb mistake disc brakes " its on this page , this guy sprayed lubricant on his brakes and is now trying to scam the LBS and Trek .
    didn't the op replaced the pads and cleaned the brakes? i know the op made a lot of mistakes like accidentally (i hope) spraying lube on the brakes(both?), not researching bout the bike he bought, but still the lbs should at least help him right?
    MTB skillz = NADA
    Dec 2009
    He has now started 3 threads on this crap.
    AZ
    AZ is offline
    The truth is , no one knows if hes telling the truth about the LBS , hes lying about so much you have to assume that its all a lie . All except the part about douching the brakes with lubricant .
    I'm sure they would be happy to help him if he went in there the first time and told them the mistake that he had made. Instead he went there and told them that THEY had made the mistake and they were trying to help him deal with "faulty" brakes.
    Reputation: mullen119's Avatar
    Quote Originally Posted by highdelll
    Awesome!
    I am pretty sure that you need to be a detective, this is like the 5th person I have seen you bust on here and I have only been paying attention for a few months. your the man AZ!
    Quote Originally Posted by vaelin
    BUSTED.
    OMG!!! A number of you guys are truly NOT paying attention. I will break it down for you:
    1) I was speaking very "off the cuff". I really wasn't "shooting" lube DIRECTLY into the calipers & pads. I was overemphasizing to show what a newb mistake it was. I was under the impression that the REAL problem was that lube/oil SOMEHOW got into the system. I got this "wonderful" (sarcastic) advice from my LBS mechanic.
    2) You bringing this point up shows that you are not paying attention to what I am posting. The calipers and rotors have been cleaned with alcohol thoroughly and the pads are brand new. The LBS manager even saw for himself that everything was adjusted properly, just that the disc brakes suck. Maybe you should actually READ what I have posted. How the hell am I trying to SCAM my LBS? LOL. This is so stupid its hilarious.
    3) The salesman told me something not true. I tried the brakes out while I was there and asked why they were not strong. He said they just needed to be bedded in. Now that I have replaced/cleaned everything, and bought new pads.....they tell me that its just that the disc brake is just not any good.
    Most of you have been very nice but there have been a lot of know-it-alls and persons whom simply spit out whatever comes into their heads. Thank you for the nice peeps help, but I am going to find another forum. The moderators obviously are not keeping out the riff raff. I still can't believe there are people accusing me of trying to scam the bike store. LOL.
    I Have Cookies
    Dec 2008
    I am going to find another forum.riff raff LOL.
    YES. The sales man was speaking the truth. I don't care what brand brake you are putting on the bike THE PADS NEED TO BE BEDDED IN!! It's even true with the disk brakes in cars and trucks. Once the pads bed in the power and modulation will go up.
    The fact that your brakes suck and always will is irrelevant at this point.
    Have fun over on PINKBIKE!
    ____
    Kimo
    AZ
    AZ is offline
    I wasent , after your LBS reads all three of these three of these threads I'm sure you guys can get together and sort it out .
    AZ
    AZ is offline
    Casino Bicycles
    43906 State Highway 74
    Hemet California
    800-851-7433
    www.casinobicycles.com
    More Information >
    Trek Store of San Diego
    2123 Industrial Court
    Vista California
    760-599-9735
    www.treksandiego.com
    More Information >
    Cyco-Path
    29760 Rancho Californa Rd #107
    Temecula California
    951-695-4823
    More Information >
    Jax Bicycle Center-Murrieta
    26612 Margarita Road
    Murrieta California
    951-239-8239
    www.jaxbicycles.com
    More Information > One of these is likely the shop he is dealing with , any Temecula locals ?
    By all means.....go ahead AZ.MTNS. Everything I have put up here the business already knows. LOL. I just can't stop laughing at how ridiculous this is.
    Quote Originally Posted by jonbobcar
    Another poster who has obviously not read my posts on this subject. You are talking out of complete and utter ignorance.
    AZ
    AZ is offline
    Meh , we shall see . I'm sure you will enjoy your short stay here .
    Casino Bicycles
    Hemet California
    800-851-7433
    More Information >
    Vista California
    760-599-9735
    More Information >
    Cyco-Path
    Temecula California
    951-695-4823
    More Information >
    Murrieta California
    951-239-8239
    www.jaxbicycles.com
    LOL! This is comedy! You reeeeeaaaalllly need to get rid of all that spare time. I'm not even going to insult you. I'm just saying, if you have this amount of extra time.....send me some.
    AZ
    AZ is offline
    Anything to help you out . It only takes a second or two .
    Have fun then. I will let you focus on your project...LOL.
    AZ needs to step away from his keyboard for more than 15 mins a day (excluding bathroom breaks)
    Quote Originally Posted by Dictatorsaurus
    I second that recommendation. All I can say is "control issues".
    AZ
    AZ is offline
    Why , because I called you out on your idiotic attempt to defraud ?
    Dude, actually READ my posts!!!!!! You are coming to a conclusion without all the information. And, I think you are hurting your image on this forum. The LBS knows everything I have posted here! Everything!
    newless cluebie
    Pot calling the kettle black buddy.
    I was the only one who gave you instructions on what you COULD do yourself to the brakes in this thread without "replace them."
    You chose to ignore it, then you only read the part where I thought that if you were the one who screwed up the brakes, you should take responsibility.
    Boohoo, "this forum suxx0rs because I'm being picked on." Welcome to the Internet.
    AZ
    AZ is offline
    You should read all the posts , in all of the threads you started about this . I posted several times about how to fix your issues , I believe I have all the info . As far as my image , if it goes to shiite over calling out a scammer so be it . Integrety means so much more than image , but I'm sure that concept is lost to you .
    Omaha Clyde
    Really? Dont know too many people who are too concerned with their online "image"
    your comparing a pinto to a corvette. if the bike shop told you they were good brakes, then dont go to that bike shop anymore. Take it as a lesson learned and stay away from anything that says promax on it. Buy some bb5 or even better, some bb7's. There is nothing that you can do to make the promax brakes work any better then they do with new pads and a clean rotor. I agree that trek should at least put tektro brakes on there bikes (and that is still a crappy brake but will atleast stop you). Sorry your LBS salesman lied to you.
  67. #67
    A little off topic, but I was actually fixing my 10 year old Promax V-brakes. I couldn't believe they lasted this long. I'm thinking of switching to single digit 7s.
  68. #68
    Quote Originally Posted by jarHunter
    AZ gives some of the best advice on this forum. He does tend to give the response of "spend money" a little more often then needed and likes to get on dremer which is funny most of the time but every once in a while uncalled for. Overall though, listening to his advice will save some headaches. This time he is right for sure, Go spend some money and upgrade.
  69. #69
    I have some really old promax V's as well that i have just laying around in case I ever want to go back to them. They actually worked pretty well for the few years I used them. I guess promax does make one good product.
  70. #70
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    lulz...
    here is a bunny with a pancake on its head..
    now...OP....stop being a spaz and upgrade your brakes...or get used to them.....
    Click Here for Forum Rules
  71. #71
    Reputation: 006_007's Avatar
    mmmmm, pancakes
  72. #72
    mmmmm, bunny
  73. #73
    Feb 2010
    I wonder why Trek would put crappy disc brakes on? why not put v brakes? Anyway, I upgraded to bb7's and I am very happy with them. I did see the other post about getting lube on the brakes. Makes this whole issue very interesting. When I installed my bb7's they grabbed immediately.
    go with the bb7's or bb5's.
  74. #74
    Quoted
    Uhm... AZ dude, I hate to say it, but you might have had a hand in creating this monster:
    I would do some shopping around if I were you , it should be pretty easy to better that price . If you can do your own maint. I would save the money on the service plan .
    Just sayin'...
    David B.
  75. #75
    AZ
    AZ is offline
    Quote Originally Posted by davidbeinct
    Just sayin'...
    David B.
    The key word being " if " . Respectfully , nobody twisted his arm to forego anything , just as nobody provoked him to deception , fradulant claims etc. Then to put the icing on the cake , post here bashing a respected company , trying to pass off his assinine mistakes to someone else .
  76. #76
    I Have Cookies
    Dec 2008
    mmmmm, bunny
    +1
    <a href="http://s93.photobucket.com/albums/l45/ae111black/?action=view&current=a8072ef7.jpg" target="_blank"><img src="http://i93.photobucket.com/albums/l45/ae111black/a8072ef7.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
    here's a pic of a real bike for you to refrence
    ____
    Kimo
  77. #77
    Dude, chill, I'm totally busting your chops. I just found it funny that following this twisted bunch of threads it turns out some very reasonable advice, followed by a nincompoop, resulted in all this mess.
    Such are the interwebs...
    David B.
  78. #78
    AZ
    AZ is offline
    David B.
    No prob. here , always value your input .
  79. #79
    AZ.MTNS,
    You just don't get it. I take full responsibility for the lubricant thing.
    What I dont take responsibility for is the fact that the stock brakes on the 3900 disc simply do not have enough power to stop the brakes. How do I know this is not just the case with my bike? I have tested other 3900 disc bikes since all this started happening. They had the same issue. I bought new pads from the store in question. They were installed and the entire brake system was thoroughly cleaned before hand. They still do not work! The manager himself noticed that the brakes were in good condition...just not stopping powerful enough. He rode it himself! I told him the whole situation (lube problem and all). I am being totally honest with the bike shop.
    Again, I take full responsibility for my mistake. However, my mistake is not why the disc brakes have sucky stopping power. I even bought new pads to remedy the mistake. So tell me again.....how am I trying to rip off the company? The manager himself AGREES that it is not the lube...it is the brakes themselves.
    TELL ME! HOW AM I TRYING TO RIP OFF THIS COMPANY? Your posts about me defrauding dont make any sense.
  80. #80
    David B.
    David B.
    Sounds like you are a little frightened of AZ LOL! You sure backed down quick. Just busting your chops though.
  81. #81
    AZ
    AZ is offline
    AZ.MTNS,
    Your claims of the brakes not ever functioning do not hold up . You took possesion of your bike on 01/25/10 , not a peep from you about the brakes until one week ago when you lubricated them . Odd that there is no mention of a problem for over six weeks , then when you make a mistake and cant get it cleaned up it turns into a manufacturers problem . To top it off you come on a public forum and bash the manufacturer and your LBS instead of owning up to your mistakes . It was not until your last post that you admitted to any culpability at all . To even suggest that the product is at fault is ludacris . To suggest that the manufacturer is at fault is laughable at best and fraudulant at the worst . To sum it up you are lying and you got caught . Man up and fix the problem instead of trying to pass the buck .
  82. #82
    AZ
    AZ is offline
    David B.
    I can assure you that there is nothing but the utmost respect between DavidB. and myself , to even suggest different is foolish .
  83. #83
    Like sands through the hourglass...
    ...these are the days of our lives.
  84. #84
    Ocean...alcohol isn't the best choice to clean up oil for something like this. A great many lubes aren't soluble in alcohol, not even a bit. It's a good general purpose solvent for cleaning airborne contaminants, car exhaust (marginal), etc. I use it for occasional wiping down of the rotors. In your other thread, I suggested that you use an Ajax powder paste. It works. That, or some auto brake cleaner, acetone, etc. (do NOT use paint thinner, mineral spirits, kerosene, turpentine, etc...those solvents have an oily residue.)
    Also, if you aren't using 91% isopropyl alcohol you're further wasting time ($1 at any drug store, sometimes found by the diabetic supplies). The usual 70% won't cut much of anything, and if you used "rubbing alcohol", that has oils in it. If the brake *honestly* sucks that bad, it may not get you where you want to be, but since the lubricant is thrown into the situation, it would at least be good to try and fix that the best way.
    If you had residual oils on the rotor, then you might have lightly contaminated your new pads. Search on this forum for methods on cleaning pads....soaking/heating/sanding works pretty well if they didn't absorb too much. Give it a shot.
    I do think that as you get to know bikes, bike people, and bike shops, your attitudes might change a little bit.....hope so. Most mtb'ers are pretty cool peeps, but it's a bit of a different DIY crowd than your average automobile shopper, especially in online forums. Just sayin'. good luck with the situation, hope it works out ok for ya.
  85. #85
    ~Disc~Golf~
  86. #86
    AZ.MTNS,
    I think you may honestly be crazy. First, it has been a lot longer than one week since I had the lubrication problem.
    Second, what do you mean I can't get it cleaned up. If I couldn't get it "cleaned up" and the manager knows about the lubrication problem. Why would he himself blame the quality of the brakes? You are acting as if I am keeping something secret from them.
    Third, are you saying that I, word-for-word, have to say "I, ****** ******, take full responsibility for getting lube on my disc brakes"? When have I ever denied making the newbie mistake? Go ahead, show me the post (it doesn't exist).
    Fourth, you simply will not address the FACTS. I NEVER bashed the LBS. LOL! Heck, I never even mentioned the business name. The negative thing I said about the bike shop was that the salesman lied, whether that was out of ignorance I do not know. As far as bashing Trek, that is a lie. The manager of the store agreed that the disc brakes were simply not going to give me the stopping power I needed. the simple fact that Trek decided to use disc brakes that LBS managers agree are poor quality shows that Trek needs to open their eyes to the problem.
    In conclusion, I do not know why you are mad. I have found almost everyone at that business to be nice and somewhat helpful. They may have not addressed/handled every situation in a perfect manner, but I am confident that they will make it right.
    I simply cannot believe your emotional issues AZ. The fact that you have gotten this fired up over on this topic shows complete ignorance of the FACTS. This forum points new buyers toward the direction of LBS, but when something goes wrong, then the trash talking starts. I have no problem whatsoever with the LBS who sold the bike reading all my posts. They already know it all AZ!
  87. #87
    The impression I got from reading your posts here and on the other threads was that you were, indeed, bashing the salesman, the bike shop, and Trek. Not only did you call them liars, but several of your posts were suggesting they were crooks (i.e. "will rip you off", paraphrased from your words). Maybe you're young and don't realize the impact of those statements, or maybe you mis-spoke when typing it out.....definitely had that impression, though. Sounds like you have great expectations and demands, and in real life things don't often satisfy like that. Salesman, for instance....lied? Perhaps he wasn't very knowledgeable, or perhaps he didn't know that those Promax brakes weren't very powerful, or perhaps he just assumed that every brake will get better with use (mostly true). But lied to you? How exactly do you know?
    As far as Trek opening their eyes to the problem, I think you're just totally missing the FACTS here, and what others have said: you bought a bottom end bike with entry level components, and $579 was a lot of money to you (your words, in a few posts, and evidenced by your haggling over $50 between shops). Trust me, those bikes are "price point" bikes and there isn't much profit at all for either the manufacturer or the retailer. It's not easy to put together a decent-quality bike at those price levels and still give you the confidence that a large company can provide with service and warranty. If you're pushing your budget, buy a cheaper bike or save up a little longer. Trek offers that bike as a pretty solid value for what you're buying, honestly. So do the entry bikes from Specialized, Scott, Giant, etc. But see them for what they ARE, not what you expect them to be as someone new to the game. They're worlds above walmart bikes, and worth buying, but you're just not going to get the awesomeness that you see in magazines and videos at that price level. Lesson learned.
    Maybe "the stopping power you need" is the key here....and you just found out that bottom-end isn't going to give you that....you're just missing the point that you needed to spend more to get what you wanted. No prob, you're new to this. I think people just took issue with your unfounded bashing of products, people, and companies -- sure does look as though that's exactly what you've been doing. So suck it up, get some brakes that you like or work it out with the shop, and ride happy.
    Glad to hear that you feel like you're getting good service....reading your letter to Trek and your words about the bike shop/shop employees, and your general distrust while shopping for a bike....definitely got the opposite impression from you.
    I'm getting off the grandpa soapbox now....apologies if I offended.
  88. #88
    Enthusiast
    Highdell, I had to google your number sequence. In case anyone's interested, here's good link:
    http://books.google.ca/books?id=8u1E...age&q=&f=false
    The figure caption explains how the sequence is derived.
  89. #89
    Enthusiast
    It's probably unfair for us to jump on the original poster and accuse him of defrauding his LBS, just as it is unfair of him to accuse his LBS of lying.
    What I see is a beginner who spent what he felt was a ton of money on a bike, and things have gone a bit badly for him. My advice to the OP? Spend the money. Buy a set of BB5s. Put the whole mess behind you as a lesson-learned.
    And we should all put this mess behind us. Let's not turn a minor dust-up into disaster.
    If it weren't so dreary out, I'd go riding now.
  90. #90
    Reputation: Eric Z's Avatar
    i just wasted 5 minutes of my life reading through this thread. and another 10 seconds posting on it. enjoy the weekend, all!
    ez
    - 1995 Giant ATX 870
    - 2011 Salsa El Mariachi XL
    - 2011 Kona Unit (singlespeed) XL
  91. #91
    Reputation: mudforlunch's Avatar
    dude. ok. oceanfirehawk, everyone here is screwing with you. what no one here is going to tell you is that LBS and riders don't tell noobs how to get their brakes to work properly so they can get them to keep coming back and buying more parts (rotors, pads, labor costs, etc.). In order for disk brakes to work properly, you need to rub the rotors down with ranch dressing. Yes, I'm dead serious. It's one of those things that everyone who rides knows, but we never really talk about it, because almost all of us work in bike shops and make a lot of money off noobs who are just getting into riding and don't know what they're doing. Seriously, try it tonight, and then go for a ride. Those babies will stop on a dime. Hidden Valley Ranch works the best, I have found.
  92. #92
    ~Disc~Golf~
    Kirkland from Costco works just as good, plus you can buy it in bulk - no need for that marked up name brand stuff.
  93. #93
    Reputation: random walk's Avatar
    I was wandering the aisles at Costco just yesterday and noticed Kirkland ranch dressing sports a "Not for off-road use" sticker.
  94. #94
    ~Disc~Golf~
    Quote Originally Posted by random walk
    meh... it's just a 'CYA' thing.
    Just don't do any drops or hucks and you'll be fine.
  95. #95
    I Have Cookies
    Dec 2008
    No way baby! Great Value all the way!!! I dont need to get all "dolled up" to go down to the SuperWally Mart!!! Like You do down @ Costco's
    ____
    Kimo
  96. #96
    MTB skillz = NADA
    Dec 2009
    Does the ranch dressing work for hydro's as well? I'll be breaking in my new hydro brakes this weekend. I hope we have some ranch at the house.
  97. #97
    ~Disc~Golf~
    Ranch is incompatible w/ hydros
  98. #98
    newless cluebie
    You need to use italian dressing or preferrably vinegrette. The olive oil is better than the DOT brake fluid.
    (Truthfully.. ranch dressing MIGHT actually work as a tire sealant.)
  99. #99
    thousand island
  100. #100
    Permanent Noob
    Reputation: JCullen's Avatar
    +1
    thousand island
    Plugs the bigger holes better!
