Page 2 of 2 FirstFirst 1 2
Results 26 to 31 of 31
  1. #26
    Reputation: jetboy23's Avatar
    Quote Originally Posted by Vettevert View Post
    On the XTs. That sounds great....but I barely got the bike wife approved, and she wouldn't understand why I was replacing brand new brakes if you know what I mean.
    Let her ride the bike and feel the vibration. She will immediately agree that they are unsafe and require replacement.
    Disclaimer: they're probably not unsafe, but, from the vibration i've felt... it can remove confidence on a technical downhill pretty quickly with the shuddering.
  2. #27
    Reputation: shwinn8's Avatar
    Feb 2006
    is the Salas HT referring to the full suspension HorseThief? If so, I'm guessing one of your pivot bearings is shot or possibly a loose mounting bolt.,
    '11 Jedi
    '01 Rocket 88 Stage3
    '00 Homegrown
  3. #28
    Reputation: smithcreek's Avatar
    Nov 2012
    I had some thumping also. Seemed like the most obvious cause was some unwanted contact with the "arms" of the rotor so first thing was to realign the caliper. I could see one pad was contacting first and warping the rotor about .01+" before the other pad contacted. It took about a dozen attempts to get the caliper positioned so there was absolutely no detectable rotor movement, either visual or by feel, to either side when I pressed the brake. The thumping disappeared instantly and so far has not returned.
  4. #29
    I think I am seeing the same thing. I think the pads are hitting the rotor arms...
    I have tried many times to center the caliper. Sometimes the thumping gets worse, and other times it cures it...temporarily. I guess I should keep trying. Since making this adjustment changes the problem, it must be what is causing it.
  5. #30
    Quote Originally Posted by shwinn8 View Post
    Yes, a horsethief. Bike is new, so I doubt it is shot, but I will check the mounting bolt.
    Feb 2006
    bearings can fail even if they are new due to poor manufacturing. you never know! just another possibility to look at
    '11 Jedi
    '00 Homegrown
