Results 1 to 5 of 5
    Aug 2013
    Dirt in the downtube
    So I picked up a used Jamis Dakar xc comp the other day. Overall the bike is in pretty good shape, and I got it cheap. However....I didn't notice until I got it home and flipped it over, there is a bit dirt rattling around in the downtube. The bottle cage bolts on the underside were removed, so I assume mud sprayed its way into it from there. So my question is.... is the tube open to either the bottom bracket or headseat so I can clean it out, or is it just going to be stuck there? If it is open to either, I am sure it isn't doing those parts any good. Thanks for any advice.
    Dec 2010
    Take out the BB and fork and use an air compressor to blow air in one hole. It should blow everything out the other hole.
    Aug 2013
    Quote Originally Posted by sasquatch rides a SS View Post
    Sweet!!! Thanks
    Dec 2010
    Make sure to put some bolts in the frame to keep dirt out
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Re: Dirt in the downtube
    If that doesn't work, you may have to pull the fork out of the frame. There should be a big opening where the downtube joins the headtube. Anything in there will come out easily through there.
    I'm a mountain bike guide in southwest Utah
  1. Downtube protector
    By al95ti in forum Devinci
    Last Post: 08-18-2013, 04:43 PM
  2. The One downtube protection
    By ikarus189 in forum Canfield
    Last Post: 08-10-2013, 12:57 AM
  3. Women's dirt clinic this weekend and next. Dirt Series
    By zazzafrazz in forum Women's Lounge
    Last Post: 05-16-2012, 04:53 AM
  4. Trussed Downtube
    By Crispy01 in forum Frame Building
    Last Post: 08-04-2011, 02:04 PM
  5. Downtube Fender
    By dsimp1712 in forum Commuting
    Last Post: 04-08-2010, 09:18 PM
