Results 1 to 5 of 5
    Diamondback Response -- Sport?
    I'm looking at the Response and the Response Sport and was wondering if the component set on the Sport is worth an extra $100? The differences are the Sport has disc brakes, 120mm travel in the front shock compared to 100mm, Shimano Altus front derailleur, and Shimano SL-MC40 shifters. After test riding both bikes, they seemed comparable. No noticeable difference in shifting but the disc brakes were better.
    I'm going to be doing some single track on the weekends and some fire road riding during my commute. I'm leaning toward the lower end model without the disc brakes and using the $100 on a helmet and a different derailleur or some pedals.
    Thanks.
    Did I post this in the wrong forum?
    Personally I'd go with the response and not the sport.They both have entry level components so you may as well save the $100 and replace components as they wear out or break.I would think for what you're doing an 100mm fork would be fine and the disc breaks on the sport are not that great anyways.
    Another suggestion would be to get Avid BB-7 disc brakes if you want discs.You can get a set of them for about $100 and from what I hear are very nice.
    Tossin the salad.
    Reputation: TX_Shifter's Avatar
    Nothing wrong w/ the VeeBrakes IMHO and 100mm fork. I had the 06 response w/ the 80mm Spinner fork couple years back and it was fine and held up. great entry level bike. I then sold it got the gary fisher marlin w/ 100mm fork. had better geometry frame style, but it also cost more. For what you probably plan to ride it and if your stuck on the response, I say save the $100. I only upgrade to disc if its hydraulic type. I hated the hayes mechanical type brakes
