    New question here. diamondback responce sport or overdrive?
    over drive
    Overdrive 29" Butted 6061-T6 Aluminum w/ Formed Top / Down Tube, integrated Headtube, DB Snake Stays, replaceable hanger Fork SR Suntour XCT MLO 100mm travel, 28.6mm stanchions w/Mechanical Lock out Rear Shock N/A Cranks SR Suntour XCT 22/32/42t Bottom Bracket Sealed Cartridge F. Derailleur Shimano TX50 dual pull, Top swing, 34.9 R. Derailleur SRAM X-4 8spd Shifter SRAM X-4 trigger 8spd Brake Levers Tektro Alloy w/ reach Adjust Brakes Tektro Novela Disc w/ 6" Rotors Gear SRAM PG-820 8spd Cassette (11-32t) Rims 32h Weinmann SL-7 Doublewall Tires WTB Prowler SL 29x2.1 Pedals Wellgo Alloy forged, CNC MTB Handlebar DB Lazer Series 31.8mm low rise Stem DB AL6061 Ahead 7 31.8mm Seatpost DB Lazer Series Micro Adjust 30.9mm Seat Avenir Series 200 Black Headset Integrated "Cane Creek" Size Drop-in ACB 1 1/8" Colors Black Chain KMC-Z82 Hubset (F) 32h SL-7 Alloy w/ CNC Disc Mount (R) 32h SL-7 Alloy Cassette w/ CNC Disc mount Spokes White 14g Stainless Steel Grips DB D2 Kraton
    response sport
    Sizes XS (14"), SM (16"), MD (18"), LG (20"), XL (22") Frame DB 6061-T6 Aluminum w/MISSION Machine Formed Top Tube, Formed Down Tube, DB Snake Stays, replaceable hanger Fork SR Suntour XCM 120mm travel, 30mm stanchions Rear Shock N/A Cranks SR Suntour XCT 22/32/42t Bottom Bracket Sealed Cartridge F. Derailleur Shimano TX50 dual pull, Top swing, 34.9 R. Derailleur Shimano Acera 8spd Shifter Shimano SL-M310 8spd Rapidfire Brake Levers Tektro Alloy w/ reach Adjust Brakes Tektro Novela Disc 6" Rotors Gear Shimano HG30 8spd Cassette (11-32t) Rims 32h Weinmann MX260D Doublewall Tires Kenda Klaw XT large casing 26x2.1 Pedals DB Toe Clip Compatible Platform Handlebar DB SL318b Oversize 31.8mm Mid Rise Stem DB SL318s 31.8mm Seatpost DB SL309p Alloy Micro Adjust 30.9mm Seat DB All Moutain saddle Headset Zero Stack Ahead 1 1/8" Colors Steel Blue Chain KMC-Z82 Hubset (F) 32h MX260HAlloy w/ CNC Disc Mount (R) 32h MX260H Alloy Cassette w/ CNC Disc mount Spokes White 14g Stainless Steel Grips DB Brics 130mm D2 Kraton
    what bike is better specs wize?
    Never trust a fart
    Reputation: frdfandc's Avatar
    Do you like the big wheels or the little wheels?
    Ride them both and decide.
    Reputation: Polyspecific's Avatar
    Quote Originally Posted by frdfandc
    ++ Dead on frdfandc.
    I like 26" wheels my friend likes 29" all depends on how they feel to you.
    Hey!! I found my limit.... lets see what happens when I push it about 2 notches farther....
    Lucky for me, my wife bought the Response and I have the Overdrive so I can take her bike when she's not around. IMO, the lockout feature on the Overdrive 29 is worth it alone. But I have the standard version only because I wanted rigid forks. I enjoy riding mine. The Response is really responsive to your input and very planted only because it's a bit porky but it doesn't feel it. The Overdrive gives a bit more cushion than the Response over the same terrain. Funny but I feel like I'm cruising along the trails on the Overdrive while the Response makes me feel like I'm attacking it even though I'm riding both at the same pace.
    2011 Diamondback Trace "Sport"
    2011 Diamondback Overdrive 29er
