Results 1 to 5 of 5
    Feb 2006
    destroyed post mount thread on fox
    the down bold on my fox's post mount (where the caliber is placed) cannot get tight. the thread where the bolt screws on is destroyed. can i solve it somehow? thanks
    bike tester
    Reputation: syl3's Avatar
    helicoil
    Feb 2006
    When you install a helicoil you have to drill the hole much bigger to tap for the helicoil. There may not be enough meat there to do this.
    This is a hack and people will hate it but M6 thread (.1968) is very close to 1/4 inch (.2010). If it was me, I'd very carefully open up the hole with a #7 drill - can probably do this by hand as it will already be approx the correct size. Then tap it for SAE 1/4 inch coarse. You will need a bottoming tap for this. It will be just a few thousand larger, enough to get a good thread. You might have to open up the caliper hole slightly. If it doesn't work you can still put the helicoil in.
    You might want to try posting in Tooltime
  1. Who makes post to post mount rear adapters???
    By ebnash in forum Brake Time
    Last Post: 08-24-2014, 03:17 PM
  2. Post mount
    By Jamenstall in forum Frame Building
    Last Post: 05-08-2012, 11:26 AM
  3. Lefty Disc brake mount? - IS or Post Mount
    By tojnom in forum Cannondale
    Last Post: 02-03-2012, 04:16 AM
  4. Replies: 7
    Last Post: 01-02-2012, 10:34 AM
  5. Post mount to IS mount adapter...correct me if I'm wrong.
    By ProjectDan35 in forum Shocks and Suspension
    Last Post: 04-22-2011, 08:38 AM
