Results 1 to 8 of 8
    Sep 2013
    Deore, Alivio, XT, SLX, Shadow Design... Confused!
    Hi,
    Need a little help distinguishing between all these jargon: Deore, Alivio, SLX, XT, LX, Shadow design, etc... Are the Deore and Alivio the family name, and SLX, XT, etc are the class? Also, are they just derauillers? I see Deore shifter, brake, derauiller, everything! Initially I thought they were just a class of brakes... So confused right now.
    Fat-tired Roadie
    Nov 2007
    Visit the Shimano web site.
    Almost all the things you listed were names of groups of components that are marketed together. Most groups contain all the elements of a complete drivetrain. In general, they occupy a sequential series of pricepoints.
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    They are named families of Shimano components. I believe the order is Alivio->Deore->SLX->XT->XTR, ascending. SLX can be considered best bang for the buck for performance/weight/durability. Not far off the performance of XT with a slight weight penalty at 30% less retail cost.
    shadow and shadow plus are rear derailleur technology. Not sure what the shadow technology actually does, but the shadow plus definitely works. It has a clutch that reduces chain slap and chain drops. It is available on slx and higher.
    mtbrmembernewuserbeginner
    There's also a nice breakdown of these on the second post in this thread:
    Noob Buyer's Guide
    Nov 2008
    Re: Deore, Alivio, XT, SLX, Shadow Design... Confused!
    Shadow hugs lower and closer to the wheel. Prevents strikes
    Sent from my LG-P769 using Tapatalk 2
    Sep 2013
    Quote Originally Posted by beer_coffee_water View Post
    But then what's Deore XT? That's my rear dereuiller...
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Kevin_Federline View Post
    It also changed the geometry of the pivots in the derailleur parallelogram to reduce chainslap. On older designs, the knuckle of the RD could bounce up and hit the chainstay from below. Not so with shadow. Shadow + added the clutch which keeps the pulleys from swinging freely, reducing chainslap even more.
    The full names of the SLX and XT groups are Deore SLX and Deore XT. The Deore name goes way back. Deore LX is still around but has the older parallelogram design. It is basically now considered a touring/trekking group. It is capable of using a bigger cassette than traditional road derailleurs. It used to be a mtb group at the level of SLX. Current shimano 10spd derailleurs and shifters use Dyna-sys technology, which subtly changed the pull ratios. Generally, dyna-sys stuff is not compatible with earlier 9spd stuff.
    SRAM uses its own heap of product names and technology marketing terms, but they follow a similar component group naming structure. And so does Campagnolo.
    Back in the 80's and maybe earlier, you had a few companies that would partner together to make different parts for one group. You had Suntour doing drivetrain bits, dia-compe doing brakes, and probably other companies I can't recall. All the parts would have the same group name even though different companies made them.
    The tendency to make a set of matching components and give them a single group name goes back at least a few decades.
  1. Shimano Alivio vs. SLX vs. Deore XT
    By howetechnical in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2014, 02:04 AM
  2. Alivio 8spd replacement shifters,will deore work
    By lolaralph in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2012, 10:11 PM
  3. Deore XT vs Deore Kinda confused on my parts spec for my Anthem X3
    By shwndh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 10:17 AM
  4. Alivio shifter Deore derailleur?!?
    By brownv1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2011, 09:27 AM
  5. Compatibility Deore and alivio 8spd vs 9spd
    By chris555 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2011, 01:14 PM
