Results 1 to 16 of 16
Thread: Degreaser
    Degreaser
    Is there any other kind of degreaser that would work on a chain? I've got all sorts of automotive degreasers and lube and was wondering how well they'd work with taking White Lightning off my chain.
    Aug 2005
    pedro's bio degreaser that's all I use
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    I use simple green
    Regular bike degreasers work well for most chain lubes but I've found White Lightning to be somewhat resistant to them.
    The White Lightning Clean Streak degreaser work very well to remove White Lightning and judging from the way it smells it seems to be nothing more than automotive brake cleaner (in a pretty can with a higher price).
    Any auto parts store, Walmart, Canadian Tire, Pep Boys, etc should have brake cleaner.
    One warning: It doesn't seem to play well with the plastic in those clip on chain cleaners - mine became crazed on the inside after using it.
    Yes, we have tons of parts cleaner for cars, so that will work to get rid of white lightning?
    Minerals Spirits/Paint Thinner in a jar, drop the chain in & shake well. Let dry for a few hours.
    -james
    2000 Trek 6500 HT
    2008 Ibex Asta Comp X7 FS
    So is yimmy saying that all I need to do is drop my chain in paint thinner and shake it? would automotive brake cleaner work?
    I've read a number of other people use the paint thinner method. Nice thing is that you can reuse the thinner a number of times - if it gets dirty pour it through a coffee filter.
    The only brake cleaners I've used are aerosol cans, not sure if that's what you mean? In that case, the advantage of the spirits/thinner is that it really gets inside the chain, not just on the surface. And it evaporates given enough time, so you don't need to rinse the chain off as far as I know.
    -james
    2000 Trek 6500 HT
    Cyclist of Borg
    Reputation: Locutus's Avatar
    Go to Home Depot [or similar] and get TurpAtine not TurpENtine. The former is a petroleum distilate and the latter is a tree sap distilate. TurpAtine works awesome. drop in what ever and give it a swish and the chain is sparkling, after that some hot soapy water and then cold to rinse out the soap. I have found it to be the BEST [bar none] degreaser ever
    Alright, I'll be sure to use one of your paint thinner methods before my next race and from what yimmy said I can conclude that aerosol brake cleaner will work for a quick sub-par clean. Thanks a lot!
    Simple green works great and it is also biodegradable....though paint thinner burns pretty....
    Dawn dishwashing liquid.
    Reputation: 006_007's Avatar
    biodegradable degreasers are funny considering the grease that you wash off is still going down the drain.......
    "biodegradable degreasers are funny considering the grease that you wash off is still going down the drain......."
    Are you serious?....wow...the implications....screw it....I am just going to start using paint thinner and dump that down the drain as well!!!
    Chain Degreaser
    Since I was 14, I have always used Diesel Fuel for a degreaser. Enough to cover the chain in a container and shaken. Let stand, and it can be reused. Cheap even at to days preices.
    Like I said above, and DHHogan mentions before me... diesel, gasoline, paint thinner, mineral spirits can all be re-used. Clean your chain or bearings in it a few times, then pour it through a coffee filter.
    I do use simple green for anything that I want to spray on, scrub & rinse. But it's nowhere near as effective if you just want to shake & dry.
    -james
    2000 Trek 6500 HT
