Results 1 to 13 of 13
    May 2012
    Decent used suspension fork for under $100?
    I'm looking for a decent suspension fork for about $100. It can be used, a takeoff, doesn't matter, as long as it's in good overall condition.
    Thanks.
    Living the High Life
    Reputation: Ithnu's Avatar
    Feb 2007
    A fork, shock, or frame?
    May 2012
    Sorry about that. A suspension fork.
    Feb 2007
    I'd suggest going to craigslist and set the max at $150 and search for "Rock Shox" "Marzocchi" or "Manitou". Fox suspension really doesn't make anything cheap.
    I live in Denver and here's what came up for me. denver bicycles - all classifieds "rock shox " - craigslist
    Depending on what you're using it for there seem to be many options, try near wherever you live.
    Former Bike Wrench
    Might be able to find a lightly used Dart 3 for under $100
    Least expensive new Rockshox you will find.
    RockShox XC28 Fork 2012 at Price Point
    ~ 2011 GT Avalanche 2.0
    ~ 1993 Diamondback Topanga
    ~ 2012 Diamondback Overdrive Expert
    Reputation: adonis_abril's Avatar
    Jun 2012
    Yeah, you can probably get an older Rockshox on Craigs and I suggest Ebay too. I found a 2008 Rockshox 351 recon u-turn coil with adjustable 85-130mm travel for $140.
    Mar 2012
    $80
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I see Rockshox Tora forks go in the low $100 range. That's the cheapest of the 32mm stanchion forks. Skip the Dart forks. They are only 28mm and really heavy.
    I personally like the 302 Rockshox Tora on my iron horse; it's lightweight, durable, and looks/sounds cool
    Quote Originally Posted by Luclin999 View Post
    Oh wow, that is good to know. That is the fork that came on the Airborne Guardian that I almost went with, but decided to go the next step down with the Airborne Skyhawk. So if I find that the Suntour fork on the Skyhawk is really that bad or it breaks, I can get the same fork that came with the Guardian for about $100 and still be at less total cost.
    EDIT: Just found it slightly cheaper on Amazon: Amazon.com: RockShox XC28 - Coil 100mm 26-Inch 9mm (Black): Sports & Outdoors
    Jun 2012
    Quote Originally Posted by xceebeex View Post
    It's not quite the exact same fork...the Guardian uses the 29er version
    Quote Originally Posted by adonis_abril View Post
    Well, yea, but I figured that would be pretty obvious that they would be slightly different since the Guardian has 29 inch wheels. The 29 inch version wouldn't do me much good on a 26 inch bike It is still an XC 28 though.
