Results 1 to 5 of 5
    May 2013
    New question here. Cube Analog Disc 2012 upgrade (crankset, bottom bracket, tyres, saddle, mudguards)
    Hello everyone! I've bought a Cube Analog Disc 2012 last year. Now I want to replace and upgrade some parts. I don't really understand bike components on a decent level, so I seek your advice. Here are the parts that I want to replace:
    1. 9-speed crankset Shimano FC-M430 44x32x22T, 175mm.
    I scratched it pretty badly, that's why I want to replace it. I have nothing against a similar model, but, maybe, I can replace it with something more lightweight?
    I wonder if Shimano Deore M590 Triple Chainset 175mm - 22.32.44t - 68/73mm - Black will fit: Shimano Deore M590 Triple Chainset | Buy Online | ChainReactionCycles.com
    2. BB-UN26 bottom bracket.
    It emits a chirring noise... I want something silent.
    3. Schwalbe Smart Sam tyres, 26 x 2.25.
    These are too thin, I already had some punctures in the past. I would want something similar, but more protected.
    4. Scape Active 8 saddle.
    I would want something softer. This saddle is a real pain in the butt.
    5. Mudguards.
    SKS Velo 65 Mountain set doesn't fit - there is no hole in the front fork; front SKS Shockboard doesn't fit - cables in front of the fork get in the way. I wonder if any mudguards can fit this bike at all.
    I will be glad to hear any recommendations!
    I use and like SLX cranks .. Bike24 has good pricing on Shimano and Schwalbe tires.
    Bike24 - Shimano SLX FC-M660-10 Crankset 3x10-speed
    Pop the plastic cover and then the inner seal off and load each side of the bb bearing with grease. They come undergreased. Carefully work around the outside edge of the cover and the inside edge of the seal with the edge of a thin knife.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    1. If the only issue that you have with it is scratches, I would say keep it. Chances are you will scratch up another crankset down the road. If you hate the scratches, you can always strip the paint, polish them, and maybe clear coat them. I advise that you keep them until they are worn out. Going from M430 to M590 wont save you much weight anyways. If you are looking for a real upgrade you need to go with at least SLX cranks but I would go for XT/XTR. Right now you have a 3x9 drivetrain so keep that in mind.
    2. Follow EB1888's advice. If it ends up dying on you they are decently cheap to replace.
    3. What sort of punctures are you getting?
    4. You might not neccisarily need more padding. You might just need a saddle that fits your butt or to have that one set up properly. I use a Selle Italia Carbonio and a Specialized Phenom Ti for my bikes. They are thin and pretty stiff, but they fit me and are comfortable for a couple of hours.
    5. I have never used mudguards.
    May 2013
    eb1888, moefosho, thanks for the advice!
    Quote Originally Posted by moefosho View Post
    I damaged my bike's cranks with an old monkey wrench; I rarely get scratches when I'm riding.
    I'm afraid that SLX/XT/XTR cranks are an overkill for this bike. I also want to keep 3x9 drivetrain; and SLX FC-M660-10 is 10-speed, if I understand this correctly. I've heard that M590 are a bit sturdier than M430. I don't have any real problems with M430, so M590 should be a nice replacement.
    Ordinary ones, from glass and sharp stones. Usually I ride in the city and in parks.
    I will look into them, thanks!
    And I think I should forget about them too. Too much headache for nothing
    May 2013
    I figured out that a chirring noise is coming from Shimano FH-RM66 Disc rear hub. Please tell me if there is a noiseless rear hub that can fit my bike!
  1. Bottom Bracket/Crankset upgrade question
    By fbabrove in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2017, 11:56 AM
  2. Crankset/bottom bracket question....HELP PLEASE
    By nelsonccc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2012, 10:00 AM
  3. xtr 951 crankset 952 bottom bracket
    By zindog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2012, 07:51 PM
  4. Bottom Bracket/crankset compatibility
    By VandaL in forum Beginner's Corner
    Last Post: 03-28-2012, 11:50 AM
  5. Focus Fat Boy or Cube Analog Disc ???
    By sempr8 in forum Beginner's Corner
    Last Post: 05-20-2011, 08:17 AM
