Results 1 to 5 of 5
    Reputation: scubastud's Avatar
    Complete novice here.....How do you repair a flat tire???
    I've bought a couple of those cheap repair kits with an assortment of parts within the kit.
    What the world does each piece do?
    They appear to come with a tube of glue/adhesive, rubber patches, tire levers, and some metal ridged patches..........
    Please shed some light on the process and what exactly the function of each is.......
    Thanks.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Remove wheel from bike, remove tire and old tube from rim using the tire levers. Check for any sand, dirt, grit, needles, glass, whatever may be stuck in the tire and caused the flat, clean it with warm soapy water to make sure nothing's left.
    Place new tube in tire, put the valve stem where it belongs in its hole in the rim, then work the tire back onto the rim(I like using my hands more than a lever for this part). Inflate to desired pressure.
    A more in depth guide can be found here, along with pics:
    http://www.parktool.com/repair/readhowto.asp?id=100
    Thanks for the quick reply.
    I was more curious on how to make a repair 10 miles out in the woods.........like what's the steps in making sure the tube will hold air once again.........
    I've bookmarked the link you sent.
    Thanks.
    I post too much.
    Mar 2005
    The steps are pretty much the same, except your bike is likely to be upside down rather than on a bike stand.
    If you have a patch kit, simply replace the step of removing the old tube and putting in a new one, and change them to:
    Find the hole, wherever it is. Once you have, use the sandpaper in the kit to roughen up the tube around the hole to allow better adhesion of the patch. Follow the patch kit's instructions closely, some come with adhesive and some come with the glue seperate from the patch.
    College Boy
    Reputation: Timeless's Avatar
    I would advice getting some of the glueless patches They at a heck of a lot easier to put on than the ones that require glue.
    I have had really good luck with Slime glueless patch kit. All I do to patch teh tube is rough up the tube a little and then just stick the patch right on. Make sure it is down nice and good and put it back in the tire and I am good to go.
