Results 1 to 7 of 7
    Jul 2014
    Compatible Shimano Rear Derailleur
    Hello,
    I have an early 80's Ross MTB Hightech Mt Whitney 6 speed and need to replace my rear derailleur (which seemed to have changed a lot since I did my last repairs).
    My original derailleur was a Shimano Deore XT Rear Derailleur with
    Deore XT Unishift Control Thumb Shifters. The newer derailleurs seem to need ne shiftes (I think). Does anyone know what Shimano rear derailleur will be compatible with my current shifters? I have had no luck in finding out.
    Thanks so much
    Mar 2014
    shimano tourney TX55 might work with those shifters. It can also be used with friction shifting.
    2010 D440 Redline Rigid 1x9
    2011 Trek Remedy 8 1x10
    2012 Jamis Dragon 2x10
    2013 Diamondback Sortie 3 1x10
    Jun 2014
    MIght try contacting Shimano tech support. Worse comes to worse, some new shifters probably wont break the bank.
    Reputation: 70sSanO's Avatar
    Nov 2013
    I believe that your Unishift shift levers are friction only, so I would think nearly everything 9 speed and less out there will work, with the possible exception of a shadow derailleur as I think it has a different cable routing.
    I run 7 speed cassettes/freewheels/shifters with 9 speed derailleurs all the time. I just finished putting together a comfort cruiser for my brother with a cheap Sunrace 7 speed shifter to a Alivio 9 speed derailleur and a SRAM cassette.
    On own my bikes, I look for really nice/nos XT/XTR derailleurs out of the late 90's/early 2000's. Just run a 7/8 speed chain, I don't think there will be a chain issue as back in the 80's swapping out a 6 speed freewheel for 7 speed with friction shifters only required adjusting the stops and cable length.
    John
    1995 Trek 970 - 80mm Atom Race
    1992 Serotta T-Max - 70mm Z3 Light
    1993 GT All Terra - 46mm Mag 21
    (STOLEN)
    Nov 2013
    Here is a link to Sheldon Brown's wealth of technical knowledge...
    Articles by Sheldon Brown and Others
    and...
    6-speed, 7-speed, 8-speed, 9-speed, 10-speed, 11-speed?
    John
    (STOLEN)
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Shimano also makes a TX-75 that should fit. If your derailleur mounts to a hanger, make sure to get the 'direct mount' and not the one that mounts to an axle.
    Shimano Tourney TX75 6 7 Speed Rear Derailleur Direct Attach | eBay
    Any Shimano MTB 9 speed or less rear derailleur will work. Pick your price point.
  1. A list of Shimano XT and XTR low/normal/non rapid rise compatible rear derailleurs.
    By GottaGo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-19-2012, 08:45 AM
  2. Shimano XT SL-M770 10sp Dyna Sys shifter with RD-M780 rear derailleur - compatible?
    By jzt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2011, 09:50 PM
  3. Need help with Shimano 761 rear derailleur...
    By In-Yo-Grill in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-29-2011, 05:48 PM
  4. Shimano rear derailleur for '01 NRS?
    By SkaredShtles in forum Giant
    Last Post: 06-14-2011, 01:03 PM
  5. Revoshift 6sp compatible rear derailleur?
    By spaniardclimber in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2011, 11:42 AM
