Page 1 of 3 123 LastLast
Results 1 to 100 of 216
    Reputation: Fuglio's Avatar
    Cool-blue Rhythm Cold Weld Frame Repair!!!
    My chain-stay cracked after one too many drop to flats
    <a href="http://s34.photobucket.com/user/mrpea9999/media/bottemout.png.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/bottemout.png" border="0" alt=" photo bottemout.png"/></a>
    <iframe width="560" height="315" src="http://www.youtube.com/embed/f6kS8eiS47k?rel=0" frameborder="0" allowfullscreen></iframe>
    mushroomdrop - YouTube
    <iframe src="http://player.vimeo.com/video/67911462" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/67911462">Fuglio..</a> from <a href="http://vimeo.com/user1614227">RCC</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    <iframe src="http://player.vimeo.com/video/65557379" width="500" height="333" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/65557379">Zach landing like a freight train to flat, 1st attempt</a> from <a href="http://vimeo.com/user11433027">cabracadabra</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    My frame rebelled against the poor treatment from me and developed a crack. Threatening to hurt me as well if i continued my abuse.
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0621132234.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0621132234.jpg" border="0" alt=" photo 0621132234.jpg"/></a>
    With no money and no welder connections. It looked like my drop to flat days were over, if i couldn't fix the frame myself.
    I decided to use an ancient hillbilly technique of "cold welding"
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0621132358b.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0621132358b.jpg" border="0" alt=" photo 0621132358b.jpg"/></a>
    I coated the chain-stay with the paste.
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0621132328a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0621132328a.jpg" border="0" alt=" photo 0621132328a.jpg"/></a>
    Then i braced the top and bottom with two pieces of steel. I then secured the mess with steel hose clamps
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0622131323a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0622131323a.jpg" border="0" alt=" photo 0622131323a.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0622131323d.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0622131323d.jpg" border="0" alt=" photo 0622131323d.jpg"/></a>
    Since i was working on my bike i decide i might as well true the wheel before it brakes too.
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0622132243-1.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0622132243-1.jpg" border="0" alt=" photo 0622132243-1.jpg"/></a>
    Do you like my "truing stand"? like I said no money...
    Ill report back with a ride report on the new cold weld technique, but I suspect I wont have any issues.
    Wish me luck
    Fuglio
    You say you don't have any money, hopefully you have good insurance.
    OG Ripley v2
    Carver 420 TI
    IMO,
    All you really did was hide the crack, and thus make it harder to see how much worse it is getting.
    If it doesn't become visible, expect a catastrophic failure somewhere in the future.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    You created several new stress risers in the repair attempt.
    Quote Originally Posted by bikeabuser View Post
    IMO,
    no way cause if it cracks below the chain stay will have to flex and if that happens the jb weld will crack
    Quote Originally Posted by Dirty $anchez View Post
    what are these things you speak of??
    AZ
    AZ is offline
    Quote Originally Posted by Fuglio View Post
    Areas where the stresses will be concentrated instead of being spread out, namely the ends of the angles used in the repair. With the stress concentrated at the ends there will be a higher likelihood of failure at that point, the angles will also tend to act like a giant shear, possibly tearing the stays in half at either end. At the very least the localized forces are likely to form cracks at those points so keep a very close watch on that repair.
    Says the man who is confident in his repair. Good luck.
    OG Ripley v2
    Carver 420 TI
    Time will tell, but I'll add that you really haven't fixed anything, even if you did hide the problem well, and possibly shift it as D$ has pointed out.
    Keep a very close eye on things, and expect the worst.
    JB Weld isn't designed to do what you have done with it, and it is no where near as strong as that frame tube is, in tension or compression.
    http://forums.mtbr.com/frame-buildin...ame-97168.html
    Will "JB Weld" work for my bike frame?
    The cold weld is just to hold the steel braces in place...... the crack grew about 1/8" on one ride so i think the stress area was all ready concentrated. ... time will tell but not much time i got a new huck to flat i built and haven't been able to try out yet since i was worried about my frame braking so next weekend ill know for sure
    AZ
    AZ is offline
    double facepalm
    dru
    dru is offline
    OP, you can do a bit better job than that, and maybe even avoid death or severe injury with a little bit of carbon fiber cloth.
    You've already got some epoxy in the form of the JB Weld.
    Cut all that crap away and start again using epoxy and several wraps of carbon fiber.
    Wrap all that up with electrical tape to squeeze out excess resin and to ensure the resin has fully saturated the cloth.
    The swing arm is toast btw, since the aluminum has fatigued. Welding will only weaken it further since the heat treating will be lost.
    One more thing, drill out the ends of the crack, before re-repairing.
    Drew
    occasional cyclist
    Just go hit a square curb a few times, and don't blame us ... We warned you !
    Quote Originally Posted by dru View Post
    Drew
    Agreed ... So why even bother ?
    At best it's a band-aid on a severed carotid artery.
    dru
    dru is offline
    I'm trying to save him from getting hurt.
    Done properly the repair I suggested could last a long long time.
    What he's done isn't safe at all.
    Obviously my best advice would be a new swing arm.
    Drew
    occasional cyclist
    Drew
    Understood, and I agree ... The OP really needs to spend some money at this point.
    No replacement parts available its a grey market frame that discontinued anyways. 2006 .
    Im kinda dis hartend. Really thought i would be impressing people with my ingenuity.. ...
    Frame was a loss before ... i at least streached it out for normal duties till the end of the season..
    No more drops to flat on it... sucks really thought i had the thing fixed thanks for talking some sence into me.
    Good news is that my friend will letvme borrow his highline to de virginize the drop. Then illbat least have a landing spotted to build up.....
    Time to start saving up....
    Wanted to be optimistic but this time its better to be realalistic....
    You guys suck im all bummed now
    Reputation: Mark in Baltimore's Avatar
    Better to be bummed and have us seem like we suck than to have a bike part jammed in your body when that ghetto repair fails.
    '12 S-Works Stumpjumper carbon HT
    '13 Specialized Carve Comp
    '94 S-Works M2
    Quote Originally Posted by Mark in Baltimore View Post
    No
    I think its fine for regular riding .. rollers... drops with transitions .. fast rocky shit.....
    Asking it to handle a hard bottem out is to much.
    Reputation: NFLcheesehead1's Avatar
    Sep 2012
    Aww man, I was looking forward to you nailing the drop on the bike and proving everyone wrong...
    "Let us not become weary in doing good, for at the proper time we will reap a harvest if we do not give up." Galatians 6:9
    Reputation: elcaro1101's Avatar
    If it were my frame, I wouldn't be riding it at all. Others have posted above the details of why, I can only add that I see it the same....very dangerous. To say it can/cannot take x/y/z types of riding is just asking for a really bad crash caused by total failure.
    AZ
    AZ is offline
    Okay, the OP is now posting this in other forums as advice as a suitable fix. Please stop, this is as ghetto a repair as there ever was and should not be used as an example of a repair.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    I found this mentioned somewhere on the interwebs...
    "JB lists its strength at 3960 PSI, which is a little stronger than the
    best values for wood but less than bamboo. So it should be OK for a
    spruce, yellow pine or oak bicycle frame but inadequate a frame made
    of high-performance bamboo tubing."
    You really should test it out on a pine bike before you risk life and limb.
    No
    I'm not trying to be rude, but your saying you think your repair is fine when you didn't have the basic knowledge to drill the ends of the crack.
    You really don't have any idea of what you're doing and slapped this half ass repair on your frame and calling it all good.
    I just hope you don't end up in the hospital.
    OG Ripley v2
    Carver 420 TI
    Join up and link back to this thread
    Total Goober
    Best line I have seen on MTBR. My new sig, me thinks...
    Quote Originally Posted by dirt farmer View Post
    .. the jb weld is there to keep the steel braces and hose clamps together...
    You guys may be right and i agree its not suitable for hard flat drops but ill keep it on and report back....
    i might hurt my self. ..... but it is mountain biking i get hurt all the time
    Jan 2013
    Oh hell no, this is a very bad idea. Now go ride that thing and have next of kin report back.
    Reputation: mizzaboom's Avatar
    Jun 2010
    Holy shyt...
    There are a bunch of people in here giving you solid feedback on the integrity of this "repair" and I sincerely hope you listen to them, OP.
    Why you would post this in the Beginner sub is mind blowing -- PLEASE anyone reading this don't do it.
    All good things in all good time
    A few days of time to test the theory of repair integrity, but not having done so ... Hmmm.
    Maybe we're getting through
    OP,
    Are you still alive ?
    I built a 3 foot drop to flat in my back yard ill post vid tommorow...... i wanted to give the cold weld time to cure......
    Cure Time 15-24 Hours
    J-B Weld | Original Cold Weld Formula Steel Reinforced Epoxy
    Strength 3960 PSI
    I'm not going to encourage you to get hurt.
    Take a rubber mallet and smack it real hard
    The rubber mallet is for fixing flat spots in my rims.
    So i get a vid up of my back yard test .. then depending on the status Ill be taking it to Angle fire this weekend!!! Sweet
    Sep 2012
    ^Sweet! Can't wait to see the vid...hopefully you prove some people wrong!
    Jan 2013
    Please don't, your frame flexes, epoxy (what JB weld is, "cold welding" is an entirely different beast) has no flex. This WILL catastrophically fail.
    Quote Originally Posted by NFLcheesehead1 View Post
    Hopefully he doesn't get hurt.
    Sep 2012
    Yeah, hopefully we hear back soon...I would definitely wear a helmet, probably a cup too
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    OP, you are beign irresponsibly STUPID, telling other people to actually go ahead and do this on other threads. Your actions go beyond trolling and could actually do bodily damage to other people. Go on and seriously hurt or kill yourself with your moronic "repair" if you so wish, but dont con others into doing it.
    If he's really not lucky, he'll be out a frame, rear wheel, or leg, as he attempts to keep riding an unrepairable frame
    If i loose the frame and rear wheel ill make a unicycle
    This is not a question of if the bike will fail but when. It may not happen for a few rides or a few months, but when you go bombing down a fast downhill or off of a drop, I can guarantee that the bike will crack even further.
    Surprised you didn't use hot glue.
    '94 S-Works M2
    Don't be silly, hot glue doesn't have Weld in it's name!
    OG Ripley v2
    Carver 420 TI
    Uhhh ...
    1. All frames Fail eventually
    2. My frame was a loss. (I had no options to fix it legitimately)
    3. I don't actually think I fixed my frame, I'm just trying to stretch its life to the end of the season
    4. The JB Weld isn't doing anything(The steel splints and steel hose clamps are doing all the work)
    5. If I used hot glue it would have been a "hot" weld and not a cold one
    Good job!
    First, I know this is a very poor test. The weekend is coming and so is Angle Fire!!!
    <iframe width="560" height="315" src="//www.youtube.com/embed/wvCBLI885xw?rel=0" frameborder="0" allowfullscreen></iframe>
    before
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0626131901a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0626131901a.jpg" border="0" alt=" photo 0626131901a.jpg"/></a>
    After... no real surprises yet
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0626131848.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0626131848.jpg" border="0" alt=" photo 0626131848.jpg"/></a>
    Reputation: Stillraining's Avatar
    May 2013
    Where are you located...for the price of the JB weld and the two hose clamps you probably could have bought a new 18" section of tube and you could have found a guy like me to tig weld you in that new section for a six pack of beer and a couple hours of BS time.
    Not dissing your bravado or you McGyver ingenuity just saying it helps to ask before you leap sometimes. There's good people out there willing to give of their time and talent. Just saying is all....Carry on.
    My ride...Pro Flex Beast
    Wife's ride...Diamondback DBR-XR8
    Ok, I'll be the first;
    That repair could possibly last a long time. Good luck man.
    (I'm not saying I would ride it, but I appreciate the effort!)
    the chainstay has a pivot point on it don't know if that matters.
    i think the braces will hold it together long enough to get some extra mileage. I was looking at used frames on pink bike and ill be able to scoop up another drop to flat bike before im done with it.
    i live in albuquerque beer is standard currency
    Sure you'll get some extra mileage ... I've been saying eventually, all along.
    The thing is, how bad might you get hurt when it does fail !
    Glad you're looking for a replacement.
    Sep 2012
    Nice vid, Looked pretty solid there
    Quote Originally Posted by abelfonseca View Post
    People dumb enough to trust every thing they read on the internet are probably not strangers to random bodily damage to begin with.
    Let us know when it happens again
    AZ
    AZ is offline
    Dain Bramage is terrible to witness, please for the love of dog at least wear a helmet.
    Im not going to wear a helmet in my back yard doing a "napolean dynamite" sweet jump
    Napoleon Dynamite - Sweet Jumps - YouTube
    <iframe width="420" height="315" src="//www.youtube.com/embed/1PhUAUsGuu4?rel=0" frameborder="0" allowfullscreen></iframe>
    Jan 2013
    Yea, cause ya know, a broken frame will only kill you on a trail.
    Seen plenty of broken chainstays, haven't seen anybody die from one.
    Willing to be nobody else has either.
    It can't be any weaker than early 2000s Specialized FSR stays. I used to break those things every few months, at best.
    Beat that thing to pieces!
    Quote Originally Posted by slapheadmofo View Post
    No kidding. Ive broken 1 chain stay and it wasnt bad at all.
    <a href="http://s1159.photobucket.com/user/Fuglio_Pea/media/2012-04-11_22-06-33_329.jpg.html" target="_blank"><img src="http://i1159.photobucket.com/albums/p624/Fuglio_Pea/2012-04-11_22-06-33_329.jpg" border="0" alt=" photo 2012-04-11_22-06-33_329.jpg"/></a>
    Not as bad as when i Tacoed my front wheel. That was a good wreck
    <a href="http://s34.photobucket.com/user/mrpea9999/media/2011-09-03_15-03-51_889.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/2011-09-03_15-03-51_889.jpg" border="0" alt=" photo 2011-09-03_15-03-51_889.jpg"/></a>
    and bracing a cracked chain stay may not be the safest thing to do, but im much more worried about the head tube cracking on my 80mm xc bike that i threw a 140mm fork on
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0128131536.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0128131536.jpg" border="0" alt=" photo 0128131536.jpg"/></a>
    now thats stupid
    AZ
    AZ is offline
    Boy, you're just full of well thought out mods aren't you? Don't answer, remember........
    Jan 2013
    I guess our values just don't line up. To me safety comes first, I've already been under the knife and it's not a pleasant experience I wish to repeat any time soon. I understand we all take risks, but I do what I can to reduce those risks.
    I wish you well.
    Yea that frame is sketchy as hell. BUT i learned the sound of flexing metel on it casing a gap jump. It was hearing that same sound from my other frame that gave me cause to check and find the crack i repaired
    Also
    Dont mind the back an forth shit talking. I enjoy it, but please come with somthing fresh. I last heard that duct tape joke 15yrs ago on the "Blue collar comedy tour"
    I wouldn't worry about that 140mm fork. The headtube area looks plenty beefy on that bike. You probably slackened the angle from 71 to 68.
    Quote Originally Posted by smilinsteve View Post
    I should just brace it with steel splits and jb weld.
    Na that frame is getting swapped with and NS Bikes surge. If the boat ever males it.. been waiting months
    Afric Pepperbird
    Mar 2005
    I've seen his horrible spelling, and questionable judgment calls - dating back to this old thread - and I must say, believe me, there's not much brain left to damage!
    Titanium junkie
    Reputation: Loudviking's Avatar
    Oct 2011
    All I can say is "WOW"!!!!!
    Climb into the sky, never wonder why - Tailgunner
    You're a Tailgunner
    Since this thread has devolved to a log of bad choices and poor judgement.......
    Heres the latest
    My getting too close to a camera shy reptile.. (i gave him a peace offering )
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0627132016d.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0627132016d.jpg" border="0" alt=" photo 0627132016d.jpg"/></a>
    Afric Pepperbird
    Mar 2005
    Heres the latest
    Did you pick up and dispose of said peace offering when you were finished?
    Fineshed what?
    Banned
    Re: Cold Weld Frame Repair!!!
    Please don't get anyone else killed. Don't mess around with structural work if you haven't got a clue.
  67. #67
    Quote Originally Posted by ehigh View Post
    anyone else?? what are you talking about??
    how often do you crash>? im just curious if you have a clue what your talking about.
    describe the scenario where the chain stay explodes and then i die. i want to know.
    Because in my mind it will happen like this
    Drop to flat bike breaks i keep falling most likely twist an ankle or tear my knee a little.
    on a turn. chain stay gives i wash out and eat shit just like every other rear wheel wash out
    through a rock garden chain stay breaks grabs rock and i land in the rock garden and (ouch)
    hauling ass on an open section probably the worst. a high speed otb not good.
    all these assume catastrophic failure that's sudden and severe. if the chain stay bends and flexes it will lockup the back wheel.
    if the frame is flexing or moving it will shatter the brittle jb weld
    most likely scenario is this
    I keep riding my bike till the end of the season (all be it not as rough as normal)
    then in the height of the Canadian winter i get another 400 2007-2010 used free ride from some canuk off pink bike
    and riiiiiiiiiiiiddddeeeeee into the sunset
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0627132007a-1.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0627132007a-1.jpg" border="0" alt=" photo 0627132007a-1.jpg"/></a>
    i really think a good portion of the people telling me ill get SERIOUSLY hurt if i wreck when my frame breaks have little experience wrecking or braking frames.
  68. #68
    Reputation: Jakerz's Avatar
    Jun 2013
    This thread gave me a good laugh lol! I actually took a sheet metal/metal working class for aviation mechanics and I can honestly say that repair goes against EVERYTHING a legitimate repair is.
    To the OP, these guys are trying to help you but it's your body to screw up in the end lol.
    Jake
  69. #69
    Quote Originally Posted by Jakerz View Post
    Jake
    How would you have fixed it?
    Like i said earlier at first i thought i done good.
    Its definetly not a UL listed repair but its good enough
    Wish me luck at angle fire that will be the real test
    More pics and vids to come wish me luck ill report back on sumday homies
  70. #70
    Without knowing the series of aluminum that was used, I'll say ... A proper fix would require a TIG welder, and a heat treatment process ... And it wouldn't be worth it, when compared to replacing the cracked component.
    Welcome to the negative of an aluminum frame ... When they get damaged this way, it's best to send it to the recycling center, and get another one.
    To give you the short answer to the question "How would you have fixed it? "
    I wouldn't !!
    It's a structural component that just isn't worth repairing.
    Replacement, Replacement, Replacement !
  71. #71
    Also,
    Your continued reference to getting hurt being part of MTBing ... Well, yea, it does come with the territory.
    But your insistence in riding failed components, that are held together with hose clamps, well ... I'm reminded of a phrase by Forrest Gump, and I'm not thinking about chocolates
    Best of luck at Angle Fire.
    Hoping that when the full failure occurs, it is nice to you, and realizing that saying "Ride Safe" has no meaning in your World.
    BA
  72. #72
    Reputation: DenDerWuz's Avatar
    Jun 2013
    First post and all, I love these type of fixes and I'm rooting for the OP, however you should heavily consider the advice given as it is all sound and will improve your situation.... BTW can you help me repair my Ironhorse?
    "Ride like they are on your six!"
  73. #73
    Also,
    BA
    Lol it really doesn't.
    I started riding about 3 years ago and it took 2 and a half years to find like minded riders. we are few and far between
    I appreciate your input and your courtesy
    the fix was always tongue in cheek and is more of an experiment then anything.
    However the frame is cracked and i am riding it on a world cup down hill course tomorrow. So i do trust the fix enough for that. If it brakes on me i doubt very much that the damage to my body would be worse then if i bit the pooch on some of the more technical features I've done. So I'm used to the risk. I'm not a very fast downhill-er. and honestly I'd rather have my frame brake at a resort then on a 45 mile all day "tour-DE-gnar" in the middle of the national forest.
    to me the risk isn't as great as some that have commented on this thread would believe. It just adds a tiny bit of spice to the ride know that I'm ridding a ticking time bomb
  74. #74
    Quote Originally Posted by DenDerWuz View Post
    how did you not die????????? OMG!!!!!!!!!!!!!!!
  75. #75
    "2 Wycked"
    Reputation: crazy03's Avatar
    Mar 2011
    Anybody else here reminded of the "Jeep Bike" thread?
    Hey OP, you're a pioneer in my book.....a trail blazer of sorts. Just wear a helmet and you'll be just fine.
    Ahhhh...Ahhhh....it's the hammy, it's the hammy!!
  76. #76
    Jun 2013
    Honestly it was the most gentile failure, kinda wish it was some crazy gnarly story, but I was truly blessed, I hopped a small root and when i landed the frame broke and the main ring contacted the dirt and slowed me down if it happen 5 min prior there would have been a good chance of me getting jacked up! That bike had stress cracks where the seat post hits the bottom bracket I was so focused on those I missed the one on the back of the bracket....
    Another pic.
  77. #77
    Sep 2012
    ^Looked like you were riding through mine fields
  78. #78
    Make light all you want, while death may be the extreme end, you could end up very seriously injured and you know that.
    Yes it's a risk we all take every time we ride, but there are degrees of risk and what you do to minimize them.
    Riding a frame that has been repair like that I'm sorry to say but just fall under stupid, you've drastically increased the chance of a crash, but hey it's your body, hopefully no one depends on you.
    OG Ripley v2
    Carver 420 TI
  79. #79
    Chew and apply as needed.
    DAMN !
    That sure looks like it was fun
  80. #80
    So what you're really saying is that you have a death wish, and you're gonna use a BROKEN bike to end your life, one day
  81. #81
    Quote Originally Posted by TwoTone View Post
    Beyond reason, anymore.
    Sorry OP, but at this point, you're insistence to throw caution to the wind, is earning you the award.
  82. #82
    Banned
    I didn't read your ill typed scenarios. I'm just saying, don't work on the bikes of other individuals. Don't provide structural work for others. Of any sort. If you want to take on extra risks in an already dangerous sport. You won't last.
    Go make some money. Go to school. Get a new bike.
    I rescinded my advice to take a welding course.
    Perhaps most disappointing about this is your disrespect to the frame itself. What you've done is ugly.
    Sent from my Desire HD using Tapatalk 2
  83. #83
    AZ
    AZ is offline
    Yes! Praise be to dog, do not ever pick up a welding lead. Please. And folks wonder why I ride alone.
  84. #84
    **** how did I miss this thread before! its only been created for some days but still... Fluglio is my hero, amazing repair, great mtbiker this fix inspired me to repair a frame with a broken top tube!
    Thank you Fuglio! Hopefully we get more videos of you testing your repair!
  85. #85
    Eggzacktiklee.
    If you BSed your head tube back on with that joke of a fix, it'd be one thing.
    But for chrissake people, it's a chainstay. Hundreds of them snap weekly. Nobody is dying. Get a grip.
    The OP seems to have a pretty realistic grasp of the risks and the quality of the 'repair'. It's mountain biking; IMO mastery requires both a set of balls and a sense of humor. Dunno why everybody's gotta try to project their fears onto others. 'If you're not as scared as I am, you're doing it wrong.' Errr...okay...
    Hope you kill that poor bike at AF. Hope your buddys get to see it happen, and it turns out funny. Hope you don't impale yourself on your broken chainstay.
  86. #86
    I'm guessing a few people see nothing wrong with driving a car that has bubble gum as a fix for a leaking reservoir.
  87. #87
    Killer b.
    Reputation: The Understater's Avatar
    Hey OP, what do you reckon the tensile strength of those hose clamps is?
    Posting on the basis that ignorance shared is ignorance doubled.
  88. #88
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by crazy03 View Post
    Ahh, twas a different time then. I fear the troll bubble burst with that thread, the likes of which may never be seen again in these hallowed halls.
    Troubling times in the MTBR kingdom, indeed.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
  89. #89
    Eggzacktiklee.
    I did my best but its still alive and kicking... THAT CHAINSTAY IS STRONG LIKE BULL!!
    Quote Originally Posted by The Understater View Post
    No clue but i added an extra one.. also coated the top with silicon so it wouldn't scratch me up when i crashed...
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0629131241.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0629131241.jpg" border="0" alt=" photo 0629131241.jpg"/></a>
    The frame held up very well through rock gardens, OTBs, and cased jumps on candy land. I rode the piss out of that bike just like always.
    I know the rear end was put threw the ringer ,I pinched flatted a tire with 60psi two different times. The last time was right at the top
    I was at the top of angle fire with no air in the back tire. I thought to myself "wouldn't it be cool to ride down world cup" Then my better judgement kicked in and decide to ride down a blue trail instead
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0629131708.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0629131708.jpg" border="0" alt=" photo 0629131708.jpg"/></a>
    poor rim. it all ready had 4 flat spots... so maybe at this point its just getting more round!!
  90. #90
    Quote Originally Posted by justamember View Post
    Excellent TR.
    Guess you won't be needin' the HL.
    freeway drop is coming...its a flattie . Ill end up putting a tranie on it to make it hardtail friendly. Cant wait till Wednesday.... Help me build the bike up. and help me hide it from my wife plz
  91. #91
    Killer b.
    You rode a 1.95 at Angelfire? What the hell man? Have you got a death wish?
  92. #92
    Lol i was hoping someone would catch that... i had it at 60 psi and still pinch flatted... Im starting to realize im very back heavy on the bike.
  93. #93
    So here is my Video.
    Seems like the world didn't want me to ride. Cracked Frame, pinch flats, Lighting closures, friends that couldn't make the ride. It was me against the world. In order to ride I would deny fate and push on.
    <iframe width="560" height="315" src="//www.youtube.com/embed/b7HXq8FeHbw?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
  94. #94
    Obviously
  95. #95
    Reputation: Haint's Avatar
    Someone was shot during your ride.
    I like Sand - I don't like Witches
  96. #96
    Quote Originally Posted by Haint View Post
    And hidden behind silicone and a hose clamp.
  97. #97
    Desparado...... the guys in this thred were calling for blood
    They wanted to see somone die . I felt i let them down so i had to give em something. Blood thirsty gouls they are
    <iframe width="560" height="315" src="//www.youtube.com/embed/b7HXq8FeHbw?rel=0" frameborder="0" allowfullscreen></iframe>
  98. #98
    Jan 2013
    Thats priceless!
    The silicone is the topper. Who gives a frak if my chainstay breaks at 30mph ripping through the trees and I eat it along with all of my teeth and break my hip, as long as I don't get scratched by a frakking hose clamp!
  99. #99
    That chainstay is fixed... all you guys were wrong.
    None of you knew what you were talking about.
    But now you know it works.
    Enjoy your crow pie.
  100. #100
    Fixed LOL
    I'm thinking you've crashed one too many times, or actually want to die on an already broken bike.
  1. Aluminum Frame: To weld or not to weld, that is the question!
    By Single Trak Mind in forum General Discussion
    Last Post: 08-14-2012, 09:31 AM
  2. Can I weld a frame with MIG/MAG or MMA?
    By car bone in forum Frame Building
    Last Post: 05-01-2012, 07:32 PM
  3. Trailer clamp on or off frame weld?
    By Dr.Zoidberg in forum Rocky Mountain
    Last Post: 04-12-2012, 11:30 AM
  4. How can I request that TREK smooth weld my frame?
    By Ice Cold in forum Beginner's Corner
    Last Post: 05-28-2011, 09:41 PM
  5. Repair a cracked weld
    By Prophet Julio in forum Frame Building
    Last Post: 04-26-2011, 06:27 AM
