For socks the only brand you should be looking at is Fits. Their performance trail sock is their go to biking sock, although for colder weather you may or may not want something thicker. I personally think the performance trail is just fine for cold weather riding. Other brands like Smartwool are nice and made of the same material (merino wool) but Fits is the only company that owns their own looms and factory (they actually used to make Smartwools socks for them) so their socks are much softer than the competition.
For base layer clothing you need more merino wool. Its the only thing I use for cold weather biking. Won't hold smell like a synthetic, is temperature regulating and unlike the wool most people are used to its soft. I personally like Icebreaker for a performance base layer. Smartwool is fine for base layers as well but I personally think Icebreaker has a better fit for high output activities.
If you need a little more than a thick base layer for insulation where you are at the only thing I would suggest would be the Patagonia R1. Its expensive for a fleece but the Regulator grid pattering really does make a difference and the athletic fit is great for riding. Only drawback is that it is a synthetic fleece so it needs to be washed frequently unlike wool which can last for a few rides before it needs to go in the washer.
For a jacket I wear the Patagonia Houdini over my base layer for ultra-lightweight protection if I only need minimal wind and water repellence. If the weather gets a little worse Ill throw on a lightweight softshell instead, like the Patagonia Simple Guide. Id personally stay away from softshells that are windproof as the ones I have used don't breathe quite well enough for riding, but I also tend to get hot pretty fast if Im being active even in cold weather.
I usually also take with me a warmer layer for when you're stopped. My personal go-to is the Arc'teyrx Atom LT, which is one of the best pieces of outdoor gear I own. Arc'teyrx is very expensive but also very worth it and will last a long time. Arc'teyrx uses Coreloft in their synthetic down products and I have found Coreloft to be the best synthetic down out there. It breathes unbelievably well and Arc'teyrx binds it to the inside of the fabric with glue so its not quilted, aka no cold spots. The Atom LT packs down to a pretty small size and weighs nothing. Arc'teyrx also makes the Atom in the SV (severe weather) form if you live in a colder environment and need something a little extra. Another good option is the Patagonia Nano Puff. It doesn't breathe quite as well as the Atom, when I go inside while wearing the Nano Puff I usually want to take it off as it gets too warm, where the Atom I can wear all day. But the benefit of the Nano Puff, something Patagonia doesn't advertise, is that its constructed in a way that makes it windproof even though it doesn't have a specific windproof layer of fabric in the jacket.
All these things should be readily available at any respectable outdoor store and if they don't have the specific products I mentioned they can always order them so you can try them on before you buy. Remember to support your local stores and not those big box names.
OP - There is some value in you being a little more specific about your needs. Since you haven't yet, I'll just give you some general info. When I first started getting into cold weather riding and asking these same questions I found this website and it was rather helpful.
Get some under armor spandex running pants and a spandex long sleve shirt and wear it under your normal clothing. If its super cold throw a thin fleece cap under your helmet.
I get most of that stuff clearance style from SierraTradingPost. MTB stuff can get trashed pretty quickly so I wouldn't pay big money for anything. The jacket should be breathable and have some sort of venting. For pants I like any sort of softshell fabric with fleece under them. I'm a big fan of cheap neoprene socks with thin wool liners under them for keeping my toes dry. Some sort of wicking balaclava under your helmet and you're in business.
Anything made with fabric from Malden mills is worth a little extra 'cause it's still the best on the market and they run the way an American company should.
No worries. A couple things I should mention though, the Patagonia R1 isn't really your only option for a midlayer, its just the best for riding (in my opinion). Smartwool last fall season started producing some merino wool-synthetic hybrid midlayers that are pretty good too, the vest they make could be a decent option. Also Solomon has some pretty sweet jackets for trail running that could be perfect for your outerlayer or a combined mid and outer layer. I have not used one of Solomon's jackets while riding so I don't have any personal experience with them but it is something that would be worthwhile to look at.
I second that motion! Underarmor has a line of ColdGear for use when it's... (get ready for it) ...cold. This gives you a comfy-warm feeling even if you have holes in your outer layers where the wind can rush in. Sometimes you may elect to just wear that and have a t-shirt or fleece over that. As far as pants go, I'm probably alone here, but I'll take a pair of sweatpants and pull the ankles up around the back of my knee, and voila! Capris! I hate capris, but they aren't a banana hammock, I don't care if they get messed up, and they don't get in the way of a crank like my gore-tex pants do. I also like to have my legs breathe really easily.
Or you could also get some disproportionately large gloves.
That's why I look for something in that line up, I cant stand tights unless I buzz the hair off my calfs and that is not fun either, not only that try getting a size 13 foot through tights. Big 5 has some deals on cheap stuff for winter might be last years inventory, snap it up and ride...
I used to ride in the wintertime in Illinois and found wind protection more important than layers. After riding for five minutes on a 20 degree day I was warm enough not to need insulating layers beyond my thick shell layer. I wore a full face helmet and ski goggles to seal out the wind. If you are going anywhere with a risk of being stranded by a breakdown then you'll have to at least pack more gear.
Don't overdress. Fifteen minutes into your ride you will be producing more than enough heat to stay warm in very cold weather. Just be sure to keep the wind off. We ride in the 30s with long sleeve jersey and breathable shell. In the 20s you'll want long pants (insulated spandex) and winter shoes or booties.
If riding remote locations maybe pack a fleece jacket in case of breakdown and you can't keep generating your own heat.
Well I didnt find a jacket to block the wind, strange cause it blows every day here. I only found/bought UA coldgear tights and some arm warmers. Have trouble finding jackets that don't cost $89 - $100 that will fit me and are long enuff on my torso.
The thought of over dressing is always on my mind.
I get most of my outdoor clothing at the Columbia Outlet store in the outlet mall in Vacaville, CA. You have to buy in tune with the retail cycles. That is, you buy summer stuff in late July when the Fall stuff comes in, fall stuff in September when the winter stuff comes in, etc. I've found that their more technical gear is good. I buy fleece stuff there and non-cotton shirts. I'll buy fleece gloves anywhere they are on clearance; I have two pairs with tags waiting in my closet now.
Dress in layers. A non-cotton tee for the base, a long sleeved non-cotton shirt for the outer; a wool or acrylic flannel shirt or polypro sweatshirt. No cotton anywhere. This is great for the climb. For the descent, a tight woven polypro fleece like "Windstopper". Maybe a polypro vest underneath if its cold. Polypro fleece long johns on the bottom, if necessary. In colder weather, I wear convertable pants so I can take the legs off if it warms up. Gloves with a windproof outer layer. Of course, a goretex parka or equivalent if rain or wet snow is likely.
Remember, clothing is equipment too and your life can depend on it in the wilderness.
Most of this won't help much where it's really cold; you'll need more layers and more technical gear. By the way, my Columbia outlet is on the way to the Rockville hills park for me but these outlet malls are all over.
My outfit is not that much different than layering for backcounty tele. The ski stuff is just warmer.
A light weight jacket, gloves, and a warm skull cap.
Or at least that's what worked for me yesterday when riding in the low 30s yesterday. Northern Kentucky area. Actually had on a base layer under the jacket but turned out to be too warm and started overheating. Rode home after work with just the jacket on, was up in the 40's though at that time.
Any suggestions for a good lightweight jacket with vents? Mine doesn't have any. Price range less than 100$
My rig for down to 20*, mostly road riding 'cause the snow is too deep on the trails, unless you ride the groomed snowmobile trails before they soften up.
No cotton!
Silk balaclava or fleece beanie under the helmet, crosscountry ski gloves, wrap around sunglasses. If its cold/nasty enough for goggles I'll go skiing. Long sleeve poly or wool base layer top, then 1-2 fleece layers depending on temp/wind. I like to have front zips so I can ventilate as needed. North Face, Patagonia are favorites. Gotta have a windproof top. Front zip for sure, pit zips can be nice. I have several that cross over from biking to skiing/climbing/hiking.
For leg warmth I start with a light poly or wool base layer (Patagonia) and add a heavier Patagonia R3 or R4 for warmth and wind resistance. I can usually still wear some loose fitting bike shorts over the leg layers.
I think the hardest part is the feet. Without going to some sort of overboot, I wear a thin pair of liner socks and then a mid weight hiking sock pulled up over the longies. Gotta leave the shoes a bit loose for circulation.
Fill up your water bladder or bottle with warm water or tea.
My clothing needs vary a lot, depending on where I'm riding.
On the road, I go much faster, at lower effort, so I get cold. On trails (small hills, constant effort) overheating is more often the problem. I imagine that, if you do a 2 hour climb followed by a 20 minute descent, you will overheat on the way up and freeze on the way down ... unless you add some clothing at the top.
I get by most of the time with Smartwool arm/knee warmers. You don't want to overdress. I use lots of lighter layers so I can shed if I overheat - maybe a base layer, regular SS jersey, and a light jacket on top and tights or warmers on the bottom. If its REALLY cold, I stay in
What about for my face? I have a couple different balaclavas but I wear glasses so it's not really a good situation. Would a full face helmet and goggles work?
Is it cold enough that you really need to cover your face on the uphills - or working your way through "broken terrain"?
Many full face helmets trap the stale air in front of the face, enough that your oxygen supply suffers on the uphills.
For the less extreme cold conditions, something that you can easily add or remove could be a good idea: a balaclava or Buff (microfiber tube) that you can easily put in your pocket or pull off of your face.
For the times where it is unpleasant to have your face uncovered. I thought it might be good as a windshield. A balaclava for me has been a pita use, sometimes even for breathing it seems.
Facial hair helps...but I hate facial hair. So I use an underarmor neck gaitor which does over some facial protection. It works really well combined with shades. Anyhow, this with a light jacket, long sleeve shirt and good socks works well for me ridding down to 30 degrees...wearing baggy cargo shorts only.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
