Results 1 to 30 of 30
Thread: Clipped Pedals?
    Nov 2013
    Clipped Pedals?
    Ok, first does "Clipless" unintuitively refer to pedals with clips?
    My bike came with flats and they have done me fine for two years, I've never tried pedals with clips. At a recent enduro event I photographed, there wasn't a single rider using flats that I noticed and was wondering what the reason for using clipped pedals is, is it just to stop your foot slipping off the pedal (I can only think of one or two occasions this has happened to me)?
    I'm a bit reluntant to give them a try without knowing I'll like them, as bytime you buy a pair of shoes as well, they're not that cheap. I don't like the idea of the eggbeater style ones I saw a lot of people using so was looking at something like these:
    This issue comes up all the time, the flats are working for you .Why are you thinking of changing? You can search box here to find the other treads on peddles.
    You can gain from using clipless the main advantage is u can use the up stroke to gain more speed; but that comes with time. Yes u will fall a couple times when learning or forgetting u are clipped in when coming to a stop. If u decide to try them practice in a grassy field so when u do fall it wont hurt to bad.
    The shoes u can find on sale on the interwebs (jensonusa.com) those are good pedals u found u can get them on amazon for pretty cheap.
    So its up to if you feel u want try clipless not for everyone.
    Nov 2013
    Had a look at some thread using search, I think the only way I'm really going to know is to try them. I foind those ones here in New Zealand for $109, everywhere else here is listing them at $250+ . Bytime I pay shipping I think amazon works out a little more expensive.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    what type of riding are you doing? like the other man said if flats work, why change?
    Fat-tired Roadie
    Nov 2007
    These threads often make my head hurt a little. First, some history:
    Clipless pedals are actually about a hundred years old - really! But I don't think they started to take over the market until some time in the '90s. Before then, any halfway serious cyclist used clips and straps. That's the basket things. BMX is old enough to have had some decent flats out, and cruiser bikes had 'em too. But they weren't really players in the serious road market.
    Riding in toe clips off-road sucks. But riding toe clip pedals without the toe clips sucks even more. Clipless pedals eliminate the toe clip and are actually different enough to have a name.
    I don't think that the mechanism retaining my foot to the pedal is actually that important to how much power I transfer, or how consistently. I think it's all about the shoe. Serious road, XC, and lately, some trail shoes have a very stiff midsole. The outer sole is the best the manufacturers can glue on, usually not actually very good. So keeping these things on a pedal without a retention mechanism sucks. For roadies, it was even worse - their shoes didn't necessarily have any tread at all. Still don't, in fact. Clipless pedals are more user-friendly than toe clips.
    Now, you get options. There are flat pedals with a ton of surface area and good grip. The shoe doesn't need to be as stiff and can have a regular sole.
    For myself, I still prefer clipless. I like my XC shoes, and I don't mind a little help staying on the pedals when things are getting sketchy. My shortest ride is an hour and I do a couple races a year running a bit under six. I really value my stiff soles, cants, and fancy insoles. And again, no objection to a pedal I can ignore.
    If you're curious, start with a good shoe. IME, retail on XC shoes worth owning starts at about $100. Not that they don't show up secondhand or go on sale, of course. Buy them locally, so you can try on a few. Plenty of people do fine with PD-M530s as pedals (I ride Time ATAC Aliums) so if you don't want to spend tons of money on that part, don't. I'm promising myself some carbon-soled shoes later in the winter, but I did fine on nylon for years.
    Reputation: Dresdenlock's Avatar
    I was riding with flats/platforms until the end of the summer and I can tell a huge difference with riding now...but I am riding XC...since the switch over I am able to ride up hills better and I have more power as well..I use to get left behind and now I am able to keep up with the pack...I wasn't a big believer in them but I am now.
    We Can't Stop Here...This Is Bat Country.
    Out Of Step.
    Nov 2013
    Thanks for the information, I've gone ahead an bought them, if I don't like them I'm sure I'll find someone that will take them off my hands.
    Going down to my LBS today to look at shoes, anything in particular I should be looking for?
    Reputation: Hairnet's Avatar
    Jul 2013
    Entry level Shimano mountain shoes kind of suck. I used to use a pair on the road and even then they fell apart. Try on different ones and choose whichever is most comfy.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Riley-NZL View Post
    If the trails you ride have little to no hike-a-bike then stiff soled shoes will get the most out of your clipless pedals and can help prevent foot pain on longer rides. If you do more hiking then a somewhat flexible sole with some grip is better, hard soled racing style shoes aren't much for walking.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Something that fits your foot. Everything else is just icing. Try on a few different models and see what's good to you. I would recommend picking up a pair of the multi-release SPD cleats (assuming you bought those XTs in your first post) and using those as your first set of cleats.
    Oct 2013
    Clips refer to toe clips + straps that roadies used to use to secure their feet to the pedals. Modern pedals use a cleat and retainment mechanism rather than toe clips, and are therefore called "clipless". However the the act of engaging the cleat has popularly been dubbed "to clip in", hence all the confusion.
    I have those exact pedals on my road bike. I like to be able to pull up on the pedal while accelerating from a stop or nearly coming to a standstill on a climb. And when I'm dead tired, I like the extra help to keep my feet on the pedals, and positioned optimally. I think the m530's that you show are easier to clip into (less prone to flipping) than the m520s that don't have the platform. For me, they've been a solid pedal.
    Fat-tired Roadie
    Nov 2007
    Re: Clipped Pedals?
    Quote Originally Posted by zebrahum View Post
    +1. Also, don't get a "casual" or "commute" shoe. I like a buckle, now that I have it, on the top strap. And straps as opposed to laces.
    Mar 2013
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Nov 2013
    Got my Pedals today, and got my shoes from my LBS yesterday, they were the cheapest they had at $160:
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    I had an older version of that shoe. Good beginner shoe. Stiff enough sole to begin out on. Good quality, but they didn't hold up very well to my riding. The velcro started having issues, especially the top strap.
    I would start out on the pedals with the retention at the lowest setting, so that you can get your foot out easily, or more easy. You can always get on the bike, hold yourself up against a wall or have a friend hold the bike, and practice clipping and unclipping. It will take a little time to adjust to, and yes, you probably will fall at least once while you are out riding, because you will forget, or not be able to clip out in time. This will change with riding though, so don't be discouraged. We have all done it, and I have mine on video to remember it by. If you don't fall at least once, you aren't doing it correctly.
    BTW - I no longer ride a mountain bike, but do still ride to commute to work and for fun. I still clip in. I have Shimano M520's on both of my bikes, and have a pair of entry level Shimano shoes with the ratchet strap at the top, and now a set of more commuter friendly SPD shoes. I don't know that I could go back to flats, nor do I want to. I prefer the feeling of being connected with the bike, and it really helps on the hills.
    The pedals turn, not just the left one, but the right one too.
    Reputation: jimibonz's Avatar
    Dec 2013
    [QUOTE=TenSpeed;10889049
    [/QUOTE]
    +1 on that. I have limited experience with clipless pedals on my road bike but the flats on my mtb just didn't feel right- sort of like that feeling I get if I drive a car w/out a seatbelt on. Anyway I've got those same pedals on my mtb and love them. The softest/easiest settings are very secure while being confidence inspiring at the same time.
    2013 Cannondale Trail SL2 29er
    2012 Cannondale CAAD10-4
    I can't help growing old but I refuse to grow up!
    Nov 2013
    Got about 5 mins of practicing with them in before breaking my rear shock :P The shock has been fixed and is on its way back so hopefully will get to try them out bit better soon. I'll try lowering the retention setting, I was using it at the default level hey come at. I noticed some pretty big gouge already in the cleats, is that normal?
    Dec 2013
    Start out at the easiest release settings and stop handicapping yourself.
    Dec 2013
    I just purchased a bike with Shimano PDMX7 pedals installed. Just wondering if there is a clip in conversion to convert them to flats? Sometimes it's nice to wear everyday shoes to go to the store or whatever.
    hmm don't think so. but shimano do a clipless pedal with a small platform around it for riding in regular shoes. I had a set on my last bike, great for a quick run down the road for groceries.
    Quote Originally Posted by bbc0 View Post
    There are several versions of these out there.
    I like my crank bro mallet DH
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    Realistically, any clip-in pedal can be converted to a platform with a little work and ingenuity (by mounting the proper clip to a piece of aluminum that has some form of traction adding surface - Skateboard Friction Tape, Nail holes punched in from the bottom, pop-rivets, etc.) even if the market has not created a commercial replacement yet. I was a late convert to clipless (relatively speaking) in the mid 90's and before that used a clip and double straps on my roadbike (through the front and back of the pedal) and half clips on my MTB. One thing that hasn't been mentioned is that both platforms and clip/strap pedals fix your foot in place which results in any twisting motion being absorbed my your knees. Maybe not a big deal (unless your north of 50), but I'm more comfortable with my current set-up than I ever was in either platforms or clip-ins. I ran Mallets until I started Cross racing then I switched to Eggbeater 3's and that's basically all I use now. Admittedly I don't see a ton of technical trail, but the EBs clip in so automatically, I don't really think about it and I can always plant my arch on the pedal to get through a tough spot. I mounted and dismounted hundreds of times with the EBs and never slipped off once. They may not be perfect for everyone, but I'm pretty dang happy with them.
    Picture Unrelated
    Jun 2005
    Nope, nothing you'd want to ride in longer than around the block. Those clip in platforms are made for test rides and anything you'd have that's similar would just rotate on you. It certainly wouldn't inspire any confidence.
    Spend a few more bucks and just buy a set of decent flat pedals. Keep your clipless pedals in the garage in case you want to try them later, but don't be in a hurry. There's no really good reason to ride clipless despite what everyone will tell you.
    Feb 2012
    There always has to be that one person that posts that tries to talk someone out of clipping in. I just don't get this. The OP and others want to clip in, and purchased the pedals and shoes. Why come here to discourage that?
    I see no reason to ride flats, but you don't see me in other threads crapping it up discouraging those looking for good flat pedals to ride on do you ?
    Reputation: hey_poolboy's Avatar
    I'm a clipless newbie. I've always ridden flats, but this past season started riding with more friends and riding more aggressively. Many times I found that even with good low heel technique I was wishing for more security. Clipless seemed like the next logical step to me.
    I picked up a pair of xt pedals and spesh comp shoes. Only been able to ride around town so far due to an ice storm, but really like the feel of it so far.
    You can always keep a set of flats around to swap for when you'd feel more secure.
    Sent from my DROID RAZR using Tapatalk
    since 4/10/2009
    Reputation: Harold's Avatar
    Not quite. Those plastic ones posted above DO suck, but if you want to do a casual ride without swapping pedals, you can toss on a set of these:
    Amazon.com: Winwood Decksters Platform Clip-Ons, without cleats: Sports & Outdoors
    I wouldn't keep them on the bike full-time, but if wanting to take the mtb out for an errand, or a family ride or something, they'd be a great option, and would last. Since they're metal and the cleat is separate and replaceable.
    Fat-tired Roadie
    Nov 2007
    Re: Clipped Pedals?
    Quote Originally Posted by TenSpeed View Post
    I prefer clipless myself. At least, on bikes I ride for sport - my commuters always got clips and straps. But I think zebra has a point. If someone gets a bike that happens to have clipless and his first question is how to use them with regular shoes, looking at better flats doesn't sound like such a bad suggestion.
    I sometimes think I switched to early myself. But I don't know if there were good flats with 9/16" spindles back in 1999 anyway. Probably, but the guy I rode with was my only source of information at the time, and he was all about clipless.
    Moderator Moderator
    I've been running clipless so long, I've still got an onZa sticker on my workstand. I prefer them strongly over flats for any sort of trail riding, including most DH (though if I had any sort of ability to jump, I'd probably like them more at certain places). The only time I find that flats really work better for me is skatepark/DJ/pumptrack type riding. Otherwise, I'd go clipess all the way for trails.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
  1. Clipped or Platform?
    By Badassbassangler in forum 29er Components
    Last Post: 04-27-2012, 10:22 AM
  2. Clipped in for the first time.
    By machine4321 in forum General Discussion
    Last Post: 03-28-2012, 04:54 PM
  3. clipped in?
    By drmajor in forum All Mountain
    Last Post: 12-12-2011, 04:21 PM
  4. Who has broken a chain while clipped-in??
    By highdelll in forum General Discussion
    Last Post: 05-02-2011, 07:45 PM
  5. Clipped or Un-Clipped
    By resqman911 in forum All Mountain
    Last Post: 03-18-2011, 08:30 PM
