Results 1 to 8 of 8
    Inspector Gadget
    Reputation: abeckstead's Avatar
    Feb 2012
    clipless pedal tension
    A few months ago I decided to give clipless an honest try. I bought some budget minded pedals and shoes so that I didn't have a huge $ commitment if it wasn't for me. Turns out I like them a lot more than I thought I would.
    I have the Shimano m424's (ones with plastic cage) and I notice I have a hard time keeping the tension even between both sides of the pedals and between both pedals (left-right). While not the end of the world... my OCD traits kick in and I want things even and balanced I do tend to pull my left foot out first a majority of the time, I think that explains why that side always has a more loose feeling. I keep cranking the tension up the left pedal, but it never stays even with the right pedal.
    My actual question is will some higher end pedals keep the tension more consistant? or is this just a part of clipless and everyone deals with it?
    Cow Clicker
    Reputation: wmac's Avatar
    Not familiar with the tension parts in that pedal, but my XTs stay tensioned.
    No, YOU don't understand. You're making an ass of yourself for all of eternity.
    Quote Originally Posted by abeckstead View Post
    I ride a pair of XTR pedals....
    I backed the tension all the way off on both sides a long time ago...every so often I have to clean them and away I go.
    May 2012
    I had the same problem. I switched to crank brothers pedals and the tension is always the same on both sides of both pedals. They aren't adjustable so you are either happy with the tension level or not. I find them easier to get in and out of than my spd pedals.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Do whatever you want, they're your pedals. If you want to crank the tension on one side to even out the feel, do it. I might offer that you could have more wear on one side than the other which could contribute to some of the difference in feeling, but what I believe is that manufacturing tolerances between springs is such that a click or two of adjustment is needed to make sure it's even.
    I think you're over-thinking things; do what you like best!
    Reputation: citiznkain's Avatar
    Jun 2012
    also keep in mind that your lead foot tends to be stronger than the other, similar to if your right handed, your right arm is a little bit stronger. both pedals could have the same tension, but one could feel tighter or more loose.
    Reputation: GreenCanoe's Avatar
    Oct 2012
    Sounds like it's a problem specific to those pedals. Even the cheap M-525 pedals hold their tension with no problems.
    "Faster, Faster until the thrill of speed overcomes the fear of death." - Hunter S. Thompson
    It could be your cleats are not exactly the same either...but I am leaning toward the pedal. Pony up for some better SPD's and you should be good to go.
