Changing 34t ring on casette with 36t or 38t?
Hi friends
I've bought a used great mtb with a 1x9 XT drivetrain. I love the bike and the setup but there are a few places on my regular loop where I could use a bit of a lower gear. I have a Shimano XT 11-34 and a 32t in the front. I dont wanna change the front ring cause I dont wanna loose my high gear for going down.
So my question is: Is it possible to change the 34t sprocket on my cassette with a 36t or even a 38t?
Thanks in advance!
Mat
There might be a replacement ,but derailuers can only take so many teeth . You can look what yours will take on the simano web site. If you went to 10 speed you couls go to a 36.
The Shimano HG-61 is a 9 speed cassette than comes in a 12-36 version, but its a lower end (heavier) cassette.
And then there's this:
38 Tooth Cog for Mountain Bike Cassette 38t Sprocket | eBay
With enough tinkering, all things are possible. Two more teeth on your largest cog won't help all that much. How big is your chainring? You may be able to get a bigger change that way.
Front chainring is 32T but I dont really wanna go down in size because Im afraid of loosing my high gear. I wanna go 10 speed but my drivetrain is good so I see no point in changing that now. I will do some derailluer research and change to a 36 or 38 on top. Thanks for the replys!
Do you really use 32/11? I can spin it out on the road... but it's mountain biking.
You could always go to a double or triple. There's a reason multi-chainring setups have been dominant for so long.
I would just purchase the cassette above. The HG cassette is really your only option for a 36 gear up top on a 9 speed setup. I run 32 front and 11/34 rear on my trail bike and spin out the 11 quite a bit. When you ride more, you will find it will be easier to climb, even in with the 34 rear.
If you go 10 speed eventually, I would suggest going to an 11/36 cassette with a 34 front ring. Your low gear will feel similar to what you have currently, but you will pick up some top end.
By bapski in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 07-23-2013, 05:15 PM
By brankulo in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 06-26-2011, 06:51 PM
By ILMTB in forum Beginner's Corner
Last Post: 05-04-2011, 02:56 PM
By drm31078 in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 04-12-2011, 08:11 AM
By STT GUY in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 01-24-2011, 08:45 PM
- You may not post replies
- You may not edit your posts
Forum Rules
