Results 1 to 13 of 13
    Jun 2014
    New question here. Change stem length to fit a MTB that's one size too large?
    I recently purchased a 2013 Cannondale Trail SL3 in their Large size. After my first ride, I'm suspecting that it may be one size too big.
    Even with the seat positioned as far forward as allowable, I can easily achieve full extension of my arms when sitting on the rear 1/3 of the seat with body leaning forward. In order to get some bend in my arms, I have to lean more forward than I would unconsciously position myself. More often than not, I find myself, instead, shuffling up to the front 1/3 of the seat. I went for my first ride yesterday and this morning, there's some soreness in my neck and lower back.
    To add to my suspicion, everywhere I've looked online (plus talking with bike shops) tells me that I should be riding a Medium (I am 5' 8'').
    I test rode a Medium today (not the exact same model, but the geo numbers are similar to my model's Medium size) and, to get full arm extension with the same forward lean, I had to sit just past the rear end of the saddle. Sitting at the rear 1/3 of the saddle with the same forward lean gave me slight bend in the arms (that's the desired, right?).
    I think the reach is a tad too much. For me, there's no issue with the standover.
    I don't want to be hurting my body unnecessarily because of a non-ideal fit on my bike.
    Since standover isn't an issue, would simply reducing the stem length do the trick of achieving the same kind of fit I'd expect on a Medium in terms of reach? Or are there other frame geo factors between the Medium and Large that play a role in rider fit as well?
    What it ultimately comes down to is whether I need a new stem or a new bike altogether.
    can u return it? how long is ur stem now? check a zero set back seat post if u need one, around 20mm u would be fine, anything above that u start changing the characteristics of the bike.. i think the handling gets affected when the bike is too big, u have to exaggerate some body movements to get certain responsiveness out of the bike
    5'8" you should not be on a large.
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    OP - can you post a side shot of you sitting on the bike in the current state? Your height is a bit off to be on a large, but that doesn't rule it out that it might fit you. Depends on your body, arm length, torso length, leg length, etc. What size stem is on there currently?
    The pedals turn, not just the left one, but the right one too.
    SP Singletrack rocks
    its better to be a long top tube with short stem then a short top tube with longer stem.
    Fat-tired Roadie
    Nov 2007
    Re: Change stem length to fit a MTB that's one size too large?
    Quote Originally Posted by eb1888 View Post
    At 5'8", I feel borderline.
    Between a medium and a small.
    Can you return it?
    While you can make a bike fit your body by messing with the stem length, it'll really mess up the handling.
    I held onto a too-big road bike for years because I got a good deal on it and then didn't have that kind of extra money for a while. Nice bike, but I could never set it up so it was easy to climb in a straight line and didn't hurt me. Handling is even more important off-road. You really need to be able to move both forward and back over the bike without running out of range of motion.
    Mar 2014
    If this bike is new from a shop def. return it. You never know how a bike fits till you get on it. I have two large bikes and two mediums all fit great. Im 6ft and if I went by every manufacturer's recommendations I would only ride a large. It you can't return you can adjust the stem length, seat position, and bar width. I just feel at 5'8 its going to be a stretch.
    2010 D440 Redline Rigid 1x9
    2011 Trek Remedy 8 1x10
    2012 Jamis Dragon 2x10
    2013 Diamondback Sortie 3 1x10
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    I'm 5'8" and ride a large (19") with a 90mm stem and 0 setback post.
    Can you share your bike, stem and post dimensions?
    Jun 2014
    New question here.
    Thanks guys for the replies.
    Hereís a pic of me on the bike:
    The stem is 90 mm center-to-center. The saddle is at zero set-back. The handlebar is 680 mm.
    In this pic, I have a slight bend in the arms. But I can easily lock out just by leaning back a bit. Since I'm relatively new to MTB, I'm not entirely sure what to expect in terms of the 'proper' riding position... maybe that's normal?
    Complete bike dimensions can be found here. It's the Large.
    Seat tube length: 18.7 / 47.5
    Top tube (horizontal): 24.2 / 61.4
    Top tube (actual): 24.5 / 62.2
    The shop is transferring in a 60 mm stem to swap. They say that itís all that is needed to correct the fit since standover isnít an issue.
    The shop guys are pretty cool and knowledgeable, but I'd like to get a second opinion from people who didnít sell me the bike.
    Iím really hoping I can keep it since I got a good deal on it. I wonít be able to find anything comparable in quality at the price with 2014 models.
    Ultimately, though, I don't want to be hurting my body because of a bad fit on the bike. That, and/or a compromised handling because of the resulting adjustments are reasons enough for me to overlook the 'good deal' and return the bike.
    Mar 2013
    That fit looks great to me. A shorter stem will make bike handling better I think.
    Feb 2012
    That looks like about a perfect fit if I have ever seen one. Was expecting something completely different. Let us know how the new stem is.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    It doesn't look too bad. My preference would be a little smaller, to get a more nimble bike.
    Leaning forward a little is quite normal. It puts the rider's center of gravity lower which makes me feel more in control.
    Can you move your weight back on the bike? When rolling on the bike, cranks level, can you get your backside behind the seat for riding down the steep spots? Or do you run out of arm length there? 30mm in stem length can make a world of difference there.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Fat-tired Roadie
    Nov 2007
    I hate when people post pictures of themselves sitting on bikes, leaning against a wall. I could pick apart your position, but I don't know if it's your position - what matters is how you fit on it and how it handles when you're riding.
    I like a 585-590 mm top tube and 90 mm stem. So sticking a 60 mm stem on your bike gives you and me about the same reach, but a different weight distribution.
    So the real question is how does it ride? I don't like stems that short, but some people on the site swear by them. I think a lot of it has to do with how you feel about flat to climbing singletrack. I love getting to the tops of things, so probably most of my time spent mountain biking is spent climbing. Of course I get a kick out of descending. For me, a medium has nicely balanced handling. I could see having a different attitude if I did all my climbing on logging roads.
    Here are some things to try. When you're coasting, put your pedals at 9 o'clock and 3 o'clock and lift your butt off the saddle. Try not to have any weight on your hands - really balance over your feet. Do you have to correct toward the front or back of the bike?
    When you're riding, do you have much weight on your hands?
    If you take your hands off the bars, does your bike become super twitchy? Do this without changing your position.
    How long do you need to keep this bike to feel like you got your money's worth?
  1. Replies: 2
    Last Post: 04-19-2014, 04:32 AM
  2. 2011 Large 5 Spot stem size?
    By crankarms in forum Turner
    Last Post: 02-29-2012, 05:36 PM
  3. Stem size on large rise frame
    By Jeddz3 in forum Cannondale
    Last Post: 10-03-2011, 01:45 PM
  4. Should I change stem length for lift service runs?
    By KrisRayner in forum All Mountain
    Last Post: 07-28-2011, 12:15 PM
  5. Stem length on SL Mojo Large
    By ricki1nz in forum Ibis
    Last Post: 02-14-2011, 05:50 PM
