1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
Results 1 to 9 of 9
    Reputation: ZeroSkillet's Avatar
    Dec 2012
    Chamois tight shorts, underwear or no underwear v.noob
    Just bought myself first pair of riding shorts Fox Giant Ranger mtb shorts, i was wondering if most of you wear the tights commando or with underwear?
    Sleek Jamis Exile Rider
    Reputation: MadMacMan's Avatar
    Mar 2011
    Sans underwear.
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    Never underwear.
    Except when not on the bike. Then? Almost always.
    Please.
    Reputation: Gasp4Air's Avatar
    Most folks say no underwear, and by all means try it. However, I wear non-cotton briefs to keep my junk tucked away and do not suffer chafing. My rides are relatively short though (1 to 2 hours), so all day epics might be different.
    Use it, use it, use it while you still have it.
    Fat-tired Roadie
    Nov 2007
    No underwear.
    But the primary problems with underwear are sitting on something that's bunched, sitting on something that gets waterlogged, or sitting on a seam. Cycling shorts didn't always have a chamois, especially back when it was actually a leather thing.
    Competent User
    Mar 2012
    When you put cotton between yourself and the chamois, you're negating the effect of that chamois, in terms of moisture wicking and comfort.
    It's like asking for chafing.
    Dec 2012
    Thanks for the insight guys! Will go commando ASAP! lol
    I just wear compression shorts (underarmour) under baggy soccer type shorts - no padding, no shammy and I'm fine. No chafing or other unpleasantness. My rides are short (1-2hrs) and I wouldn't be surprised if longer rides needed chamois/padding but for me, I'm good to go. I once wore underwear under my baggies instead of the compression shorts and it was much more irritating and uncomfortable.
    I wouldn't wear underwear under compression shorts.
    May 2012
    No underwear for best results, but you can probably get by with underwear for a time. If you have any discomfort or chaffing it is due to the underwear. The chamios should be tight to the skin and hold all the bits tightly in place. That is how they are designed to work.
    Joe
    2003 KHS Alite 4000 26" Hardtail - XC, All mountain, blah blah blah.. I just ride.
  1. Speeding Cyclist Found Naked with Underwear on Head
    By mtbxplorer in forum Commuting
    Last Post: 10-31-2012, 08:35 AM
  2. Best all mountain shorts - without chamois??
    By cesalec in forum Apparel and Protection
    Last Post: 06-28-2012, 09:23 PM
  3. Underwear for Fatbiking??
    By ak greeff in forum Fat Bikes
    Last Post: 12-10-2011, 12:25 PM
  4. Looking for UNDER shorts with a (really) good chamois
    By Porschefan in forum Apparel and Protection
    Last Post: 07-12-2011, 12:42 PM
  5. Used underwear vs. used bike parts.....
    By Smokebikes in forum North & South Carolina
    Last Post: 06-05-2011, 06:21 PM
Hot Deals
Contests
Latest Mountain Bike Articles
