Results 1 to 13 of 13
    Dec 2013
    Chainring repacment
    Hello, My bike came with SRAM 44/33/22t chainrings. I took off the 44 and put on a Race Face bash guard and replaced the chain once. I have bent teeth on the other two rings and straightened them out in a vice multiple times, but I think it's time to replace them. I cant seem to find a 33/22 setup anywhere. Race Face makes a 32/22 will this work? Is there anything else I need to be aware of? Thanks in advance for any forthcoming help.
    Are you replacing just the chainrings or the entire crank? Most 4 bolt chainrings with the same BCD (104/64) should work.
    Dec 2013
    Just the rings, and thanks for the quick response.
    Fat-tired Roadie
    Nov 2007
    Price a complete crankset while you're at it. Waste bothers me, but you may be surprised.
    You must have spectacular crashes to bend the teeth on the middle and inner rings with a bashguard
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    Quote Originally Posted by AndrwSwitch View Post
    Concur with one proviso. I recently replaced my Deore crankset with an XT 2X (the 3X was actually available even cheaper) for slightly more than the cost of aftermarket rings. On the up side, the crankset came with an external bearing set that I can't use but will probably sell. On the downside, the RaceFace rings I put on my last bike were much better than the factory XT rings they replaced.
    Dec 2013
    Thanks for the help guys. Actually I haven't really crashed hard at all, the stock drivetrain just seems to be junk. I broke the chain on the first ride, replaced the cassette after a month and have been straightening out the chainrings intermittently. Thanks for the complete crankset suggestion, I'll look into it.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I suppose it is possible to bend chainring teeth with forceful shifting under load.
    I don't know if this is the case here, but it is a possibility.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Dec 2013
    Hmmm from what I see here bending chainrings seems to be an uncommon occurrence. Well I'm 6' 3' 230lbs and this is the first bike I've owned with the 10spd setup. While at my LBS I questioned whether this type of setup would be robust enough for me, and they said it would be.
    Fat-tired Roadie
    Nov 2007
    What bike is it?
    Most chainrings are 6000- or 7000-series aluminum and relatively thick. But at the lowest end, I think chainrings stamped out of sheet metal might not hold up too well.
    chain rings are cheap and can be found on the bay in all shapes, sizes, and colors. FWIW, I'm 275, 6'5" and I build all of my bikes with old parts from CL and the bay and I've never bent a tooth on a chainring. A new set of quality rings should last you a whole season if you're a racer or last many years if you are an intermittent rider.
    Keeping the drivetrain properly cleaned and lubed will certainly prolong its' life.
    Fat-tired Roadie
    Nov 2007
    LOL, I bent a few when I was half your weight. Shifting under load can do it...
    Dec 2013
    Thanks again for all the helpful suggestions, I have been known on occasion to shift under load, lol. I do keep my drivetrain clean and lubed and I ride between 35 and 50 miles a week.
  1. CNC'd my own XX1 chainring
    By westin in forum SRAM
    Last Post: 12-19-2013, 10:09 PM
  2. CNC'd my own XX1 chainring 34T
    By westin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2013, 02:00 PM
  3. Chain jumping from small chainring to middle chainring
    By menusk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2013, 10:31 PM
  4. Replies: 4
    Last Post: 11-04-2011, 07:02 PM
  5. XTR 970 chainring
    By Ansible in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-15-2011, 10:37 AM
