Results 1 to 5 of 5
Thread: Chain Questions
    Reputation: Revivalll's Avatar
    Chain Questions
    I need a new chain for my GF Tassajara and I have a couple questions. 1. Are the chains at the dept stores any different/worse than ones at the LBS. 2. What size of chain do I need, are they all standard or what? 3. I was thinking of getting an extra link to carry around at all times in case I break one, is there a differnce in those? Any advice would be greatly appreciated.
    Ride the dream
    Reputation: EnglishT's Avatar
    Not all chains are the same - the number of gears you have will determine what chain you need.
    If you have 9speed (likely) you will need a 9/10 speed chain.
    Not being american its hard to make a statement about where you buy it from - but its possible to say that spending a little more on a stronger (but not uberlight) chain is a good idea.
    Personally, I'd very highly recommend the KMC X9 ti-ni chain (ok, its fairly expensive as non-superlight chains go, but very very durable, and should last a long time if regularly lubed up).
    With spare links - go for KMC Magiclinks
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I say grab a Shimano LX chain. Cheap, durable.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    The only chains I've seen in department stores didn't seem to specify how many gears they are for. This determines the thickness of the chain. I like the SRAM chains myself. I don't like Shimano's non-reusable pins, and the stock KMC chain had some sticky stuff packed on it from the factory that was a dirt magnet and a nightmare to clean off. Make sure you size the chain properly, most likely you'll have to remove a few links. See parktool.com for help if you need it.
    go to a local bike store, and you can get everything you need for under $2. i just had to replace a chain for the first time and i went to my lbs, and i told them what bike i had (one that they dont carry btw) and they gave me the proper chain, and told me to get a chain tool, and told me how to change it out, all in all it cost me like $23, and now i have a few spair links from shorteing my chan, and i have a chain tool, so just go to your lbs.
