Results 1 to 19 of 19
    Chain length for double crank?
    I had a 36/22 and replaced the 36t with a 32t, but can't find online how to measure the correct chain length on a double.
    On my other bike, I replaced the outside with a bash guard and figured I'd shorten the chain when I replaced it, but when I did the big big measurement, the chain would get jammed on the cassette when shifting multiple gears at once and I had to lengthen it a few links, so that didn't work lol.. So what's the correct procedure to measure the chain length on a double?
    Sent from my 831C using Tapatalk
    Park Tool Co. ParkTool Blog Chain Length Sizing
    If it is a full suspension then you need to do the big-big + 2 links with the suspension in the longest setting.
    Hmm. I never knew there was an equation lol.. I guess my teachers were right I will use algebra in real life
    Fat-tired Roadie
    Nov 2007
    I use algebra in real life but wouldn't use it for that.
    Jan 2009
    make the chain long enough but not too long. there is probably a way to calculate it but that's a waste of time. run the chain through the gears and derailleurs and make it long enough to clear the big-big combo on your chainrings and cassette.
    I get that and know how to do it on a 3x setup but when I did it on a 2x it didn't work so I thought I was doing something wrong. I looked online and didn't see anything specific to 2x setups.
    Fat-tired Roadie
    Nov 2007
    On road bikes, it's the same. I'm surprised it gave you trouble on your other bike. I'd look for some other cause. Maybe having a little more tension due to a shorter chain was making your rear derailleur do something weird?
    Derailleur was new and adjusted fine.. Added an extra 2 links I think and its fine. I could shift one by one, but shifting 3 gears at a time and it got jammed and didn't shift.
    I'm going to shorten my chain by a link to compensate for the smaller chainring.. I'll see how it measures first and go from there.
    Fat-tired Roadie
    Nov 2007
    SRAM or Shimano? Rear suspension?
    Sram x5, fat bike is the new one i need to cut, full suspension with new deore shadow is the one that wouldn't shift, but i added a link or 2 and its fine.
    Fat-tired Roadie
    Nov 2007
    Since you still have the long cage rear derailleur, if you wanted to be conservative you could just remove one link and call it a day. You could remove none and everything should be okay too. I'm not sure if chain slap is an issue on fat bikes...
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    While a longer cage is not as sensitive to a too long chain as medium and short ones, it's advisable to disregard cage length entirely when figuring out the proper chain length.
    It's "chain around the biggest front and rear, + 2 links".
    Doesn't matter how many cogs or chainrings you have, doesn't matter which derailleur you have, doesn't matter what size things are front and rear... Don't make it too difficult.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    the biggest mistake is people think "Plus 2 links" means one inner and one outer,... a "link" is actually 2 parts.. the inner and outer plates are one link.. so you need 4 plates added. 2 inner and 2 outer plates equaling 2 links..
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by thomllama View Post
    I think you may have that wrong, I'm pretty sure 1 link is 1/2 inch and 1 inner+1 outer link=1 inch (2 links).
    Maybe I'm the one who has it backwards though, during my entire career working on bikes I had never heard of, nor used the "big/big plus 2" method and only found out about it here on mtbr after retiring from that work.
    Oct 2007
    Quote Originally Posted by J.B. Weld View Post
    it's what everyone thinks,.. honestly I wouldn't have know except back in the day when I was building drag cars the aftermarket, high performance, timing chains were based on "links" for purchasing and I ended up with a REALLY long one as I counted plates not links.. was OK.. just made it 2 chains
    if you go to get SS chain parts you can actually buy "1/2 links" which are single sets of plates.
    here...
    Is your Mountain Bike Chain Trying to Tell you Something?
    though many of the manufacturers have just adopted the "1 link =1 plate set" as most people figure it that way. but even then they state when sizing they optimally want "2 links plus the quick link"
    really though, with chains.. adding 2 link sets (4 pieces of chain) is safer,.... you can always shorten it if it's too long....
    I'm pretty familiar with half links from working on old beaters "back in the day"
    Maybe I'm just misunderstanding your meaning but I do know that a 114 link chain has 114 pins @ 1/2' each. According to Park 2 links is one set of inner and one set of outer plates- Park Tool Co. » ParkTool Blog » Chain Length Sizing
    Also Sram- https://www.sram.com/sites/default/f...nual-rev-a.pdf
    So two links = one inch, right?
    Oct 2007
    no.. but yes.. again depends on manufacturer these days ... a "true link" is one inch.. but even like you've pointed out.. they state 116/114/112 links chain length which is plate count...
    but the original chain length theory of Large-Large +2 links should be Large - Large + 2 inches or 4 plate sets... again.. it's kinda gone by the wayside as the manufacturers have done away with it over the years to avoid issues/confusion and derailleurs are over sized to compensate as they will often do a good bit more chain take up then they are rated at.
    again.. toooo long is better than tooooo short
    I haven't seen any bicycle chain manufactures describe one link as anything other than 1/2 inch so to avoid any confusion it seems sensible to me to go by bicycle industry standards when describing a bicycle chain link, especially to beginners.
    Also every every bicycle chain brand I'm aware of specifically recommends adding 2 links in the big/big combo based on the definition of one link as 1/2 inch.
    I'm not disagreeing with you that too long is better than too short, I just think it should be clear that your recommendations go against those of component manufactures and repair websites such as Park Tool. I'm pretty sure I've went against their recommendations a few hundred times or so myself because as I already said I never used that method for sizing chains.
    Fat-tired Roadie
    Nov 2007
    I think the page that comes with SRAM chains recommend big-big +2 and actually shows a picture with one set of inner plates and one outer.
    I'd rather just count pins, since it's unambiguous.
  1. Replies: 2
    Last Post: 12-14-2013, 03:52 AM
  2. E*Thirteen Chain Guide on SLX Double Crank
    By Devin5836 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2013, 06:23 PM
  3. Shimano XTR 24T Chain Ring on a Double Crank
    By rideronthestorm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-06-2012, 12:30 PM
  4. Will a 9 speed chain work on new XT double Crank?
    By Rod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2012, 08:43 AM
  5. Will a 9 speed chain work on new XT double Crank?
    By Rod in forum XC Racing and Training
    Last Post: 02-04-2012, 06:24 PM
