Results 1 to 6 of 6
    May 2013
    Chain guide if going 1x
    Do i need a chain guide if I'm switching to a 1x on the front? My rear right now is 7 but may upgrade to 9 few months down the line.
    Thank you.
    Sent from my LG-MS870 using Tapatalk 2
    Total Goober
    You might try the All Mountain forum. Pretty sure I've seen it discussed there. I think the only peeps getting away without a guide have a clutch in the rear, and even then some need one.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    May 2012
    Depends. If you use a ring like the Race Face Wide Narrow, you may not need a guide or bash. It also depends on your rear derailleur. Check the drivetrain forum. There's a few threads about 1x setups.
    Reputation: Gouda Cheez's Avatar
    Feb 2013
    Quote Originally Posted by BigSteve in CO View Post
    This.
    May 2013
    Re: Chain guide if going 1x
    Thank u
    Not with your present chain ring. If you use a single speed chainring or one of these new wide-narrow rings and shorten your chain, there is a good chance it will work. Depends on how rough the trails are that you ride. I've got a couple of bikes that are working fine this way.
    Otherwise you can setup a BBG bashwich for a cheap solution.
  1. Bionicon C.Guide V.02 Chain Guide + Fuel EX 8?
    By DBackRider08 in forum Trek
    Last Post: 09-23-2013, 04:03 PM
  2. Proper chain guide/end guide for Kona HeiHei 100
    By texasdirt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-09-2013, 08:10 AM
  3. Replies: 4
    Last Post: 03-14-2013, 05:23 AM
  4. Bionicon chain guide - use on upper chain line?
    By phazeshifta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2012, 12:39 AM
  5. rohloff chain guide or other guide options???
    By nicolian in forum Nicolai
    Last Post: 05-22-2011, 02:06 PM
