Results 1 to 6 of 6
    May 2013
    Carbon frame assembly
    So my new bike is on the way and I'm super excited. It's a diamond back overdrive carbon expert, my first carbon frame and my first 29er. I've ridden and worked on bikes for over 10 years, but I don't have any experience dealing with carbon fiber. The bike has an aluminum seatpost and a carbon frame. I've read and it seem like carbon assembly paste is the first choice for the seat tube, and in a pinch I could use grease, does that sound right? or would grease be preferable for a carbon/aluminum interface?
    Also I haven't dealt with hydraulic disc brakes on a bike in a few years. I'm thinking that the brakes will come pre-bled and ready to go, and if they're not, the lever will be squishy/not firm right?
    I figure I'll make sure the headset got greased, but it's got a sram pf30 bottom bracket, can they be serviced? is it worth trying to pull it apart to grease the bearings in it?
    Seeing as this is my first new bike in a while, I'd like to do what I can to protect the frame/paint from scratches and dings, any suggestions on how?
    I appreciate any and all help, I hope to post pics and a review once I get some miles on it.
    Mar 2013
    Congrats on the new bike.
    I'm assuming you brought the bike complete and assembled.
    I wouldn't put grease on a seat post, use carbon paste. A little sachet will go a long way and are cheap to buy.
    The brakes should be pre bled and ready to go, may need to be bedded in. ( Did they feel squishy when you tried the bike out).
    If the bike is brand new it should be all greased up and ready to ride?
    For frame protection I used helicopter tape on the front of the down tube, the back of the seat tube, around the headtube junction where all the cables rub and a bit on the rear triangle where the brake cable rubs when the suspension moves.
    The tape is a pain to put on but does a good job.
    Have fun on the new bike
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    I know I'm not the only one but I have never needed carbon paste.
    Also it's imperative that you use a torque wrench of some sort and don't over tighten.
    Enjoy your new ride, let us know how she goes.
    Fat-tired Roadie
    Nov 2007
    Never assume. If you're buying online, check everything. Park Tool has a new bike build checklist that's excellent. You probably won't have to do everything on the list, but you should at least make sure it has been done.
    May 2013
    It's coming from the DB factory, they say it's 80% assembled, so I'm assuming the derailleurs will be on, and possibly the cranks. I figure most of what I'll need to do is deal with the bars/controls, put the wheels on and maybe set up the brakes, true the wheels a bit and of course make sure everything is tight and lubed.
    Redcoat
    Aug 2013
    Yeah it's only been disassembled to mail in the smallest package possible. It should be lubed already but it never hurts to lube again. Pedals, wheels, bars and away you go mate.
  1. New Specialized Carbon Stanchion Assembly
    By Kirk Pacenti in forum Shocks and Suspension
    Last Post: 11-10-2013, 09:06 AM
  2. New Specialized Carbon Stanchion Assembly
    By Kirk Pacenti in forum Specialized
    Last Post: 11-09-2013, 09:18 AM
  3. Rear hub assembly - Roval Carbon 29
    By rogerfromco in forum Wheels and Tires
    Last Post: 04-21-2013, 05:37 PM
  4. Carbon assembly paste
    By rtsideup in forum Tooltime
    Last Post: 02-10-2013, 06:11 AM
  5. Where does one get carbon assembly paste?
    By weirdwallpaper in forum Clydesdales/Tall Riders
    Last Post: 08-28-2012, 02:52 PM
