Can't remove thru axle on rear wheel
Hi all,
I'm new to the forum and am just getting back into biking. I got some flats this weekend and can't remove the rear wheel. It's a sunringle hub with a Maxle 12*142 thru axle. The quick release lever will fold out, but when I insert it into the groove to loosen the axle, it feels like it has been machined tightened, and it won't budge. It feels like feel like the lever it going to break if I put any more pressure on it. I'm sure I'm missing something, but I honestly can't figure it out. Thanks for any support.
lots of lube, be careful not to damage the dropouts..take it to a shop see if they can cut it, better pay for a new axle than a new frame...
<iframe width="560" height="315" src="//www.youtube.com/embed/94dMnuVYqbI" frameborder="0" allowfullscreen></iframe>
Try a search on the forum or on google and you'll probably see your not the first to have this issue. Here is one result of a search:
Help - Seized Thru Axle
I tried lubing it, and finally gave up and took it to my LBS. The mechanic said he'd never seen one so tight, but after several tries he was able to remove the axle. It broke in the process, so a new axle is on the way.
Thanks for your help.
dab a little anti seize on the threads for next time
By connolm in forum Singlespeed
Last Post: 09-24-2013, 06:01 PM
By eugenelt in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 08-22-2013, 01:50 PM
By Smdqt in forum Beginner's Corner
Last Post: 08-04-2013, 11:24 AM
Last Post: 07-13-2012, 03:35 AM
By digital.aaron in forum Beginner's Corner
Last Post: 05-29-2011, 05:27 PM
- You may not post replies
- You may not edit your posts
Forum Rules
