Results 1 to 11 of 11
    Reputation: moe.ron's Avatar
    May 2014
    Cannondale Trail SL 29 2
    Anybody else riding one? What are your thoughts? I really like mine but dont really have a clue what I'm doing. The shop I bought it from hasnt been much help with my questions, at least in the front of the house. The Techs are busy, I dont like bothering them if I can avoid it. I rode 4 or 5 different bikes before choosing this one. Well, circles in parking lots anyway.
    I am about 200 lbs and roughly 5 10. When I picked it up a few weeks back they assured me they set it up for my weight and not to worry about it, the forks would only need air at a minimum of once a month. The front fork seemed really mushy, I finally went and got a pump and found there was only 50 psi. According to the specs on the fork there should be about 120 psi for a fat slob like me. No more mushy!
    I have a tendency to lose traction on hills too, I will figure that out though.
    Mine is a medium, seems to fit pretty good but I am not sure I would know the difference. You could read about it for weeks.
    Its my first bike in many, many years. I have a lot to learn. I have no technique. Its not like riding when I was a kid...balls out, coast, balls out, coast... My 47 year old out of shape body cant ride like that for long! My riding is kind of like this post, all over the place.
    Anyway, just curious what others think of theirs. I did a search, the last specific SL 2 thread that popped up was from 2012.
    Reputation: Nubster's Avatar
    I don't have a Trail but an F29 and IMO Cannondale has some fantastic bikes. They do a ton of R&D and I'm sure you made the right choice with your selection.
    It sux that you don't have the best support from the shop you bought your bike from. Maybe show up with a 6er for the techs and I'd bet they'd be more than happy to help you out with your concerns.
    Traction, that could be tires or technique or both. Just make sure you get some weight shifted over the rear wheel but not too much or the front will lift. It's a balancing act. Spinning rather than mashing can help too, if that's possible. I know when starting out...even in the lowest gear I would still have to mash rather than spin. That will come in time with better fitness, if you are in the same boat that is.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Must mash in the lowest gear when starting out? No real reason for that. Low gear is so damn slow on a trail triple, someone at twice his weight can spin up the steep sections, like me.
    OP: Did you try a large while you are there? Most of us 5'10ers are towards the high end of a large frame. 6'1"-6'3" seems to be when an XL frame is a must. You certainly can ride a medium, but if the saddle to bar distance is too short, your breathing will be restricted and you will overwork your arms on the trails. What is your inseam?
    WTB Nineline, 29X2.0" is your tire. Wider tires would help with traction. Air pressure also influences traction. You could run the rear at 30-32 and the front at 26-28 and see if you don't get rim hits or rollover in the curves.
    Nobby Nic Performance 2.2s are one option of a higher volume tire.
    Quote Originally Posted by Flamingtaco View Post
    Not everyone runs a triple and I didn't go look at the bike specs to see what his bike had. It was just a suggestion that spinning helps rather than mashing and some people aren't in the shape to spin, even in a triple granny gear, believe it or not.
    Kona Big Unit SS
    Mar 2014
    For sure spinning is always the most energy conserving and controlled way to climb. The rear tire will never slip when weighted with you in the saddle no matter how smooth the tire. As for the fork if it was properly set up and in a short time lost that much air there may be a issue with the fork.
    Fat-tired Roadie
    Nov 2007
    I'm having problems with my smart phone and I'm almost at work, so I'll keep this short.
    Google "peter white fit" and set your bike up to fit your body. If you prefer mountain biking, try to do a lot of your test riding on the trail - it'll change your results.
    Learn to spin at least 90 rpm. You don't have to do it all the time, but you really need to have it available as a tool.
    Learn to climb cleanly out of the saddle. I usually shift up 1-3 gears when I do this - it's a much slower cadence. That also makes it useful when I run out of gears.
    Good luck!
    May 2014
    I actually rode a large first. After that I went to several other stores in the area and tried a variety of brands and sizes. To me it felt like the mediums fit better but I didnt much care for what I rode or it wasnt within my budget. The cannondale also seemed to have the best mix of components and bang for the buck in my price range. I didnt want to spend a bunch on upgrades until I knew I was going to enjoy and stick with it.
    I went back to the first shop and tried the Cannondale again in a medium, the large wasnt bad, but the medium felt a little better. The guy in the shop nudged me towards the medium too.
    Thank you all for the input. I am going to air down a bit and adjust the seat to see if I can get a little more room.
    Fat-tired Roadie
    Nov 2007
    I'm 5'8" and ride mediums with about the smallest non-weird stem for my bar width. 5'10" on medium sounds pretty good to me. It's not going to result in much more reach, by the time you're in a riding position, or much higher a saddle or bar position.
    Since you rode some larges, I don't think you need to second-guess yourself.
    Jun 2013
    I am 5'11" and ride a medium Trail SL2. I'm about 315 geared up and ride with 150psi in the fork. That is still well below the maximum pressure. I check fork and tire pressure before every ride. I upgraded the wheelset and went to a single 32t chain ring up front but everything else is stock.
    Reputation: Trail_Blazer's Avatar
    May 2012
    I had one and it was awesome!
  1. 2013 Cannondale Trail SL 2 (26er) or 2014 Cannondale Trail 5 (29er)
    By quickmammoth in forum Beginner's Corner
    Last Post: 07-06-2014, 08:02 AM
  2. Replies: 0
    Last Post: 08-25-2013, 09:37 AM
  3. please delete
    By discohospital in forum Cannondale
    Last Post: 07-20-2013, 01:54 AM
  4. 2011 cannondale trail sl3 vs 2012 cannondale trail 5
    By idon'tlikepink in forum Beginner's Corner
    Last Post: 08-22-2012, 07:56 AM
  5. Trek 3700, Cannondale Trail 6, or Jamis Trail X2?
    By rjc003 in forum Beginner's Corner
    Last Post: 07-09-2012, 05:44 AM
