Results 1 to 9 of 9
    Reputation: yd35's Avatar
    Cable housings rubbing off paint
    Some of my cable housings have worn off the paint on my bike. I have two questions related to this: Is this harmful to the frame? How do I prevent this? Thanks
    Full of holes
    Reputation: SwissBuster's Avatar
    Quote Originally Posted by yd35
    1. Not really.
    2. Put clear tape over the rub zones, or change the cable routing so it doesn't touch. Or ignore it.
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    It won't really hurt anything, but if you want to prevent it, order some of this:
    http://www.go-ride.com/prod_fact.html
    It's like a thick clear vinyl that you can cut and stick whereever you want to protect. Like the starshield you can get for cars.
    ...the wave won't brek
    Reputation: anthrax's Avatar
    Mack Tack form the Dollar strore will probaly work too
    But most people tend to ignore it.
    If your frame is Aluminium then rust is not a concern.
    beleave me after you have enough miles on your bike the cable rub will be the leaste of your paint woes.
    Take care
    A
    2008 Santa Cruz Superlight SPX-XC Kit
    2003 Specialized Rockhopper FSR-XC Comp
    2006 Specialized Allez Sport Double
    ~I Ride In Circles ~
    Reputation: ZoSoSwiM's Avatar
    Dec 2005
    I went ghetto fab and did a strip of back electrical tape under my cables... Yeah, it doesn't look very nice but oh well.
    ~ it's all good ~
    Aug 2005
    No, it won't damage your frame unless if it's steel and rusts or something.
    pUt Da LiMe In Da CoKe YoU nUt
    nice, thanks for all the input. i think i'll rock the ghetto style and try wrapping athletic tape around the problematic portion of the housing.
    On MTBR hiatus :(
    There is such a thing as transparent vinyl (electrical) tape, as barely seen along the head tube weld in this photo.
    <img src="http://www.booboodog.net/images/shmk3(16).jpg">
    speedub.nate
    MTBR Hiatus UFN
    As mentioned in Go-ride site, there is a product that is called Clearbra, I have heard of a similiar product that is used on front of cars to prevent rock chips. I think its made by 3M. May be available at auto paint supply stores.
