    I Have No Friends2Ride w/
    Reputation: LOVELESS's Avatar
    Bonking ... not feelin' well Buying The Right Size Stem...
    hello, I need some help in getting a new Stem, The current stem I have feels long(about 4 inch), I want something shorter and same rise angle...
    so far I have my heart on Syncros AM Stem, it seems shorter judging from the picture...
    one of the size listed on the site is " 1-1/8", 60mm, for 31.8mm, I don't know whats the 60mm is for..
    http://www.speedgoat.com/product.asp...t=46&brand=381
    Can someone help me w/ this..? I see some w/ 70mm, 80mm, 100mm
    which one is the right size for my bike..
    http://img301.imageshack.us/my.php?image=f7rj7.png
    My Bike
    2009 Cannondale F7 Disc - Don't Know Y I Bought This Bike. N(-_-Y-_-)b
    I Truly Apologize For Any Grammar Errors
    pedal pusher
    Reputation: f3rg's Avatar
    Measure your stem from the CENTER of the handle bar clamp to the CENTER of the steerer tube clamp, and that will tell you how many millimeters it is.
    FYI: pretty much all bike measurements are taken from the center of one thing to the center of another.
    No matter which stem you get, though, make sure it has a 31.8mm bar clamp, but it seems you already figured that part out.
    Quote Originally Posted by f3rg
    oh.. I see, the 60mm, 70mm,& 100mm is for the length(how far apart handlebar will be from your head tube) correct..?
    so If I want my handlebar to be closest to my head tube(but also rised) I buy the 60mm right?
    My Bike
    Quote Originally Posted by LOVELESS
    Correct, the 60, 70... 150 is the length. 1 1/8 is the tube diameter. 31.8 is the handlebar diameter.
    Don't forget to include the angle in determining fit. If you get one with the same angle but shorter, it will drop the handlebar height some. The angle will determine how much it drops.
