Results 1 to 7 of 7
Thread: Bubble in Tube
    Reputation: hankscorpio's Avatar
    Jun 2012
    Bubble in Tube
    I found a tube I had left in the shed which means it went through winter and summer temps and humidity.
    I inflated it to check on it and it held air but I noticed there was a big bulge in one part of it. Probably 3 inches long.
    Toss it? Not a big deal? Ever seen that before?
    Jul 2013
    I'm no expert, but it sounds to me like a weak spot in the rubber, and it will likely pop the first time it rolls over something abruptly. I would trash it.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    Defo trash it. Tubes dont cost a lot. Better safe than being stranded out in blue yonder pushing your bike back for miles.
    Jul 2013
    You shouldn't even have asked. Throw it in the garbage.
    Reputation: masterofnone's Avatar
    I could tell you a long humorous (it wasn't at the time) story about a ride where I had a double flat and was literally eaten alive by a swarm of ravenous mosquitos, all the time running in circles with rims and tire levers pumping up tubes screaming and cursing the entire time. Orrrr...just throw it out
    Reputation: shiggy's Avatar
    Dec 1998
    Bubble in Tube
    Quote Originally Posted by hankscorpio View Post
    It is fairly normal and not usually a problem when the tube is inside the tire. I see it on at least half of the tubes I have ever had.
    mtbtires.com
    Trail Ninja
    Reputation: Varaxis's Avatar
    I see that in generic tubes a lot. It'll still do its job. Bulges like that just mean that there's varying thickness in that spot, which requires less force to stretch. It will conform to the shape of the tire.
    One might think that area would be more prone to damage, but if anything pokes through the tire or you pinch it, other parts of the tube don't really stand a better chance of not puncturing. If anything, it might lose air over time a bit more, since the rubber used to make tubes isn't completely air-tight due to the pores, and the thinner part of the tube might lead to more leakage. That's only something you would notice over a course of several days though.
    I don't believe cycles of cooling, heating, and varying humidity affects the rubber that tubes are made out of, most likely butyl rubber, like you think it would. I know that ammonia breaks it down and I don't believe it has any additives added into it that makes it resistance to ozone cracking, so exposure to outdoor air may deteriorate it. I think people are more or less saying to toss it more because it's old and neglected and how the dependability of the tube might weigh on their mind when they ride, and not so much because of the bulge.
    We're all on the same ship, and it's sinking.
  1. Bubble Spot
    By Haint in forum General Discussion
    Last Post: 04-25-2013, 08:25 AM
  2. M988 XTR MC - bubble coming out of...
    By Pau11y in forum Brake Time
    Last Post: 12-19-2012, 08:46 AM
  3. Bubble noise from front brakes?
    By EZuphill in forum Brake Time
    Last Post: 08-07-2012, 06:20 AM
  4. OT: Is Gold A Bubble?
    By Scott O in forum General Discussion
    Last Post: 12-28-2011, 03:45 PM
  5. Sooo embarrassed.... Bubble Guts on the trail.
    By George@PenuelBicycles in forum California - Socal
    Last Post: 09-27-2011, 04:39 PM
