Results 1 to 9 of 9
    Breakage in the Spokes
    So I am just getting into riding harder and I expected things to start breaking but just not so quickly. I am a complete newbie when it comes to fixing my bike although I am learning as I go.
    I was riding along a trail yesterday and out of no where a stick/branch decided to get in my spokes and popped two of them out. So, can I fix this and how difficult is it?
    MidnightBroomstickCowboy
    Good question, I could use this info. too.
    "As a true patriotic American, I blindly follow what my elected leaders tell me." - Jack English
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I think it's a piece of cake, but I took a little time to learn how to do it. A spoke wrench is the only special tool I recommend. Do a little reading on how it's done and give it a whirl. It's just common sense if you think about it and have a small amount of mechanical aptitude.
    A little verbose, but a decent read:
    http://www.kenkifer.com/bikepages/skills/spokes.htm
    Depending on where the broken spoke is, you might need a cassette lockring removal tool and a chain whip to get the spoke threaded in...
    it shredded out of the wheel. The piece that anchors the spoke in the wheel in broke.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Quote Originally Posted by swmarc
    For further reference, that thing is called a nipple.
    I suggest you buy some new spokes if the ones you have look pretty bent.
    Ok so I got two new spokes and nipples( thanks for that) and I have trued the wheel of wobble but now there is a hop in the wheel. It isn't horrible, and probably wont even noticeable if I ride on it. Should I worry about it?.
    Reputation: 4slomo's Avatar
    There are two parts to wheel truing: lateral true (wobble) and radial true (hop). Generally you work on one and then work on the other, until they both are right on. It may take several adjustments to get them both right.
    Reputation: 006_007's Avatar
    I resource that I highly recommend comes from a friend of cycling that we lost this past year. Sheldon was absolutely brilliant and published much information for cyclists to use.
    http://sheldonbrown.com/
    Check out the section on wheels. Go right into the wheel building section and it will answer all of your questions.
