Results 1 to 6 of 6
    Aug 2013
    Brake issue with new bike
    Hello everyone,
    I recently acquired a trek remedy 5 bike for a really good price, the bike had never been used by the previous owner, anyways straight to the issue, I had to take the wheels off the bike to get it to fit in my car, and I think during the trip the rear brake handle got pushed in. So as a result the back brake pads were closed. I removed the pads and use a 10mm wrench indicated by the manual to move the pistons back, but the pistons still seem to move back into place. Any ideas how to fix this?
    Jul 2013
    Which brakes are they? Brand etc....
    You may need to bleed them if you have pushed the pistons back in and get no results.
    Anyways, I just use a coin to put between my pads when the wheel is off or you can go and buy a specialized overpriced piece of plastic from your LBS.
    Post this in Brake Time with the variety of brake model.
    Fat-tired Roadie
    Nov 2007
    Hydraulic disc brakes self-adjust. You need to spread the pads with something. I suspect that the adjustment you found was for adjusting reach or how soon the pads engage in normal operation.
    A bleed block is a nice tool for spreading the pads because you're very unlikely to damage the braking surfaces, while using a metal tool can chew things up. I bet your local shop has a couple kicking around. Or, figure out something with whatever you've got on hand.
    The Shimano instructions say after you push the piston back, to insert a spacer or rotor and squeeze the brake lever several times. Likely this allows the fluid to drain back into the reservoir.
    Aug 2013
    Got it working thanks guys, just had to push the pistons back a little further. Here is the bike, I picked it up from a seller locally for a grand. Dude bought it and never rode it, it even had the warning stickers on it still.
    Attached Thumbnails Attached Thumbnails Brake issue with new bike-imag0024.jpg
  1. Formula RX brake issue
    By mbikerguy in forum Brake Time
    Last Post: 04-10-2012, 08:02 PM
  2. need help with brake issue
    By mudtoy1986 in forum Beginner's Corner
    Last Post: 11-17-2011, 06:13 AM
  3. Brake issue
    By Ford Prefect42 in forum Cannondale
    Last Post: 10-26-2011, 05:59 PM
  4. road bike brake issue
    By Scott O in forum Brake Time
    Last Post: 03-30-2011, 10:17 AM
  5. Brake fit issue on Carbon 456
    By K-max in forum California - Norcal
    Last Post: 02-21-2011, 12:46 AM
